#81 (permalink) |
paulmc
is looking for more power 750-800bhp is not enough
Cars owned: GTR R35, 911 turbo, F10 M5, V10 RS6
Just been outside, horrible night. I have nothing in either pipe both are soft and fully squeezable.
2019 RS3 Saloon To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#82 (permalink) | |
WingedBeast1968
is still here
How weird. I'm confused ![]()
#84 (permalink) |
paulmc
its pissing with rain and dark !!!!!!!!
the things i do. Give me 5 mins ![]()
#86 (permalink) |
paulmc
You clearly dont know me lol
Ok, muppet alert you are right. I have a some sort of restrictor on my driver side bank. it was tight againt the bollom hose connection so could feel nothing until i took the hose off the top connection. Sorry cant take a pic its too dark to get the hose off the bottom pipe. Taking the hose off the top pipe allowed me to feel the slug of metal in the pipe. Deffo nothing on the passanger side. like i tell my kids, do it once do it right, tripped on my own words. Sorry for the confusion.
#87 (permalink) |
WingedBeast1968
is still here
That's okay, thanks again.
![]() Cruising, the breathers actually suck air out of the turbo inlet, vacuum caused by the PCV and plenum. Why restrict one bank and not the other? That must surely cause a differing air volume between bank 1 and 2? Maybe that's why the bank balance is required. Balanced, despite different levels of bleed off through the breathers. I need to get my engine design book out again. Once again, you're a star dude! Thank you ![]()
#88 (permalink) |
keithmac
is a lurking GTO-TT owner..
Maybe so you don't have stagnant air in the valve covers?.
Good luck, sounds like you may have a rich spot in your fuel map and the short term fuel trim does a good job for the most part to cover it up. Retarding the ignition as softens the resumption throttle after coasting. I run an OS Giken R3C clutch in the GTO, tuned decel fuel cut out completely due to the harsh reaction when coming back on throttle. Could the gearbox have anything to do with it, maybe it should slip the clutch slightly to soften the transition?. I think the actual torque differnce at low throttle between 14.7:1 and 12:1 afr would be negligible?. What injectors have you got fitted?.
#89 (permalink) | |
paulmc
You got logs you can post up. or I can do logs of mine at idle etc if that helps?
#90 (permalink) |
WingedBeast1968
is still here
What's the restriction on bank 1? Good luck, sounds like you may have a rich spot in your fuel map and the short term fuel trim does a good job for the most part to cover it up. Stock map does it too. Defo an issue Retarding the ignition as softens the resumption throttle after coasting. Okay ![]() I run an OS Giken R3C clutch in the GTO, tuned decel fuel cut out completely due to the harsh reaction when coming back on throttle. Could the gearbox have anything to do with it, maybe it should slip the clutch slightly to soften the transition?. It does, but no amount of adjustment can dial it out. Touch points and clutch capacities are -7 to +7 range. Should be around zero for stock. I think the actual torque differnce at low throttle between 14.7:1 and 12:1 afr would be negligible?. It's pretty sensitive to torque. You can feel it surge forward. What injectors have you got fitted? Stock injectors. 570cc/min
#91 (permalink) | |
WingedBeast1968
is still here
Stock map, stage 1, stage 2, stage "stock like". All the same.
#92 (permalink) |
WingedBeast1968
is still here
Fuel cut overrun for a short time, then very light throttle pick up.
AFR bottoms out at 12.2; not good. datalog14.csv
#94 (permalink) | |
WingedBeast1968
is still here
#95 (permalink) |
paulmc
Busy fitting a new kitchen, sorry not had the time.
log attached I did a while ago, idle, cruise (light throttle) and full load / boost, only runing 1 bar of boost in log
#96 (permalink) | |
WingedBeast1968
is still here
#97 (permalink) | |
WingedBeast1968
is still here
![]() That log is proper messy man. Is that with big injectors? It looks like you've a vacuum leak, but the opposite to mine.
#98 (permalink) | |
paulmc
I was going to pressure test the system after I had the engine out but not had the time. It certainly goes well. What you see in the log?? How's yours any further on finding the problem??
#99 (permalink) |
WingedBeast1968
is still here
The trims look like either the tune is a bit off, or there's a leak somewhere.
She's adding fuel under cruising, and removing it under load, but can't quite make it's mind up. I've got the opposite to that, and a definite problem somewhere. Mine is still messing about, but I've noticed the turbo outlet pipe on bank 1 is oily and sooty (no sweep), which can only be coming from inside the pipe. When the temperature in the garage drops below 40, I'm taking them both off to have a look. Better since the injector seal replacement though, so I'm on the right track. ![]()
#100 (permalink) | |
paulmc
Ah that's ok. This was base tune just to see how it was going. 1.0bar on 95 got 5 maps after that one. Good to gear it's going better. Mine had a bit of oil but deffo no soot.
Bookmarks |
Thread Tools | |
