Ooh you tease, spoiling Shrek again and making my car jealous too! Hopefully one day I can get mine down to the Z-Unit and have the underside completely refurbished as well!
Yes, you did, and do you realise its virtually a year to the day when you found Shrek,
I have found your initial e-mail to me,
"shit you have to buy that one mate
that's a NUR R1"
"Ultra-rare! Nismo R1 engine retrofit V spec II Nur!
Nur dedicated color Millennium Jade + NISMO with Aero
Nismo LMGT4 OMORI FACTORY SPEC + S tune with Sass!
Construction content: R1 full conversion
(N1 block for the vehicle Nürburgring, N1 turbine body continued use)
The general advice was to get the largest possible, as the R34 is 4.5m long you need 5m or larger to move around the car to open the boot / bonnet etc.
so I went for the longest that will fit in my mates garage, It's the 'large' Cair-o-port @ 5.5m long. 3 fans, side and front doors, steel frame and whilst it is up against the up & over door, there is clearance when opening the door as the frame is angled inwards so no fowling issues.
Purchased from Hamilton Classic Ltd, delivery within 3 days.
Bobby / Zealou5 will be adding a final update shortly with all the latest photographs (far better photographs than I can take) and full tech info of what they did with what and why etc.
in the meantime, a couple of FSB photographs.
ref Nismo intake - yes, still available new as far as I can see - send a message to Jurgen or Aarin at JM-Imports and they will get you an upto date price.
and as it was sunny day time to polish the underside with the help of some second hand ramps I've recently purchased - extremely useful due to the lack of ground clearance on the R34!
I’ve been asked why spray the Epoxy Mastic 121 rather than the usual brush it on method!
A few reasons:-
I wanted a more OEM finish both texture wise and colour wise.
Zealou5 where able to colour match the 121 to the factory primer Nissan use on the underside from new.
There’s a lot more work involved as everything in Wiltshire has to be masked off that isn’t to be sprayed (gearbox, subframes, all lines & brackets, props, hubs, suspension arms etc, etc, not to mention the entire top of the car and the engine bay interior & all holes going through to the engine bay from the chassis).
Using the same amount of Epoxy 121 as a ‘normal’ paint brush job, 3 coats rather than 2 where applied – missing nothing, all holes, cavities covered and protected and the resultant finished is superb.
This was the first time Zealou5 had applied the Epoxy by spray and it worked out really well IMO.
Probably 75% to 100% more expensive due to the massive masking off task – but well worth it and a track test day has already been booked @ Bonneville, I am that confident that this is protected for 20+ years – easy
plus a few close up photographs of the finish achieved and wet testing with H2SO4 & HCl – no problem. :chuckle:
Black LM GT4 wheels off today for a clean, inspection of the wheel arches following the work carried out by Zealou5 and a try out of the white Nur Spec Enkei wheels.
Super work, IMO, as clean as, each and every nut and bolt torqued to the correct level and identified with a green dab of paint when completed - thorough - I like it! :chuckle:
Related Threads
GTR Forum
2.4M posts
69.2K members
Since 2001
