bleeding problem? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan Skyline > Brakes, Wheels, Tyres and Suspension (Skyline)
Like Tree1Likes
  • 1 Post By FRRACER
Old 27th May 2005, 05:34 PM   #1 (permalink)
JOHN Q is unaware they can edit their status
Cars owned: R33 SKYLINE GTR
bleeding problem?
hi all
any info on bleeding the brakes on my r33 gtr.
ive just changed the fluid and they are a wee bit spongey all the air seems to be out of the system. ive heard about bleeding the abs pump but there doesnt seem to be a bleed nipple on my pump.
anybody any thoughts?
cheers john
JOHN Q is offline   Reply With Quote
Old 28th May 2005, 05:10 PM   #2 (permalink)
nobody any ideas?
Old 28th May 2005, 08:02 PM   #3 (permalink)
Jabberwock is unaware they can edit their status
Jabberwock's Avatar
Cars owned: R33 GTR
I was told there should be no need to bleed the abs pump......
When I do mine I do them one bleed nipple at a time ie two goes on each caliper - it takes longer but for some reason gives me better pedal feel afterwards compared to duel-bleeding.
Ken
Just another kart mechanic...
Tuned by Abbey Motorsport
Jabberwock is offline   Reply With Quote
Old 29th May 2005, 08:10 AM   #4 (permalink)
thanks ken, ive bled each caliper a few times now and they are still a bit spongey, saying that if you half press the pedal and press it again its solid and doesnt go soft.
cheers anyway
john
Old 29th May 2005, 03:28 PM   #5 (permalink)
Jabberwock's Avatar
Cars owned: R33 GTR
Some people (including me) have also fitted a brake-stopper which prevents the master cylinder from moving when the pedal is depressed firmly. It doesn't increase braking power but gives a more confident and immediate feel to the brakes. There are several available so you may need to shop around. Easy to fit too.
Cheers,
Ken
Old 16th February 2015, 11:03 AM   #6 (permalink)
kangal is unaware they can edit their status
i have the same problem
kangal is offline   Reply With Quote
Old 16th February 2015, 11:56 AM   #7 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
I'm quiet sure the R33 abs block does have bleed nipples. There should be two I know on the R32 they have them.
Start from the caliper further away from the master cylinder so LR, RR, LF and RF. Then do the abs. I would avoid dot 5 or 5.1 gives soft pedal feel compared to dot 4 or 4.1
RossC likes this.
Old 16th February 2015, 10:38 PM   #8 (permalink)
TABZ is R35 GT-R
Replaced brake fluid on my R33 Gtr today, couldn't find any bleed nipple on the abs block.
Just followed the same sequence listed above with no real issue.
3 of my bleed nipples were blocked from sitting about so long; removed them and a quick drill through seen them right again
TABZ is offline   Reply With Quote
