Jun R32GTR - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree196Likes
Old 17th August 2015, 01:26 PM   #1 (permalink)
Dan Parker is unaware they can edit their status
Dan Parker's Avatar
Jun R32GTR
Here is my 32GTR
Spec
INTERIOR
Hks f-con v-pro gold Ecu (mapped by MGT)
Inovite lc-2 wideband
Hks evc 5 boost controller
Hks turbo timer
Omori Factory oil pressure gauge
Omori Factory boost gauge
Omori Factory oil/water temp gauge
(All gauges in custom built alcantara trimed centre console painted KH2 gunmetal grey)
Tomei gear knob
Custom made gear gaitor in black leather with white stitching
Shift light
Fuel pump warning lights
RWD switch
Hks kansai 6 point roll cage with rear diag bar (dash dodger) painted in Audi ibis white
Roll cage mounted fire extinguisher
Original Gtr matts
ENGINE SPEC
JUN 87mm forged Pistons
JUN forged rods
N1 balanced+edged crank
Nismo engine bearings
Jun oil pump
Jun rod bolts
Jun main bolts
Jun fully worked cylinder head
Jun fully prepped original R32 block
Tomei oil restrictor
Jun adjustable cam pulleys
Hks special order cams
Jun titanium retainers
Jun valve springs
Jun shims
Jun head bolts
Hks metal head gasket
Hks spy intake filter
Jun custom made intake pipe
Trust spec-R hug intercooler
Jun custom made polished aluminium hardpipes
(Jun custom boost pipe heat shields+joiner brackets)
Hks T51 Kai signature series turbo (comp housing modified)
Hks manifold
Sard 66mm type-J magnesium external wastegate
Jun custom built screamer pipe
Jun custom built titanium exhaust
Jun billet aluminium ignition amplifier bracket
Jun billet aluminium intake pipe bracket
Jun billet aluminium sensor brackets
Jun billet aluminium twin fuel filter holder
Earls stainless braided lines throughout
As co pipes
Most bolts/washers replaced with stainless
Jun custom breather tank
Jun custom aluminium cam cover breather pipes
Custom 3" core copper radiator
R34 fan
Jun oil thermostat
Nismo coolant thermostat
Nismo fpr
800cc injectors
Jun modified fuel rail for extra fuel pump feed
Sard twin fuel pumps (each with separate earls stainless lines)
Sard twin fuel filters
Trust oil cooler kit
Trust oil filter relocation kit
Hks earthing kit
TRANSMISSION SPEC
Os-giken triple plate clutch
Os-giken lightweight flywheel
Os-giken 1st-3rd gear kit
Nismo short shifter
Nismo slave cylinder
Nismo gearbox mount
Modified transfer clutch pack
Nismo rear diff
SUSPENSION
Tein coilovers
Tein pillow ball top mounts
Tein pillow ball tension rods
Cusco front upper suspension arms
Arc front arb
Arc rear arb
Cusco front strut brace
Cusco rear strut brace
Braced rear subframe
Tomei hicas lockout
BRAKES/WHEELS
Rota torque 18x10 et12 in White
Blox red billet aluminium wheel nuts
Abs removed
Brembo front brakes
Earls braided brake lines
Tomei master cylinder stopper
R33 Gtr servo
Nismo master cylinder
BODY
KH2 gunmetal grey
Nismo front bumper
Nismo rear quarter spats
Nismo side skirts
Nismo rear bumper spats
Nismo bonnet lip
All original R32 Gtr badging
Clear/smoked front indicators
GTRNICK and mayed87 like this.
Dan Parker is offline   Reply With Quote
Old 17th August 2015, 01:36 PM   #2 (permalink)
Tinoush is dreaming of 500 HP
Tinoush's Avatar
we love pictures
TrendSetter likes this.
Tinoush is offline   Reply With Quote
Old 17th August 2015, 01:44 PM   #3 (permalink)
Dan Parker's Avatar
Wil post pics later
Old 17th August 2015, 05:02 PM   #4 (permalink)
markM3 is GTRless!
Blimey, sounds like a monster!
Await loads of pics!
markM3 is offline   Reply With Quote
Old 17th August 2015, 05:16 PM   #5 (permalink)
Dan ep3 turbo is unaware they can edit their status
Dan ep3 turbo's Avatar
About time Dan, you missed off precision 6266 turbo.
Dan ep3 turbo is offline   Reply With Quote
Old 17th August 2015, 05:23 PM   #6 (permalink)
Dan Parker's Avatar
Hi mate, yeah it's taken so long I thought that I'd start from the beginning and and work from there.
Old 17th August 2015, 06:10 PM   #7 (permalink)
Dan Parker's Avatar
Originally Posted by Dan Parker View Post
Here is my 32GTR
Spec
INTERIOR
Hks turbo timer
Tomei gear knob
Shift light
RWD switch
Original Gtr matts
ENGINE SPEC
JUN forged rods
Jun oil pump
Jun rod bolts
Jun main bolts
Jun valve springs
Jun shims
Jun head bolts
Hks manifold
As co pipes
R34 fan
Jun oil thermostat
Nismo fpr
800cc injectors
Hks earthing kit
TRANSMISSION SPEC
Nismo short shifter
Nismo gearbox mount
Nismo rear diff
SUSPENSION
Tein coilovers
Arc front arb
Arc rear arb
Tomei hicas lockout
BRAKES/WHEELS
Abs removed
Brembo front brakes
R33 Gtr servo
BODY
KH2 gunmetal grey
Nismo front bumper
Nismo side skirts
Nismo bonnet lip
sädde likes this.
Old 17th August 2015, 06:12 PM   #8 (permalink)
Dan Parker's Avatar
sädde likes this.
Old 17th August 2015, 06:14 PM   #9 (permalink)
Dan Parker's Avatar
MS33, Peedro and sädde like this.
Old 17th August 2015, 06:15 PM   #10 (permalink)
Dan Parker's Avatar
sädde and mayed87 like this.
Old 17th August 2015, 06:16 PM   #11 (permalink)
Dan Parker's Avatar
sädde likes this.
Old 17th August 2015, 06:18 PM   #12 (permalink)
Dan Parker's Avatar
Old 17th August 2015, 06:19 PM   #13 (permalink)
Dan Parker's Avatar
Old 17th August 2015, 06:20 PM   #14 (permalink)
Dan Parker's Avatar
Old 17th August 2015, 06:22 PM   #15 (permalink)
Dan Parker's Avatar
Old 17th August 2015, 06:23 PM   #16 (permalink)
Dan Parker's Avatar
sädde likes this.
Old 17th August 2015, 08:54 PM   #17 (permalink)
Dan Parker's Avatar
New titanium exhaust
Fitted new full titanium exhaust from garage whifbitz
Only 7kg
sädde likes this.
Old 17th August 2015, 08:55 PM   #18 (permalink)
Dan Parker's Avatar
sädde likes this.
Old 17th August 2015, 08:55 PM   #19 (permalink)
Dan Parker's Avatar
sädde likes this.
Old 17th August 2015, 08:56 PM   #20 (permalink)
Dan Parker's Avatar
