Larger throttle bodies for RB26 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan Skyline > Engine Mods
Old 24th August 2002, 01:38 PM   #1 (permalink)
DCD
DCD is speedhunting
DCD's Avatar
Cars owned: BNR34 V-spec
Any idea the benefits of larger throttles on the RB26? I've never really seen too many of these used on tuned cars and even demo cars. I imagine that more air means more power if combined with other variables(ie injectors, mapping...)
Any thoughts?
Old 25th August 2002, 02:24 AM   #2 (permalink)
hipogtr is putting the R35 under the knife
hipogtr's Avatar
Cars owned: Ganbaru Vitz!
Here are my thoughts, DCD.
IMHO, the larger 6 throttle bodies are best used where increased high rpm air flow is required but not at the expense of responsiveness - as you get with a larger single throttle conversion. For example, circuit cars. However, they are not paricularly popular because:
(1) They are quite expensive (same costs as a single throttle conversion);
(2) The overall increase in surface area of the throttles is restricted due to machining constraints - its about 3-4mm increase in diamater for each throttle plate;
(3) The compromise in responsiveness from going to a single throttle body setup is outweighed by the gains in mid to high range torque that a large single throttle conversion provides; and
(4) In a high powered RB engine, there appears to be just as much to gain from a reshaped intake plenum and air charge entry point as increased individual throttle body size (ie. improved air trajectory into the plenum resulting in better air distribution, particularly for cylinders 5 & 6 which seem to suffer from getting more air than the other cylinders).
Cya O!
hipogtr is offline   Reply With Quote
Old 25th August 2002, 02:31 AM   #3 (permalink)
DCD
DCD is speedhunting
DCD's Avatar
Thanks hipogtr. Thought as much after reading the single throttle body thread on SDU. I would have thought this could be a haflfway option between stock throttles and a big 80-100mm single. But as you said the price is far too high...
I was wondering what size of throttle bodies the old Gr.A engines used to run? Any ideas?
Old 25th August 2002, 11:53 AM   #4 (permalink)
hipogtr's Avatar
Hey DCD... Based on the Group A Calsonic BNR32 specifications (in the GT-R Owner's Book), they use the factory 6 butterfly throttle body. There's no mention of any changes or enlargements. Come to think of it, maybe that is on of the things that the Group A cars are restricted from changing.
Cya O!
Old 26th August 2002, 03:18 AM   #5 (permalink)
DCD
DCD is speedhunting
DCD's Avatar
Thumbs up
Hipogtr....just picked up that book. Bloody great isn't it!!!
Old 26th August 2002, 09:03 AM   #6 (permalink)
hipogtr's Avatar
Definitely one of the best reference books I've seen around, DCD. I think that type of book will be coming out for a number of other cars as I've already seen the RX-7 one as well.
Cya O!
Old 2nd September 2002, 04:56 PM   #7 (permalink)
Scott is GTROC #005
GTROC Co-Founder.
Scott's Avatar
Cars owned: BNR32.
So what is this book then guys?
Where can I get one and how much???
Regards,
Scott.
O O SKYLINE O O
My R32's full restoration:
Air Filters:
Scott is offline   Reply With Quote
Old 2nd September 2002, 05:21 PM   #8 (permalink)
DCD
DCD is speedhunting
DCD's Avatar
Its called "GT-R Owners Book" and its 2500Yen. Contains a look at a few racing GTRs, goes through the RB piece by piece, and a few other things like GTR catalogues. The main section is a very good graphically represented guide of basic maintenance procedures. Gives you all sorts of info on parts that need to be looked at, tells you the tools you will need, the approx time you need, parts number and generally very useful info. Would be twice as good if I could read Japanese properly...but nonetheless a very good buy.
Its been out a month or so...but I would have no idea who would sell this in the UK
Old 2nd September 2002, 05:48 PM   #9 (permalink)
Philip is unaware they can edit their status
Dino,
Who publishes it?
Phil
Philip is offline   Reply With Quote
Old 2nd September 2002, 05:54 PM   #10 (permalink)
DCD
DCD is speedhunting
DCD's Avatar
Published by Sanei-shobo Publishing Co., Ltd.
I also found a link:
GT-R Owners Book
Old 2nd September 2002, 05:57 PM   #11 (permalink)
DCD
DCD is speedhunting
DCD's Avatar
The book can also be ordered directly from them for 4610 Yen (airmail)
Hope this helps
Order Info
Old 2nd September 2002, 06:07 PM   #12 (permalink)
Dino,
Quicker than I could search for it - thanks.
Phil
Old 4th September 2002, 04:08 PM   #13 (permalink)
MDG
MDG is unaware they can edit their status
Just to get back on the issue of throttle bodies, maybe some of you have already seen this thread on SkylinesDownUnder:
http://forums.skylinesdownunder.co.n...threadid=15496
It makes for some interesting reading, especially if you're serious about drag racing.
MDG.
MDG is offline   Reply With Quote
