cracked engine block - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree1Likes
  • 1 Post By RSVFOUR
Old 6th January 2016, 08:44 AM   #1 (permalink)
markr32gtr is unaware they can edit their status
Have been looking over my engine block getting ready to build up and have found a crack on one of the water ports to the stud hole. Will I get away with this or is the block scrap ?
markr32gtr is offline   Reply With Quote
Old 8th January 2016, 11:00 AM   #2 (permalink)
Jayman is Owner of R34 GTR 720 hp
Hi Mark
If it was me, personally i wouldn't risk it. It would always be in the back of your mind if you were to use the block.
you can pick blocks up from many traders on here for a relatively small amount, if you get the option go for an early R32 GTR block as they do not go porous as the casting process was different and stronger.
Regards James
Jayman is offline   Reply With Quote
Old 8th January 2016, 11:24 AM   #3 (permalink)
ernie-b is fixing what the A team can't
ernie-b's Avatar
Cars owned: r33, capri, transit, granada
^^^ definitely 100%
you can't expect a good build on shoddy foundations
also you cant tell how deep the crack goes, at the very least it's a stress point and won't get any better
sort the problem now while it's all out in front of you rather than having to tear it all down again later when it causes problems. Probably cheaper in the long run too.
ernie-b is offline   Reply With Quote
Old 8th January 2016, 01:54 PM   #4 (permalink)
Yvo
Yvo is unaware they can edit their status
Yvo's Avatar
Cars owned: PRIMERA P10/11 eGT,BNR34,AUDI COUPE,ALFA 156
i would not risk build this engine and after the first full throttle you have a probleme,
then you have to do the same job again
Yvo is offline   Reply With Quote
Old 8th January 2016, 02:09 PM   #5 (permalink)
Alex C is learning my diff
Alex C's Avatar
Cars owned: R33 GTR, Audi A8
Couple of blocks in the for sale section worth a look....
And mod the oil gallery on the head while you're at it...I got stung with that one once which really annoyed me as the engine had been apart once in its life already.
Alex C is offline   Reply With Quote
Old 11th January 2016, 09:23 PM   #6 (permalink)
I was wanting to build the block to stand 1000 just so then I know it will cope if I ever wanted more. Am thinking in mined just to get a full built engine and strip that down .. but then that may have a crack . It was a full built bottom end and its all scrap know
Have just striped the head ready to fit a oil drain in the back and fitting new cams valve springs and may be valves .. Not shore what standard valves take ?
Old 10th April 2017, 09:32 AM   #7 (permalink)
Phil69 is missing having the GTR on the road
Phil69's Avatar
Cars owned: Skyline GTR R33 V-SPEC
Originally Posted by Jayman View Post
Hi Mark
Regards James
Sorry to hijack this thread but in relation to this, how can you identify which version the block is? Is it certain part numbers? Where are the numbers printed?
Guide to racing: See god and back off!
Phil69 is offline   Reply With Quote
Old 10th April 2017, 11:14 AM   #8 (permalink)
RSVFOUR's Avatar
code is cast on the block
OSU - Standard
24U - Stronger N1 block which can also be bought seperately
For completeness there is also a RRR Block which is the strogest but these cost really silly money (if you can find one)
Bennyboy1984 likes this.
aka The Grean Machine
My website -
Old 10th April 2017, 11:29 AM   #9 (permalink)
daytona is unaware they can edit their status
Cars owned: R32 GTR RB2.8 , Modded Suzuki GSXR 1000, Suzuki RGV500.
Anyone got a link to a thread that shows how to go about doing the 'oil gallery' mod as mentioned by Alex C? I'had a good search and come up short with any solid info on this.
daytona is offline   Reply With Quote
Old 10th April 2017, 05:01 PM   #10 (permalink)
Spiidfriik is unaware they can edit their status
Cars owned: Skyline GT-R R33, Celica GT-Four ST205, Eagle Talon TSi G1b, M5 Touring E34
Oil mods
https://youtu.be/E1sacK_wCio
https://youtu.be/M_3prtDBQOc
Spiidfriik is offline   Reply With Quote
Old 11th April 2017, 12:04 AM   #11 (permalink)
Couple of interesting vids there thanks , but i'm really looking for info on the mod where an external line is routed around the head to circumnavigate the internal water/oil ways, due to a crack developing?
