Do Luck DTM II Fitting Guide - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree4Likes
Old 20th January 2016, 09:42 PM   #1 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
After reading Aki's great review of the Do Luck DTM II it was time that the aging analogue g sensor was replaced with a more modern and up to date setup. Also at the same time remove the old and trusted Skylab fusion which was one of my first mods after almost losing the back end on my way home from RK
Remove the centre console to access the OEM G sensor:
In my case I ripped out the Skylab also
OEM G sensor removed from the mounting plate:
Do Luck DTM G sensor box mounted with double side tape provided to OEM Bracket
Plugged into existing harness and two wires for TPS routed towards the ECU and another plug for the display
routed towards the ash tray/stereo area.
Locate and identify the purple/grey wire for TPS from pin 56 Brown wire ecu side and orange wire engine side
Next up to mount the small LCD display/Controller
Next step to calibrate the TPS and the selection of modes available: To follow.
akasakaR33 and Jayman like this.
Old 20th January 2016, 09:44 PM   #2 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Summary of the available modes:
There are a total of 7 settings:
4 in G mode - G1, G2, G3, and G4
3 in ARX mode A1, A2, and A3
G1= Output signal same standalone Do Luck Digital G sensor:
G2= Output signal same standalone Do Luck Tarzan G Box:
G3= Output signal same as a new Nissan oem G sensor:
G4= User programmable - can define a percentage for each of the 4 (front, rear, left, right) G forces should be multiplied by, as sent to the ATTESA ECU. The user can choose an amplification between 0% to 200% for front, left and right G forces, but for the rear G force (i.e. braking), the amplification range is between 100% and 115% (From Aki's Blog)
ARX Mode uses throttle position along side G force and is multiplied by a set variable for each of the settings looked up from the Attesa ECU map.
A1= Street Mode
A2= Circuit Mode
A3= Pure signal mode for both throttle position and G force.
Old 20th January 2016, 10:12 PM   #3 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
TPS Calibration
Old 20th January 2016, 10:13 PM   #4 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Going through the user modes
Old 20th January 2016, 10:33 PM   #5 (permalink)
Mel HKS is Thinking... Change isn't always good
Mel HKS's Avatar
Cars owned: R33 GTR
Looks a great piece of kit and a nice guide you've done there
"Everyone has a plan until they're punched in the face!"
Mel HKS is offline   Reply With Quote
Old 13th March 2016, 09:36 PM   #6 (permalink)
Jayman is Owner of R34 GTR 720 hp
I have a question for you... On my R34 GTR the MFD never shows 100% Throttle...(for a reason i dont know, maybe it needs calibrating?) maybe max like 40-50% will this effect the operation of the DTM2??
James
Jayman is offline   Reply With Quote
Old 14th March 2016, 11:08 AM   #7 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
The DTM takes the beed direct from the ecu tps signal pin and then once installed you need to calibrate the throttle. Not sure about the MFD. Might need calibration also?
Old 14th March 2016, 11:32 AM   #8 (permalink)
Great I shall look into it. I dont see why it wouldn't work. If i had one complaint about the Screen to the G sensor is that the loom is roughly 6 inches too short i had to lengthen the loom in order for it to go under the wash/wipe stalk where I wanted it. ill post some photo's up later this week all in all looks a great product so far
Old 17th March 2016, 12:39 AM   #9 (permalink)
bwrgtr is unaware they can edit their status
great guide, where did you pickup your Do Luck kit from?
bwrgtr is offline   Reply With Quote
Old 17th March 2016, 11:35 AM   #10 (permalink)
Supertec is unaware they can edit their status
Registered User
We supply the Do Luck DTM kits. PM us for more details.
Supertec is offline   Reply With Quote
Old 1st June 2016, 09:38 PM   #11 (permalink)
SkylineFanR34 is unaware they can edit their status
Is the Do-Luck DTMII currently the best ATTESA Upgrade on the Market?
Does it works with the ATTESA ETS-Pro Version from a V-spec?
SkylineFanR34 is offline   Reply With Quote
Old 1st June 2016, 10:48 PM   #12 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Yes it does work with all models. Imo it's the best and easy to fit. Depends who you ask.
Old 2nd June 2016, 01:00 AM   #13 (permalink)
Ok That's fine. Which Setting do you mean Is the best? G mode or ARX? And use the ARX Mode only the throttle Position or combination with G Signals?
Old 9th June 2016, 02:07 AM   #14 (permalink)
habu32 is ready to strike
Cars owned: 1993 Nissan Skyline GT-R
hi, just curious...does this allow you to monitor percentage of power going to front? Kinda like a digital torque meter, like what's on the gauge cluster?
habu32 is offline   Reply With Quote
Old 9th June 2016, 08:07 AM   #15 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
I'm using A2 most of the times its quiet agressive. Just find one that works with you. I also like to map using the tps based input to then give front torque based on throttle position.
No does now allow to monitor front torque.
Old 9th June 2016, 08:53 AM   #16 (permalink)
Sounds like a pretty awesome item though, you can get the best of all DL's boxes or tune yourself. Does anyone else offer something like this (Midori Seibi, Top Secret, AutoSelect, etc)? I was really interested in Midori Seibi's G-sensors, but this has potentially swayed me, specially after reading about the Tarzan box.
Old 9th June 2016, 09:45 AM   #17 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
The do luck imo is the easiest configurable option. You have full race but fitting is a little involving and it bypasses the attesa ecu.
Old 11th June 2016, 01:01 AM   #18 (permalink)
It completely bypasses the ATTESA ecu? Didn't think that was possible unless you had something like what Full Race offers. Is this fully digital speed? Not analog like factory? Is the ecu analog or does it send/receive analog signals like the g-sensor? If so, if this DTM is fully digital and bypasses all the analog factory stuff, then wonder why this isn't more popular, since it should be super fast compared to OEM.
Or am I way off?
Old 11th June 2016, 01:04 AM   #19 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Full race bypassed the attesa ecu. Do luck doesnt. The R32 speed improvement up approx 30 times and 15 times on an R33/34. It's digital
Old 11th June 2016, 12:09 PM   #20 (permalink)
Ah my mistake, I misread your post. Thought "full race" meant a mode of the DTM. Sorry!
I wonder how having something like the Omori Factory ETS ecu from the CRS R34 GT-R would affect it. I can't find any information on it other than what's on their site, but I've read it's been "reprogrammed". Wondering if it's faster than the regular R32/33/34 model ecu's. If so, would there even be a need for a controller? Or maybe still a need but if it's got updated internals, if it'd make using a new G-sensor even better.
ETS control unit NISMO Z-tune specifications, M / C before
