Fitting Nismo 8Kgfm kit to standard R32 GTR R200 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 18th May 2016, 09:25 PM   #1 (permalink)
CabbageMS is trying to keep r32godzilla.com up to date...
Hi all,
Recently ordered 3843S-RS520 Nismo 8kgfm diff rebuild kit to stiffen up the rear diff in my R32 GTR. I'd heard the kit was a drop in fit. However after fitting the kit it's about 1mm short of being under correct preload. So I could have two 0.5mm spacers machined, but it seems like a bit of a faff. Does anyone have any further info on fitting this kit? Am I missing something, or is it genuinely made to just fit the full NISMO differential, and is not in fact a drop in upgrade to the standard R200 diff?
CabbageMS is offline   Reply With Quote
Old 18th May 2016, 10:25 PM   #2 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
I think mambastu said he'd fitted this kit, so maybe drop him a pm in case he hasn't seen this thread.
I also have this nismo kit waiting to be fitted so I'd like to know the method.
Old 19th May 2016, 08:36 AM   #3 (permalink)
I'll give him a shout!
Old 19th May 2016, 11:32 PM   #4 (permalink)
mambastu is looking forward to fork lift powah !
mambastu's Avatar
Cars owned: TH1 R32GTR, Ex-RB25DETT RS13
I've got the 3843S-RS521 12kgfm kit which I believe has different plates to the 8kgfm kit. I've changed my final drive ratios so I used a GTS-4 diff housing/output shafts and CWP and replaced the original VLSD core with a R32 GT-R LSD core and that was rebuilt with the 12kgfm kit. Straight forward plate replacement. Think I used the shims from the GTS-4 diff but can't really remember.
Stu
mambastu is offline   Reply With Quote
Old 20th May 2016, 08:14 AM   #5 (permalink)
Skyrel is aware they can edit their status
I cant really help you, but I installed this same kit in my 33 recently. I could not make any sence of the measurements in the instructions since they were in japaneese, so I just installed them with the two shims included and installed.
Looks up well, great upgrade to the worn out stocks I had.
Skyrel is offline   Reply With Quote
Old 26th October 2016, 01:53 PM   #6 (permalink)
I'm about to get on the case with this, but still have the original issue. In case I cannot get the correct spacers made up, does anyone know the part number for the standard R32 GTR rear diff plates? Or where you can get a standard rebuild kit from?
Old 27th October 2016, 06:00 PM   #7 (permalink)
What is the allowed tolerances for the measurement?
Old 10th July 2017, 01:00 PM   #8 (permalink)
mangiavelox is unaware they can edit their status
I need to fit it on my r200 but I m confused because there isn t like the oeml.
My questions is if I need to put the oem spacer or not and in which order I need to fit the different parts...
mangiavelox is offline   Reply With Quote
