Step change in handling, comfort settings and Launch Control performance - read on - Page 11 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan GT-R > Technical Chat
Like Tree84Likes
Old 27th October 2018, 08:11 PM   #201 (permalink)
Gasman is unaware they can edit their status
Gasman's Avatar
So I’ve had the dsc on the car for a couple of weeks and feel like I can give some feedback on the system.
Unfortunately I can’t add much to what’s already been said!......
A much improved supple ride when cruising, less dive when braking, flat in the corners.
I’ve only ever driven a cba gtr and I would say the dsc is worth upgrading to for the improved suppleness alone. I know some have questioned whether track times are improved as a result of the system. I don’t track my car so can only offer subjective findings.
For normal driving I find I can drive the car faster on my local crap roads without having to wince. The car certainly doesn’t crash over smaller road imperfections any more.
I have also found a nice benefit when pushing on....the tyres don’t seem to skip and scramble for grip in the corners anymore. The increased contact time gives me more confidence in the corners and you can really feel what the tyres are doing. The adaptive nature of the system is easy to get used to. Initially I thought that constantly changing suspension parameters would make the car unpredictable but instead it’s intuitive and works with you. The under/over steer bias of the car can be tailored to your preference.
It’s also possible to adjust the settings yourself via a laptop. I actually had a go at a map myself. It was horrible! And that made me realise that the system is very reliant on the quality of the mapping. That’s where Hugh comes in. He supplied me with 3 maps and his communication and support has been excellent throughout.
So in a nutshell I would say that on a cba gtr, a stage 1 remap and the dsc controller are no brainers due to their cost-benefit ratio
Gasman is offline   Reply With Quote
Old 28th October 2018, 08:54 PM   #202 (permalink)
Hugh Keir – PTSYS is getting old
Single Product Trader
Hugh Keir – PTSYS's Avatar
Cars owned: R32 GTR Race Car
Originally Posted by mcz View Post
Just got around to fit the DSC Sport controller today, I have been looking forward to installing it so I could test it before storing the car for the winter.
And I just got home after testing the various suspension settings, and I was really impressed. A much more refined feeling and much better rebound in each setting and the reduced body roll in Race is just perfect. Makes me wonder if I really should be eyeing new uprated ARBs at the moment.
Really looking forward to taking it to the track again in the Spring, this time with the DSC controller installed!
Fitting went OK, my big hands had some problems getting a good grip of the OEM controller, but overall really simple and easy to do.
For reference, I am running a CBA stock suspension on Toyo R888R tires.
Thanks Hugh, really great communication and quick responses, appreciate it!
Thanks mcz,
CBA suspension has much firmer spring rates than the later year GTR's and only slightly less than the Nismo GT3.
If you ever plan on tracking your car, ARB's will provide less roll than the DSC Sport with standard maps.
The stiffening response from the standard suspension maps on CBA cars is generally sufficient for road use, however many who track their cars feel the benefit of aftermarket Anti-Roll Bars.
Using the Tractive suspension, that also works with the DSC Sport system, there would be a reduced requirement for aftermarket anti-roll bars since Tractive can provide up to 40% more damping resistance than the standard Damptronic shockabsorbers.
Thanks
Hugh
DSC Sport equipped R35 launching at TOTB
name="wmode" value="transparent"> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Hugh Keir – PTSYS is offline   Reply With Quote
Old 29th October 2018, 07:27 AM   #203 (permalink)
paulmc is looking for more power 750-800bhp is not enough
paulmc's Avatar
Cars owned: GTR R35, 911 turbo, F10 M5, V10 RS6
Hugh,
My car should arrive early Jan 2019. I guess other than softer springs and maybe geometry changes my car will have the same suspension as previous years?
Will fitting your module allow for even softer ride when cruising but stiffer when required?? I am getting old, need comfort most of the time lol
misters3 likes this.
2019 RS3 Saloon
paulmc is offline   Reply With Quote
Old 29th October 2018, 07:44 PM   #204 (permalink)
Originally Posted by paulmc View Post
Hugh,
Paul,
Congratulations on your new car.
I am not aware of any changes to the spring rates for the latest GTR's.
The suspension can be made softer than standard on all year GTR's.
The Comfort, Sport and Race maps are all programmed to suit your requirements, most users ask for the suspension to be programmed softer than standard in Comfort.
The Sport and Race maps are also generally left softer while driving straight ahead to improve traction going into and out of corners. The suspension then stiffens up to familiar levels as the cornering G-Forces increase.
Adjustments to anti-dive when braking and anti-squat on acceleration also help build confidence.
There are users who prefer the suspension to be stiffer at all times, this is also possible, it's up to you to let me know what suits you best.
The hardest job on the latest model year cars is firming the suspension up sufficiently for track days, it is doable, these cars would benefit from anti-roll bars and springs if planning regular track excursions.
Increasing the castor is also beneficial for track day handling.
In my own GTR, I enjoy the comfort settings 99% of the time, so we are on the same wavelength there.
Thanks
Hugh
Old 30th October 2018, 07:42 AM   #205 (permalink)
paulmc's Avatar
Thanks Hugh,
Yeah the new one looks a bit lively. I prob won’t do springs but may well do antiroll bars, and if your module reduced braking dive that can only be a good thing.
have a look at the video from 10.45 mins in. Seems like under braking the rear is unloaded to the point where it makes the car unstable. Watching the rest of the video the 17 car looks a bit of a handful.
https://www.youtube.com/watch?v=gqBJGLysZzw
2019 RS3 Saloon
Old 30th October 2018, 01:23 PM   #206 (permalink)
charles charlie's Avatar
Thanks Hugh,
I interpreted that squirm as a bit of driver error. He'd taken a line towards the outside of the turning point to try and get onto the racing line from an inside starting position, but then turned in under braking, unsettling teh car.
What is most apparent is how stable under cornering the Nismo is in comparison. Little body roll, no drama at all. I'd love one of those!
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 31st October 2018, 03:32 PM   #207 (permalink)
fastby4 is unaware they can edit their status
Originally Posted by barry P. View Post
It would be interesting to run the set up on a damper Dyno if it was possible to set up a loom to initiate the inputs to see how well it works.
I did some damper tests.
See in the link
https://www.gtrlife.com/forums/topic...ein-dyno-test/
fastby4 is offline   Reply With Quote
Old 1st November 2018, 08:32 AM   #208 (permalink)
See in the link
Interesting data you gathered, thanks for sharing.
Are you telling us that the 2009 car has softer springs than the 2012 car?
If I am reading the graph correctly:-
The 2009 car has 113 N/mm (645 lb/ins) at 100 mm compression.
The 2012 car has 137 N/mm (782 lb/ins) at 100 mm compression.
Old 1st November 2018, 08:59 AM   #209 (permalink)
Yes, the 2009 front spring is softer than the 2012 spring.
The rear springs 2009 and 2012 are the same.
Old 21st November 2018, 09:30 AM   #210 (permalink)
Black Friday and Cyber Monday Sale!
Entering into the Spirit of Black Friday deals, this definitely is the season for savings and what better way to celebrate by offering a 10% discount off ALL DSC Sport controllers this week till the end of Cyber Monday.
This special OFFER means that the UK delivered price for a DSC Sport controller is £900 + VAT.
This limited time offer ends Cyber Monday at 17:59PM UK time.
PM me, or get in touch through the website
Old 23rd November 2018, 09:31 AM   #211 (permalink)
herman is i cant believe my 32 is gone im gutted.
herman's Avatar
Dsc sport controller
I will have one these mate , All the reviews seems to suggest be stupid not to , and at a great price to . Please just pm me over payment details and I will sort out sending funds to you . Cheers Dave
herman is offline   Reply With Quote
Old 23rd November 2018, 12:53 PM   #212 (permalink)
Thanks Dave will send you a PM later today.
Hugh
Old 17th February 2019, 08:26 PM   #213 (permalink)
The subject of spring rates is one that routinely comes up when discussing how to set up the DSC Sport suspension maps.
The shocks on all year GTR's are the same except possibly the Litchfield offering.
I have collected pictures of the various year suspension over a period of time and wanted to share some details of the springs that Nissan have fitted over the years to assist with those discussions.
For those that track their cars, you will no doubt, be interested to see the Nismo 2015 suspension.
I am not aware of Nissan having disclosed the spring rates, however, I have it on good authority that they are 1120lb/in front / 600 lb/in rear.
Next we have the Spec R from Swift springs which I believe to be 1117 lb/in front / 615 lb/in rear, so are effectively the same rate as the Nismo, however, they have softer helper springs that will reduce the effect.
Next we have Litchfield that appear to me to be similar to the Nismo springs on the front and possibly the Spec R on the rear.
Next we have the 2009/2010 GTR that I have seen reported as
Front Spring Rate:
15.40 kg/mm (860 lb/in) max rate
14.28 kg/mm (800 lb/in) static
12.13 kg/mm (680 lb/in) average
Rear Spring Rate:
7.95 kg/mm (445 lb/in) max rate
6.93 kg/mm (390 lb/in) static
6.83 kg/mm (382 lb/in) average
Next we have the 2011 suspension
Now the 2014 suspension
Next 2015 suspension
Finally the 2017 suspension.
The moral of the above is that when you are planning lots of track work, you will be faster with the Nismo / Spec R /Litchfield or MY 2009 / 2010 suspension.
If you are planning a drag only car then something around the MY 2015 / MY 2017 may offer a good solution.
For comfort, there is no doubt that the later years suspension is much softer.
For any of you planning a DSC Sport suspension controller upgrade, I keep them in stock ready for your 2019 campaign.
Thanks
Hugh
misters3 and motors like this.
Old 16th May 2019, 02:33 PM   #214 (permalink)
herman's Avatar
Well finally got my eba and got john to install it as was up there anyway. This is an amazing bit of kit.. I must admit I did have my doubts that it would be as good as other people have said ,but how wrong was i
The DSC Sport controller is worth every penny, cheers HUGH
Hugh Keir – PTSYS likes this.
Old 21st May 2019, 05:06 AM   #215 (permalink)
Thanks Dave,
Your car sounds lovely.
Good to hear the DSC Sport suspension controller worked for you as planned.
Hugh
Old 21st May 2019, 10:14 AM   #216 (permalink)
herman's Avatar
CONROLLER
Mate it did exactly what you said it would, softer in comfort mode and then all firms up on r mode along with less roll and nose dive . Well impressed,cheers Hugh.
Old 6th June 2019, 07:46 PM   #217 (permalink)
Thanks Dave,
Great to hear you are enjoying the benefits of the DSC Sport controller.
DSC have just brought out a help video on the launch control settings that I wanted to share, to show how everything is set-up.
Note:- The simplest way to enable the GTR's launch control, is with the brake pedal pressed hard and the throttle pedal flat to the floor, the red LED on the suspension control button flashes to let you know your suspension is ready to launch.
Lift your foot off the brake pedal and let the magic happen.
Old 23rd July 2019, 11:55 AM   #218 (permalink)
siavash82ir is unaware they can edit their status
How do I go about buying and getting it fitted?
siavash82ir is offline   Reply With Quote
Old 23rd July 2019, 12:51 PM   #219 (permalink)
motors is unaware they can edit their status
motors's Avatar
Contact hugh he will program it. It’s easy to fit he supplies great clear instructions 15 mins work basically remove glove box
motors is offline   Reply With Quote
