Gear surround removal - r35 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree4Likes
  • 1 Post By charles charlie
  • 1 Post By vxrcymru
  • 2 Post By A1ex
Old 7th September 2016, 12:36 PM   #1 (permalink)
nick the tubman is feeling very pleased !
nick the tubman's Avatar
Cars owned: R35 GTR `10. R33 GTR v-spec Road & Track. R33 GTR Race Car
Greetings,
anyone know how to remove the gear surround panel. I have got the knob off, but cant figure out the surround.
wanting to fit my carbon panel
thanks
GTR = More smiles per mile, than any other...
nick the tubman is offline   Reply With Quote
Old 7th September 2016, 01:00 PM   #2 (permalink)
charles charlie's Avatar
You need to slide out the vertical silver bits either side of the AC controls then remove the large centre panel that covers your trans tunnel. That gives you access to info the gear surround. You'll need to undo two connectors one for the IGN switch, the other for the LED that lights the surround then unclip the surround
nick the tubman likes this.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
charles charlie is online now   Reply With Quote
Old 7th September 2016, 05:06 PM   #3 (permalink)
thanks CC> :-)
Old 22nd November 2016, 04:48 AM   #4 (permalink)
zhanpt is xxx
I can't slide out the silver pieces! Any technics?
zhanpt is offline   Reply With Quote
Old 22nd November 2016, 09:03 AM   #5 (permalink)
you need to remove the lower side panels first...
for them you have to use a screw driver (wrapped in a cloth to protect) and "pop" them out. where they meet the dvd panel..
Old 22nd November 2016, 12:32 PM   #6 (permalink)
zhanpt is xxx
Thank you very much
Old 22nd November 2016, 03:59 PM   #7 (permalink)
Tinyflier is Running ACSpeedtech forged engine,trans,exhaust
Cars owned: R35 (4.25) & Brabus ForFour
If you press (reasonably hard) your hand flat against the face of the silver panels and pull your hand back, they usually slide out far enough for you to get your fingertips into the inner edge and ease them out.
David
Tinyflier is offline   Reply With Quote
Old 22nd November 2016, 04:02 PM   #8 (permalink)
zhanpt is xxx
Thank you very much. It does come out***65281;***65281;***65281;
Old 26th November 2016, 07:27 AM   #9 (permalink)
vxrcymru is a carbon fetishist
GT-RDC Founder Member
vxrcymru's Avatar
Cars owned: R35 GTR Stage 5 & Evo X FQ400
Buy a set of plastic car trim removal tools for £10 from fleabay. Saves the risk of damaging trim with screwdrivers etc.
charles charlie likes this.
Black MY2010 Black Edition, Litchfield Stage 5 - Switzer P800 turbos, Litchfield suspension, Alcon 400mm front and 380mm back discs with Pagid pads, circlips, front and rear cameras, auto folding mirrors & lots of CF. Advan RSD wheels!
vxrcymru is offline   Reply With Quote
Old 26th November 2016, 02:19 PM   #10 (permalink)
zhanpt is xxx
cheers bro
Old 28th December 2017, 03:45 AM   #11 (permalink)
TurboSam is unaware they can edit their status
TurboSam's Avatar
My side panels are rock solid can't seem to budge them. Scared of braking something with the pressure I'm putting on them. I've seen a few video's of how it's done so I'm sure I have the right technique but.....
Sent from my HTC One M9 using Tapatalk
TurboSam is offline   Reply With Quote
Old 28th December 2017, 06:49 AM   #12 (permalink)
Secret is to start at the edge which rests against the CD panel and rock your trim removal tool. Then as the trim part moves forward, place the trim remover under the part by the R-R-R switchs/AC panel and rotate the trim tool again.
They will come.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 28th December 2017, 09:49 AM   #13 (permalink)
TurboSam's Avatar
Thanks mate I give that a try
Old 28th December 2017, 08:01 PM   #14 (permalink)
TurboSam's Avatar
It worked a treat thanks again.
Old 29th December 2017, 07:14 AM   #15 (permalink)
There you go.
I knew you could do it.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 29th December 2017, 10:44 AM   #16 (permalink)
TurboSam's Avatar
Yeah happy to rebuild and engine or gearbox but when it comes to internal plastic trims I'm scared to death.
Old 12th February 2019, 10:23 PM   #17 (permalink)
A1ex is unaware they can edit their status
Cars owned: Civic, Impreza, R35 GTR
Did not mean to drag up an old thread but I have a tip to share.
Generic cloth duct tape did not leave any residue or marks. Attach the end piece to the large flat surface of each side trim panel of the console. The roll can be used as a handle. Pull straight out.
Hugh Keir – PTSYS and SKNAM like this.
A1ex is offline   Reply With Quote
