HELP!!!! AWD, ABS and HICAS lights are on - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 22nd November 2016, 05:46 PM   #1 (permalink)
XashskylineX is rebuilding his dream BNR34
XashskylineX's Avatar
as above all 3 lights are on why??
there rear end isn't friendly either keeps spinning out to
i have checked the fuse under the steering wheel and by the battery they seem to be fine blended the fluid out to kept the battery disconnected 24 hours and still the same
would anyone know what would be wrong???
thanks
XashskylineX is offline   Reply With Quote
Old 24th November 2016, 10:41 PM   #2 (permalink)
GOGS 2 is unaware they can edit their status
GOGS 2's Avatar
Cars owned: R32 GTR & audi s3
There is a 4wd ecu in the boot of the r32 gtr that has a flashing red led the number of light flashes can be used to find a fault code. Not sure if the r34 gtr has this but worth a check
GOGS 2 is offline   Reply With Quote
Old 24th November 2016, 10:44 PM   #3 (permalink)
Owner of the MSNSPS
Cris's Avatar
Cars owned: BNR32, RGV, 330i
I would guess an earthing problem. I can only suggest looking for a wiring diagram to give you a clue where to start.
Old 24th November 2016, 10:47 PM   #4 (permalink)
Jayman is Owner of R34 GTR 720 hp
To check what has caused the fault, you can bridge two of the pins on the OBD port and it will flash the EML ( Engine management light) there are numerous threads on here that tell you what each flash of the EML mean.
If you have an R34 there is NO light in the boot on the HICAS ecu and you have to use the above method.
Have you moved your TPS lately? i found that if i moved that it messed up the signal on the ecu and threw up all the lights mentioned.
James
Jayman is offline   Reply With Quote
Old 25th November 2016, 12:55 AM   #5 (permalink)
sorry guys forgot to mention its BNR32
Theres no light flashing there!!
i think that can be the problem
James
the fault tbh can be any where as i have had the car totally strip and put back together
Old 26th November 2016, 02:08 AM   #6 (permalink)
PLUS
would this have anything with the power steering?
mine isn't working
Old 26th November 2016, 08:35 AM   #7 (permalink)
R32 Combat is in limbo
Skyline Section Manager
R32 Combat's Avatar
Cars owned: R33 GTR
The HICAS system also controls the speed related power steering.
Old 26th November 2016, 01:59 PM   #8 (permalink)
thanks combat.
guess i need to replace both ecu
Old 1st December 2016, 05:13 PM   #9 (permalink)
update
I have changed the ECU's still the same
Old 1st December 2016, 06:41 PM   #10 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
Std engine management ecu?
Old 1st December 2016, 06:45 PM   #11 (permalink)
yep
Old 1st December 2016, 06:46 PM   #12 (permalink)
yes everything standard
Old 1st December 2016, 06:50 PM   #13 (permalink)
AlexJ's Avatar
The ecu sends a tacho signal to the ets/abs ecu and the hivas ecu. You could scope the pins on the two ecus to check that is getting through.
Old 1st December 2016, 06:56 PM   #14 (permalink)
like how sorry how is that done
Old 1st December 2016, 08:10 PM   #15 (permalink)
AlexJ's Avatar
By checking the pinouts and probing the appropriate pins on the ecus (ECCS pin 7,ATTESA/ETS pin 31,HICAS pin 12) with a scope or multimeter - if there is no signal with the engine running then you need to trace back the break in the chain.
If everything is stock then you may find you can use a consult tool to read the errors.
It may well be an earth and you should check them, but with all the warning lights on and the car having been totally stripped and reassembled without getting elbows deep in the service manual and wiring diagrams you are just taking shots in the dark I suspect.
