Possible causes of oil in coolant - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree1Likes
  • 1 Post By Jags
Old 7th January 2017, 07:08 PM   #1 (permalink)
tomg89 is unaware they can edit their status
Hey all. Having problems with a friends GTR R32.
Car was imported from Japan, very quickly after little use it was clear to see it was using a lot of oil. No smoke, engine runs perfectly. After further inspection it was obvious the oil was mixing with the coolant.
Firstly we replaced the standard oil filter housing/oil cooler with filter relocation and front mounted oil cooler. Hoping the stock oil cooler could have been at fault, but the fault still remains.
Today I pulled the engine and removed the head hoping to see some obvious signs of headgasket failure. Found it did have a metal headgasket fitted. No obvious signs of a fault.
I shall send the head away to be pressure tested on Monday.
Has anyone had this issue before? Anything else I should be looking out for?
I can see myself doing all this work, new headgasket etc, to find it's still the same.
Any help will be greatly appreciated.
Thanks
Tom
tomg89 is offline   Reply With Quote
Old 7th January 2017, 07:21 PM   #2 (permalink)
Jags is unaware they can edit their status
Jags's Avatar
Wait for the pressure test results to come back. I have a sneaky suspicion the head my be cracked
If it is, there's a mod that is done where the head's welded up and an external oil gallery is made on the back of the head
samgtr likes this.
We produced with spartan air
Old 7th January 2017, 07:23 PM   #3 (permalink)
needforspeed is on the hunt for parts
needforspeed's Avatar
I had a similar situation with my old R33 GTR. It was the head gasket and the engine needed a complete rebuild. I hope you have better luck!
needforspeed is offline   Reply With Quote
Old 7th January 2017, 07:36 PM   #4 (permalink)
Thanks, yea I'm hoping to find the fault before just rebuilding it. I'm worried if there's a small crack in the head that it may only be an issue when hot, therefore won't show on a pressure test.
Old 7th January 2017, 07:51 PM   #5 (permalink)
R32 Combat is in limbo
Skyline Section Manager
R32 Combat's Avatar
Cars owned: R33 GTR
It's not unheard of for heads to crack and oil get into the water.
Old 20th January 2017, 04:44 PM   #6 (permalink)
Just heard from the machine shop. Head passed a pressure test, so looks like the heads ok. Abit stumped now as to what to check next.
Any ideas?
Thanks
Old 20th January 2017, 04:46 PM   #7 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
Any ideas?
Thanks
Was it pressure tested at operating temp?
Old 20th January 2017, 04:48 PM   #8 (permalink)
That was my other thought, I don't think it was. So I'm still not 100% convinced that the head is ok. But the machine shop guy seemed to be sure it was ok.
