VSS sensor - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 31st January 2017, 07:23 AM   #1 (permalink)
angrychicken is unaware they can edit their status
angrychicken's Avatar
VSS sensor
Hello!
I have a question regarding my 90 r32 gtr. My car recently came back from a tuner and a glitch was found. They stated I might have a bad VSS, apparently they thought it was sending an intermittent reading to the ECU that was different than the cable speed cable. Thus effecting the tune (AEM V2).
Being from the USA, info is limited here. A brief search didn't find anything.
I'd appreciate some guidance in where it is located. And if there is an equivalent sensor that I can find stateside, part number, etc.
Thanks in advance!
angrychicken is offline   Reply With Quote
Old 31st January 2017, 07:35 AM   #2 (permalink)
GT-R David is BNR32 Owner
GT-R David's Avatar
The speed signal for the ECU is generated in the speedo itself.
GT-R David is offline   Reply With Quote
Old 31st January 2017, 08:05 AM   #3 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
Swap out the clocks or just the speedo. It is a fairly common fault, my VSS signal is garbage but its not used by the ecu and i have no attesa on my car so it doesnt really efffect anything. you may be able to clean it up by changing the detection in AEM; falling edge vs rising edge, smoothing etc.
Also be aware the VSS signal is fed to attesa and might cause it to throw a warning light or behave unpredictably.
Wonder what VSS is being used for in the AEM?
Old 31st January 2017, 08:50 AM   #4 (permalink)
Sorry for the neb questions.
So the sensor is the gauge cluster and attaches to the speed cable itself?
VSS was being used for launch control. Tuner said that while testing, once it sent the wrong speed to the ECU while doing a pull in 3rd gear. Basically causing a cut and the car fell on it's face. So they deleted the launch control. But they think it might be affected other parts of the tune as well.
Old 31st January 2017, 02:03 PM   #5 (permalink)
AlexJ's Avatar
Yeah the speedo cable goes into the back of the cluster and into the speedo head unit itself, and the speedo mechanism has a sensor in there and a chip to turn that into pulses which go to the ecu.
Old 31st January 2017, 02:47 PM   #6 (permalink)
Owner of the MSNSPS
Cris's Avatar
Cars owned: BNR32, RGV, 330i
Random thought - if the cluster is producing a bad signal you could think about fitting the speed sensor from an R33.
I don't know if the output from the R33 sensor is directly compatible but it might be an easy solution
Old 31st January 2017, 03:23 PM   #7 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Originally Posted by angrychicken View Post
Hello!
Thanks in advance!
Make sure you select from the ECU software the right parameters. Choose sensor type: hall effect , edge: falling with pull up enabled.
Your issue sounds like your using reluctor type sensor and possibly rising edge.
Old 31st January 2017, 05:24 PM   #8 (permalink)
Thanks for the responses!
Anyone have a part number for the sensor?
Or is there an equivalent sensor in other Nissans that can be used?
And FRRACER, I'll bring that up with the tuner when it goes back.
The are pretty well versed with AEM, but not with my car.
