R32 GTR Headlight Rewire Harness - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree15Likes
Old 31st January 2017, 05:51 PM   #1 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Having burnt out the light switch on my R32 (very common on R32s) I decided to make up a new harness that not only feeds the current via relays but also replacing the headlight harness also. Another bonus is that when pulling the main beams the low beams will remain on. Voltage drop from the battery to the bulb was some 1.4 volts on the driver side and 1.5 on the passenger side. Voltage vs Lumens is exponential so that amount of voltage loss results in less light being out to the road.
First step was looking at various ways at making up a harness - the R32 setup is rather confusing so took a while to figure it out and have a clear design that worked. There were some diagrams out there which were complex so was better to start from scratch in some ways.
Only 3 wires require cutting and joining up to existing wires at the switch side for the signal from the switch and an earth. An extra ring terminal earth is fastened to the chassis and a positive to the battery terminal. Over the next few posts I'll get some more pictures up.
Burnt out harness was cut and replaced with a fresh connector and length of wiring.
New power harness for the headlights.
Old 1st February 2017, 10:02 AM   #2 (permalink)
habu32 is ready to strike
Cars owned: 1993 Nissan Skyline GT-R
Yeah, saw this on your Facebook page, still interested in this! Looks like a good fix to a simple problem. I'm surprised Nissan never had any kind of TSB/Recall about this. Not sure if my car is having the issue or not, maybe it's just starting. Was fine for a year, then the last 6 months or so, turn the switch, headlights come on but no dash/radio/etc lights and no tail or license plate lights.
But, if I keep the switch on and push the fog light switch, everything works. Weird! Might be something simple, haven't looked into it yet, but either way, like the idea of this kit.
habu32 is offline   Reply With Quote
Old 3rd February 2017, 11:07 AM   #3 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
You have the same issue I did. It's the switch contacts that have burnt out. I tried to repair worked a few weeks and back to normal. Also check for melted plug. In the end I bought a new switch.
Old 3rd February 2017, 11:28 AM   #4 (permalink)
jnoor is told I am addicted to this site
jnoor's Avatar
Sorry for the confusion but isn't this the same kit as Supertecs???
jnoor is offline   Reply With Quote
Old 3rd February 2017, 11:54 AM   #5 (permalink)
Rich_A is piston broke.
Rich_A's Avatar
Cars owned: R32 GTR, 300Tdi Disco.
Looks good, are you going to sell them Yunis?
My BNR32 Project Thread:
Rich_A is offline   Reply With Quote
Old 3rd February 2017, 01:21 PM   #6 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Yes it is identical
Old 3rd February 2017, 01:22 PM   #7 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Just doing a few weeks testing and they will be for sale. Two versions, one will be connected up at the steering column other will be a shorter harness that will be connected to the wiring close to the fusebox/battery.
Old 3rd February 2017, 06:39 PM   #8 (permalink)
OXzilla is unaware they can edit their status
OXzilla's Avatar
Just looking for some clarification...
So will the power harness kit also include a repair for the headlight switch plug? Or do I need the power harness in addition to the switch plug?
Just curious if the kit is going to be inclusive
Edit... I read my post and realised it sounded as if English was my 3rd language
OXzilla is offline   Reply With Quote
Old 3rd February 2017, 09:02 PM   #9 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
So on the headlight itself you have a small harness that is fixed to the unit. My kit will be complete excluding that short harness, however upon request I could make it if needed.
Old 3rd February 2017, 09:05 PM   #10 (permalink)
OXzilla's Avatar
Sorry, not on the headlight, the plug that usually melts up at the switch
Old 6th February 2017, 12:10 PM   #11 (permalink)
yeah that's my concern too. i would think a new harness piece is needed (the connector with yellow wires you posted) and then the harness kit to make the power run through relays and not through the switch.
my other concern is, having both the low beams and high beams on at the same time, will that cause any issues with those running non-projector headlights? i have projector lights at the moment, but will be switching to non-projectors in the near future.
wish you were in japan, i'd love to do testing on this, as like you said, it's probably my problem.
Old 6th February 2017, 10:54 PM   #12 (permalink)
Sub Boy is a nana driver
Sub Boy's Avatar
Would be keen on one of these when you make them, with the one that connects to the fuse box in the bonnet does it have any wires running back into the the car or is all in the engine bay?
Old 7th February 2017, 07:03 AM   #13 (permalink)
border1 is unaware they can edit their status. Or is he?
border1's Avatar
Cars owned: '90 R32 GTR, R27 Clio F1
Nice idea this, I hate the thought of the full feed sitting through that dash switch all the time!
I'm interested in the version that sits in the bay - presumably you fit that into the existing wiring in series to divert the existing feed so it only switches the relays, then add a direct feed to the relays which then goes into the headlights?
border1 is offline   Reply With Quote
Old 7th February 2017, 12:48 PM   #14 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Correct if you do not want to cut wires in the engine bay near the fuse box you can run the longer length wires through the gromet under the arch liner and direct to under the steering column and splice into the switch. Just preference really.
border1 likes this.
Old 7th February 2017, 12:49 PM   #15 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Shorter harness kit doesn't need to run into the cabin.
Sub Boy likes this.
Old 7th February 2017, 12:50 PM   #16 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Both low and high beams running will not cause issues with this mod as power goes to the relay not the switch.
Sub Boy likes this.
Old 8th February 2017, 08:30 AM   #17 (permalink)
border1's Avatar
Where are you mounting the new relays in the bay?
Old 8th February 2017, 08:01 PM   #18 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Yes relays in engine bay close to battery.
Old 17th February 2017, 07:08 PM   #19 (permalink)
Silverhks is unaware they can edit their status
Color me interested.
I would need to talk about the sub harness on the lights as well.
Silverhks is offline   Reply With Quote
Old 18th February 2017, 09:36 AM   #20 (permalink)
GTES-t is getting ready to move
GTES-t's Avatar
Cars owned: R32 GTE>S-t
I'm looking forward to the engine bay shorter kit! I'm about to jump into bi-xenon projector mod for the R32 along with converting the old high beam to xenon as well and definitely could use this harness!
"That can't be a Skyline! It's got four doors!"
Old missed
Project in storage
The beast
Back in a
GTES-t is offline   Reply With Quote
