Can anyone Help? r35 gtr engine locking - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree1Likes
Old 26th February 2017, 07:53 PM   #1 (permalink)
GTRnutjon is unaware they can edit their status
Hi I've got a r35 gtr other day it cut out on me and wouldn't turn over then it started for a few seconds then cut out again, took spark plugs out and turned by hand the engine is locking but not seized also no knocking when it started briefly, I was wondering if anything starter or transmission could cause this also had bell house rattling issue if that makes any difference any help would be appreciated
GTRnutjon is offline   Reply With Quote
Old 26th February 2017, 09:44 PM   #2 (permalink)
Teaboy is Making tea and taking names
Is the car stock or tuned?
If tuned then to what level?
How many miles are on the car?
What where you doing before the engine cut out ie general driving, spirited driving or giving it a proper kicking?
I take it when you say it locks up but not sized dose it come to a dead stop or you encounter lots of residence?
Will the engine then turn backwards and free off?
What is the engine oil level and coolant level like?
Are you sure the was no out of the ordinary sounds when it ran briefly?
Teaboy is offline   Reply With Quote
Old 27th February 2017, 07:38 AM   #3 (permalink)
charles charlie's Avatar
Impossible to diagnose from such limited info.
First thing to do is read any DTC codes.
My initial thought would be a fuelling issue.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 27th February 2017, 09:54 AM   #4 (permalink)
Takamo is Living the Dream... Alhumdulillah (thanks to God)
GTR Register Trader
Takamo's Avatar
Cars owned: R32 GTR, R33 GTR, R34 GTR, R35 GTR and many many more!!!
As said by Charles, I'd be reluctant to try and turn it over if it's locking up, you may do more damage
Rabs Car Alarms 0121 771 1511 or 07973733441
Facebook:
Official Dealers of:
Autowatch Ghost Immobiliser
Smartrack Trackers, Toad, Scorpion & Blackvue
Takamo is offline   Reply With Quote
Old 27th February 2017, 10:02 AM   #5 (permalink)
Thanks guys no it's standard 60k miles and I was in 2nd gear going around 40mph, and no starage noises when it ran, it will free off if I go backwards and then come to a stop again when I go forward, I've got 2 computers but they don't talk to the car I will get it booked in somewhere at some point as i can see it's going to be quite serious.
Old 27th February 2017, 10:36 AM   #6 (permalink)
dudersvr is A Legend
dudersvr's Avatar
If the engine didnt make any noises it could be something in the drivetrain, have you tried disconnecting the prop and seeing if it turns over by hand? But it can also be something in the bellhousing.
Old 27th February 2017, 10:38 AM   #7 (permalink)
Sounds odd, almost sounds like the Diffs have wound up.
Old 27th February 2017, 10:46 AM   #8 (permalink)
dudersvr's Avatar
Or something come apart in bellhousing
Old 27th February 2017, 11:00 AM   #9 (permalink)
yeah possibly, seems odd it will go backwards and not forward, meh I'm no techy
Old 27th February 2017, 11:14 AM   #10 (permalink)
terry lloyd is ........
terry lloyd's Avatar
OP says he is turning it by hand ? sounds like something is broke in the engine if it wont turn a full cycle without locking
Old 27th February 2017, 12:42 PM   #11 (permalink)
55chev is The only true wisdom is in knowing you knownothing my17 Kuro Black 4.25
55chev's Avatar
Could be a thousand and one things,process of elimination,first id look at the data,then id remove oil filter and cut it open,if anything has gone wrong in the motor there will be signs in that filter,if engine doesn't turn by hand,then remove prop,to discount trans and diff,then work forward,i deffo would not be trying to start the motor.best of luck,hope its something easy..
55chev is offline   Reply With Quote
Old 27th February 2017, 03:32 PM   #12 (permalink)
GTR Register Trader
Takamo's Avatar
Sounds like your timing chain may have slipped which would cause the symptoms.... Hope I'm wrong and it's something minor.
Facebook:
Old 27th February 2017, 05:30 PM   #13 (permalink)
Thank you everyone, I think I will inspect the oil filter and also I will remove prop no harm In me doing that I suppose just want to know as I can't stop thinking about it haha, is the prob a straight forward job to disconnect?
Old 27th February 2017, 05:39 PM   #14 (permalink)
GTR Register Trader
Takamo's Avatar
The prop is an easy job but if you turn it over and it locks up again you might cause more damage, I'd get a professional opinion rather than risk it going bang, has the timing chain ever been changed do you know?
Facebook:
Old 27th February 2017, 05:45 PM   #15 (permalink)
This is a video of my trying to start it before I was told not to, you can see it start then cuts out that's obviously when it locks up, https://youtu.be/TFvYirZa6Aw
Old 27th February 2017, 05:51 PM   #16 (permalink)
No I won't turn it over again and timing chain has never been done, I took the spark plugs out and Inlet manifold I can see the valves they look straight but I'm not a expert
Old 27th February 2017, 06:09 PM   #17 (permalink)
motors is unaware they can edit their status
motors's Avatar
Think you are best to get car recovered and get a specialist to look at car to avid further damage.
Takamo likes this.
motors is offline   Reply With Quote
Old 27th February 2017, 06:41 PM   #18 (permalink)
GTR Register Trader
Takamo's Avatar
That sounds like cylinder lock which can be caused by the timing chain slip... Don't turn it over you will knacker it completely.
Facebook:
Old 27th February 2017, 07:23 PM   #19 (permalink)
dudersvr's Avatar
Drain the oil, remove the sump and see if any debris in there, you can even pull a rod cap off and check bearings
Old 27th February 2017, 07:24 PM   #20 (permalink)
dudersvr's Avatar
If it ran like that and stopped while running it already has bent valves etc
