Time for a new engine! - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree70Likes
Old 1st March 2017, 11:03 PM   #1 (permalink)
bigal23 is a big ginger mess
bigal23's Avatar
So as you may have seen on here my engine decided to pooh itself and spin a couple of bearings.
After a little contemplation I've decided to rebuild the engine and some shiny new parts were delivered today!
Rich_A, V-SpecII, Manzgtr and 4 others like this.
bigal23 is offline   Reply With Quote
Old 2nd March 2017, 12:46 PM   #2 (permalink)
integra is unaware they can edit their status
Nice!
Are you using standard oil pump or spline drive etc?
integra is offline   Reply With Quote
Old 2nd March 2017, 01:23 PM   #3 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
That part number is the N1 pump.
bigal23 likes this.
Old 2nd March 2017, 01:26 PM   #4 (permalink)
Ok cheers.
Didnt have time to search.
Old 2nd March 2017, 02:12 PM   #5 (permalink)
bigal23's Avatar
Originally Posted by integra View Post
Nice!
N1 pump as Alex says, I think the 24U code depicts N1 on any part numbers.
N1 water pump is on its way too.
Rods are Bridgeway I beams with ARP bolts.
All being balanced properly before assembly.
Turbos are currently being stripped and rebuilt/rebalanced by Turbo Dynamics, block is being cleaned up and rebored for the 87mm pistons and the head is being stripped for a refresh and rebuild too.
Old 2nd March 2017, 02:19 PM   #6 (permalink)
bigal23's Avatar
Just need to sort gaskets now, will probably get a full engine kit.
I have been looking at the Nismo kit with the 1.2mm metal head gasket although we think we would prefer the 0.9mm Nismo metal gasket but it seems to only be available separately...
Old 2nd March 2017, 02:37 PM   #7 (permalink)
Saifskyline is unaware they can edit their status
Saifskyline's Avatar
Cars owned: R33 GTR V-Spec
Excellent choice of parts, the Fluidampr is a winner!
bigal23 likes this.
Saifskyline is offline   Reply With Quote
Old 2nd March 2017, 02:45 PM   #8 (permalink)
bigal23's Avatar
Yeah I did look at the ATI harmonic but a good friend of mine runs the Fluidampr on his Time Attack Evo's so that was good enough for me.
Saifskyline likes this.
Old 2nd March 2017, 03:08 PM   #9 (permalink)
If you still can then I would switch the ACL bearings for KING.
Old 2nd March 2017, 04:19 PM   #10 (permalink)
Rich_A is piston broke.
Rich_A's Avatar
Cars owned: R32 GTR, 300Tdi Disco.
Looking good mate. I have a similar pile of parts to sort out.
Where did you get the crank from if you don't mind me asking? I have found a few in the UK at £975ish, but some cheaper in the USA. Currently have one on back order from FRSport for way less than that.
Keep the pics coming.
My BNR32 Project Thread:
Rich_A is offline   Reply With Quote
Old 2nd March 2017, 04:20 PM   #11 (permalink)
Rich_A's Avatar
PS - not sure if it helps, but I went for a full gasket set, and purchased a Tomei head gasket kit, as this comes with not along the HG, but metal inlet and exhaust gaskets and oil restriction widget.
Old 2nd March 2017, 07:42 PM   #12 (permalink)
bigal23's Avatar
I got the crank plus both N1 oil and water pumps through Nissan, I work in the motor trade so I did get a good deal to be fair.
Crank was in stock in Holland and was delivered in under a week.
Yeah I was going to get the Tomei oil restrictor too as you can purchase them on their own.
Been trying to sort the Nismo kits through Nissan but for some reason the part numbers don't bring anything up and they can't seem to find anything listed so not sure if they are discontinued now.
RHD Japan still list them as per my screen shots above but maybe they just have some stock left
Rich_A likes this.
Old 3rd March 2017, 04:33 AM   #13 (permalink)
BigKriss is Cruiz`n a little..
Gees guys...make the oil restrictors yourselves ...? Imagine walking around saying "I have bigal23 restrictors in my motor".....:-)
bigal23 likes this.
BigKriss is offline   Reply With Quote
Old 3rd March 2017, 11:37 AM   #14 (permalink)
bigal23's Avatar
To be fair they are quite expensive
Old 8th March 2017, 10:03 AM   #15 (permalink)
bigal23's Avatar
Rod bearings and main studs delivered yesterday!
Just need to sort the gasket kit now...
Old 13th March 2017, 01:47 PM   #16 (permalink)
bigal23's Avatar
Water pump just delivered, turbos are back now after a rebuild too.
Gasket kit should be here later this week...
Old 14th April 2017, 11:16 PM   #17 (permalink)
bigal23's Avatar
Thought I'd clean the engine bay up whilst it's looking pretty bare...
saucyboy likes this.
Old 14th April 2017, 11:18 PM   #18 (permalink)
bigal23's Avatar
OEM gasket kit has finally arrived!
Got some more parts on the way too.
Old 15th April 2017, 01:07 AM   #19 (permalink)
Sub Boy is a nana driver
Sub Boy's Avatar
Just be sure to put lots of sealant around the slot in the N1 water pump, they are prone to leaking as the sealing gap is small due to the slot.
I welded up the slot and re-drilled it the suit the block to avoid it.
Old 28th May 2017, 09:51 AM   #20 (permalink)
bigal23's Avatar
Few more Nismo goodies en route from Japan and the build can finally commence!
It's been so annoying driving around in all this nice weather just wishing I was back behind the wheel of the GTR again...
V-SpecII and OXzilla like this.
