Stage 2 to stage 4.25 - is it worth it? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree20Likes
Old 22nd March 2017, 08:21 AM   #1 (permalink)
jrattan is currently Stage 1 My11
jrattan's Avatar
I'm currently running a stage 2 with downpipes. It will cost me around £1800 to go to stage 4.25.
I know there's plenty of talk on the forum about the stages and I'm fairly aware of what it involves. I thought I'd post to get some opinions as I'm in two minds about.
My question is, is it worth from a power perspective and financial?
I don't track the car, only use it for spirited driving so never really hit those tops speeds (of 70mph ) for that long.
jrattan is offline   Reply With Quote
Old 22nd March 2017, 08:42 AM   #2 (permalink)
charles charlie's Avatar
Imho yes it is. 4.25 is the sweet spot. Bear in mind that downpipes increase exhaust loudness depending on your y-pipe and back box combo.
I chose to have a new exhaust to quite the car down with downpipes as it was just too loud for me but plenty of folks are happy with that increase in sound.
jrattan likes this.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 22nd March 2017, 08:44 AM   #3 (permalink)
jrattan's Avatar
I have boost logic downpipes and a Linney Street Titan exhaust system and titan Y pipe FYI
Not to be pedantic but what makes it sweet spot? Is it the acceleration at higher speeds or does it already increase the torque at lower speeds to a noticeable amount?
Old 22nd March 2017, 08:54 AM   #4 (permalink)
If you have downpipes I'd be concerned about running lean on the stock injectors anyway so adding bigger ones gives your tune safety.
Your tuner can then alter your map to provide more BHP across the whole rev range whilst reducing timing to cap the torque to a safer level.
Without bigger intakes you're also not benefitting from the extra gas flow the downpipes allow.
Earlier turbo spool means more response to throttle inputs as well as more power under foot.
You'll notice the difference straight away.
I call it the sweet spot as it frees the engine from gas flow restrictions whilst improving throttle response and power in any gear. It's the stock engine in its best form removed of the restrictions placed upon it by emission regs etc.
Chronos and jrattan like this.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 22nd March 2017, 08:55 AM   #5 (permalink)
james_barker is unaware they can edit their status
Think Charlie means taking into account increase in power vs amount of money required to achieve it. Also, 4.25 is the limit for much of the stock internals before you start to significantly increase the risk of failure.
Sent from my SM-T813 using Tapatalk
charles charlie likes this.
james_barker is offline   Reply With Quote
Old 22nd March 2017, 09:07 AM   #6 (permalink)
Spot on.
Stage 2 always seemed to me to be a bit of a waste of money to me especially if you've spent quite a bit adding downpipes.
I'd have gone stage 4 before downpipes (it's actually what I did) as the other bits (intakes injectors new map) add more for only a little more expense.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 22nd March 2017, 09:17 AM   #7 (permalink)
Also £1800 seems a little high?
Injector Dynamics 1000cc are £600 ish.
Larger intakes and filters £400 ish
£800 labour is way over for how easy the above are to fit.
I haven't taken into account tuning costs but maybe £300?
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 22nd March 2017, 09:20 AM   #8 (permalink)
jrattan's Avatar
http://www.litchfieldimports.co.uk/C...ing_matrix.pdf
Spoke to Sly at my servicing on the weekend and he confirmed it too. Hence why not sure really
Old 22nd March 2017, 09:25 AM   #9 (permalink)
I suppose labour costs for you Southerners is higher than for us Northern monkeys.
Regardless of a few hundred quid difference it's well worth it anyway.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 22nd March 2017, 09:35 AM   #10 (permalink)
terry lloyd is ........
terry lloyd's Avatar
Fcuk me them prices are crazy £1100 for a stage 1 ( remap ) on topic i noticed a big difference stage 2 to 4 well worth it in performance gains, you have to be a bit more careful coming out of roundabouts etc stage 2 you could just floor it stage 4 you can light up the tyres quite easy
Old 22nd March 2017, 10:23 AM   #11 (permalink)
55chev is The only true wisdom is in knowing you knownothing my17 Kuro Black 4.25
55chev's Avatar
4.25 all day long.
Chronos likes this.
55chev is offline   Reply With Quote
Old 22nd March 2017, 10:47 AM   #12 (permalink)
roscop123 is unaware they can edit their status
Im currently at stage 4 going in monday for new.asnu 1100cc injectors and a fresh remap...for some reason the previous owner done all the work but not the injectors ! Baffled at that one...
roscop123 is offline   Reply With Quote
Old 22nd March 2017, 10:49 AM   #13 (permalink)
That is an odd one.
Really risking going lean on stock injectors and bigger intakes.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 22nd March 2017, 10:51 AM   #14 (permalink)
Originally Posted by charles charlie View Post
That is an odd one.
Very weird had at 600 package and down pipes but kept stock injectors ...tuner had never seen that before usually other way around ? Injectors then dow pipes if not done when exhaust fitted...
Old 22nd March 2017, 11:49 AM   #15 (permalink)
The new COBB Stage 2 maps have calibrations for big intakes on stock injectors
Old 22nd March 2017, 12:06 PM   #16 (permalink)
Joni P. is unaware they can edit their status
Joni P.'s Avatar
Cars owned: R35 GT-R, Nismo 400R, Corvette Stingray, B324R 1JZ, Silvia convertible, BMW Alpina B10 2JZ, BMW 328 Convertible 2JZ
- Bosch EV14 1000cc injectors cost me £416 /set,
- 3" SS intakes self-made + filters £130,
- custom remapping £400
£946 in total and installation/fabrication took about 2-3hours in total.
a car without a charger is like sex without a partner.
Joni P. is offline   Reply With Quote
Old 22nd March 2017, 12:09 PM   #17 (permalink)
R35 Section manager
TREG's Avatar
Cars owned: R 35 GTR
For road use no.
Mines a stage 2 and on the various road trip meets my car has kept up with the stage 4's and 4.25.
For track use yes and if you have £1800 then go for it but do you need it?
Old 22nd March 2017, 12:32 PM   #18 (permalink)
Originally Posted by TREG View Post
For road use no.
By the same token, for road use you don't even need a stage 2 then.
Old 22nd March 2017, 12:36 PM   #19 (permalink)
R35 Section manager
TREG's Avatar
Wink
There's actually some truth in that although the stage 2 is almost to easy to get to as most owners want an exhaust change.
Old 22nd March 2017, 12:43 PM   #20 (permalink)
jrattan's Avatar
For road use we should all buy electric self driving cars
You're right TREG I don't need it and I'm 50/50 about upgrading so just wanted the view of other enthusiasts it's been useful so far...
