Thanks for the iso's. I'm getting the same error. I have another java executable that I can just double click on & it opens - I take it there is no way to make it that easy?
Hi there - I've only had my 11 plate for around a week and would be keen to do this update.
I have downloaded all the ISO files and pretty sure I can burn these to disc but not so sure what I do with the mugi files. Any advice? I run a mac if that's of any relevance? Thanks, |
The reason im getting R35 Audio to do it is that you are all speaking Latvian as far as im concerned LOL
Sorry, I have the same problem, appreciate your advice... I originally circulated the first set of discs, was easier then ! |
Its out in the open now so fsck it
$ java -jar ./Mugi.jar 10123545678901234567890123456789 << this is the first disk dvd key 10123545678901234567890123456789 <<<< unit id padded with four byte on the end add 2 on the end to generate two license keys 449A65D5B8A6883E 0092AE9E0F16961C 2 NUMBERS: 1 ms 2 exampls $ java -jar ./Mugi.jar 10123545678901234567890123456789 10123545678901234567890123456789 2 449A65D5B8A6883E 0092AE9E0F16961C 2 NUMBERS: 1 ms 2 |
449A65D5B8A6883E 0092AE9E0F16961C If so :thumbsup::clap: |
Also each DVD key is different depending on what version you have. |
Thanks for your advice :thumbsup: |
Sorry to be a pain but where is the DVD key - does it show on the display or is it in one of the iso's.
System disc is updated & working fine Thanks for your help!!:thumbsup: |
The Unit ID is 10 digits long. You don't include the hyphen. Thanks to shavermcspud I have this license generation software working but sadly none of the activation keys it generates seem valid. |
The 2017 Head unit upgrade can be applied to a MY12, yes?
This stuff costs £150 from Nissan normally. |
:thumbsup: |
Seems to be compatible with MY2009 cars onwards. Details here Connect Premium (X9) - Europe V5 | HERE |
Still no luck even with the md5 as the DVD key so if that is the correct key it must be something to do with the unit ID if it has worked in the past. still at least we got the system disc to load so not all bad
Fantastic work shavermcspud,
It would be great if someone who has successfully made this system work, could write an idiots guide to show all steps, including which files to burn and which order to use the discs and exactly how to use Java if you have never done this before. It seems many have not been successful, is this because they are unfamiliar with the process so far described. I have never used Java, so it is very unfamiliar to me and no idea how to do this. Thanks Hugh |
vBulletin Security provided by
vBSecurity v2.2.2 (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
