Stage 1 to 4.25? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree7Likes
Old 6th May 2017, 05:11 PM   #1 (permalink)
Smileygtr is unaware they can edit their status
Stage 1 to 4.25?
Currently on stage 1 litchfield but want to go to 4.25..
Am i right in thinkin i only need downpipes and my y pipe and injectors and intakes??
As been told rear section of exhaust is good for upto 750 bhp!!
Or do i need some sort of 4" rear section aswell?
Andy
Smileygtr is offline   Reply With Quote
Old 6th May 2017, 06:18 PM   #2 (permalink)
NELLEE is Attracted to women half his age and half is weight!
NELLEE's Avatar
I went stage 4 with a standard rear section no problems
NELLEE is offline   Reply With Quote
Old 6th May 2017, 07:17 PM   #3 (permalink)
dudersvr is A Legend
dudersvr's Avatar
Go 4.26 !!!!!
e8_pack likes this.
Old 6th May 2017, 09:12 PM   #4 (permalink)
e8_pack is Chav Hunter
Registered User
Originally Posted by dudersvr View Post
Go 4.26 !!!!!
That would require a Litchfield shoe shiner conversion. £5856.86.
Stealth69 likes this.
e8_pack is offline   Reply With Quote
Old 6th May 2017, 09:20 PM   #5 (permalink)
Anyone got any proper advice?
Old 6th May 2017, 09:29 PM   #6 (permalink)
Don't need rear section, the std one is perfectly adequate.
The show shiner is a waste of time, you won't be able to afford shoes once you start modding this car
Old 6th May 2017, 09:30 PM   #7 (permalink)
Who needs shoes lol
Old 6th May 2017, 09:43 PM   #8 (permalink)
TAZZMAXX is ...............
ADMIN
TAZZMAXX's Avatar
On this forum?
Old 7th May 2017, 01:52 PM   #9 (permalink)
dudersvr's Avatar
Well Litchfield list exhaust as stage 4 and downpipes at 4.25 but my friend has over 700hp with pipe DP and stock back box and the noise isnt too loud for track days if you want to do them.
Add air freshner fro 4.27
Old 7th May 2017, 02:08 PM   #10 (permalink)
Add a shit ton of carbon and you gain at least 222bhp, E8 plans to do this
I run a stick back back box at stage 4.25 and it's as quick as any other 4.25 car with a brain shattering exhaust
Old 7th May 2017, 05:24 PM   #11 (permalink)
Registered User
I'm at 4.25 but plan to go rods and pistons. Problem is, it still limits you to around 600tq due to the gearbox gear sets.
I don't want to be getting into box Upgrades so I'm not sure now. But I've seen way too many rods through the block to not want then doing, even at stage 4.
Old 7th May 2017, 05:33 PM   #12 (permalink)
dudersvr's Avatar
Im fitting extreme 18 plate clutch and will run 750 ft lbs till the box is built
Old 7th May 2017, 05:39 PM   #13 (permalink)
Just do the upgrade and then deal with the box as and when it breaks, it's not like when the engine shits itself
dudersvr likes this.
Old 7th May 2017, 06:39 PM   #14 (permalink)
Registered User
I think I will upgrade the engine anyway, just waiting on a few more quotes.
Old 7th May 2017, 07:56 PM   #15 (permalink)
Chris**** is hiding
Chris****'s Avatar
Is the exhaust perfectly capable then? As seen litchfield even on stage 2 say about a milltek rear box and air filters. No need i take it?
Chris**** is offline   Reply With Quote
Old 7th May 2017, 07:57 PM   #16 (permalink)
dudersvr's Avatar
My pal is stage 4.5 and no problems.
Chris**** likes this.
Old 7th May 2017, 08:03 PM   #17 (permalink)
Stock system will work.
You can always make the same power by upping the boost slightly.
Purpose of aftermarket exhaust is to improve volumetric efficiency which means you can make the same power at lower boost or more power at the same boost as a less efficient car.
Old 7th May 2017, 08:05 PM   #18 (permalink)
terry lloyd is ........
terry lloyd's Avatar
Would be good to hear a tuners opinion - you may not see a out right power gain but you may see gains in different parts of a dyno graph - the oem is quite small bore 2.75" from Y pipe back to the divider section , this link is worth a look at
DIY700 - 700hp on a Budget - Page 4 - R35 GT-R - GT-R Life
Old 7th May 2017, 08:14 PM   #19 (permalink)
Thats fine but @ 5300rpm you cannot make more boost the wastegates are at 100% duty on stock turbos
Old 7th May 2017, 08:40 PM   #20 (permalink)
Jesus - same thing has been said many times on this thread....... yes the standard back box is fine and hardly restrictive.
