-   -   Has ANYONE damaged their turbos/engine doing pops+bangs / Godzilla mode(ecutek)? (https://www.gtr.co.uk/forum/513329-has-anyone-damaged-their-turbos-engine-doing-pops-bangs-godzilla-mode-ecutek.html)
Chronos 17th May 2017 01:53 PM
Hi GT-r fans,
Has ANYONE damaged their turbos/engine doing pops+bangs / Godzilla mode(Ecutek)?
I've had discussions on it, most people are of the idea that it can/will/is damaging turbos/engines etc.. with the heat generated when static doing it, and even when driving and so on.. But I've not heard of anyone who has actually broken something doing it........
Mookistar 17th May 2017 01:57 PM
the damage won't present itself there and then, it's more likely to contribute to failure further down the line.
-SeanS 17th May 2017 02:00 PM
In before the "Why would you use it", "it's chavvy as hell", "it's not in keeping with the GTR", "it sounds awful" "it blows up your car" crew come along every time pops and bangs is mentioned.
I'd also be interested to hear this, although I don't think there's any question it's definitely not good for the car, particularly this 'Godzilla' mode.
-SeanS 17th May 2017 02:01 PM
That's my understanding too, definitely not good for the longevity of parts
jrattan 17th May 2017 02:04 PM
Agree with the above, but it's okay when people track their cars - that's perfectly fine [emoji106][emoji23]
Hackett88 17th May 2017 02:07 PM
its the extra heat created by the fuel igniting in the exhaust that causes the damage. Usually rear end of turbo bares the brunt of the damage, Cracked housings, cracked/chipped blades etc... but you wont notice this until the turbos die.
If you get them really hot you can also cook the bearing cores leading to early turbo failure.
Stealth69 17th May 2017 02:10 PM
Now you have the disclaimer out of the way yes it will ultimately **** the turbos up at the very least, the shock from explosion I should think will destroy the bearings/blades in the turbo.
Not only will it cause damage to the turbos people have set fire to various parts of their cars.....
DAL3S 17th May 2017 02:16 PM
Something to avoid then. Note taken! :chairshot:chairshot
Chou 17th May 2017 02:42 PM
Sounds shit and is chav tbh.
Deserve to have turbo/engine damage for being so cringeworthy
dudersvr 17th May 2017 03:49 PM
Do you mean like this
http://i1182.photobucket.com/albums/...pstcjbnfbs.jpg
TAZZMAXX 17th May 2017 03:52 PM
On the plus side, if you're stupid enough to need a button that tells you you're in Godzilla mode, you'll be stupid enough to not realise your turbos are ****ed when they do give up. Ignorance is bliss, as they say.
Stealth69 17th May 2017 06:56 PM
Originally Posted by dudersvr (Post 5292329)
That's the plank!!!
snuffy 17th May 2017 07:34 PM
Ooo, I like the Nissan badge with the devil horns !!
Oh no, hang on, no, actually it's shite.
Trev 17th May 2017 08:05 PM
I'd like to know why it's called "GODZILLA" mode anyway?
The ONLY GT-R to use that name is the R32 and is a SKYLINE.
evogeof 17th May 2017 08:36 PM
guess who tried for pops and bangs while parked up and failed :bawling::bawling:
car was hot, parked up in P, was in 95 map R R R mode. car just wouldn't rev high even had my foot to the floor and held it there. my old evolution 9 was better in launch control.
https://www.youtube.com/watch?v=VvOMb-5VgBw
never tried it before so no piss taking :D:D
-SeanS 17th May 2017 08:56 PM
Car has a rev limiter in Neutral at about 4-5k RPM. All the ones you might have seen on youtube have had their limiter removed and will have an aggressive map for their pops and bangs. Got to be honest that was pretty embarrassing ;) I'm not sure what's worse, sitting and doing pops and bangs or failing miserably at them :chuckle:
evogeof 17th May 2017 09:04 PM
pretty embarrassing??? it was very embarrassing :bawling::bawling:
first time ide ever tried it to be fair, pops and bangs are fine when driving though. only used them a few times.
WingedBeast1968 17th May 2017 11:44 PM
Never tried any of that chav nonsense. My motor is buggered anyway. :(
Chronos 18th May 2017 09:10 AM
Whats up with it?
shavermcspud 20th May 2017 06:55 AM
Fairly sure Geof, you can increase the static RPM with the cruise control up and down button.
