Nurburgring Preperation - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree9Likes
Old 30th May 2017, 10:06 PM   #1 (permalink)
e8_pack is Chav Hunter
Registered User
Got a trip booked in July.
Anything I need to do to the car before I go on track? I'm no driving good so expect to hear about various rubbish cars scalping a GTR. However, I'm more worried about bonnet poppers going off.
So cancel them? What about the ecu, can I bypass it with a wire or something or just disconnect it?
Anything I need to do.
Going for a full service, new bell housing and goodrich brake lines.
e8_pack is offline   Reply With Quote
Old 30th May 2017, 10:33 PM   #2 (permalink)
JapFreak786 is .
JapFreak786's Avatar
Bonnet poppers going off means you are expecting to prang it, which you won't right so don't worry about that!
I'd say good brakes/tyre's and take your time. I was there last year and though I didn't drive my car myself, I did go out in an M experience car which was great.
Old 31st May 2017, 05:46 AM   #3 (permalink)
Registered User
I heard the poppers can go off just by going over the kerb or on the grass, even rumble strips!
Old 31st May 2017, 10:33 AM   #4 (permalink)
dudersvr is A Legend
dudersvr's Avatar
A few have so try not to go over kerbs, grass, gravel traps or bikers. You can dissconect at front of car which will stop the bonnet popping.
If you have time to stop in Holland message a guy called Richard Landsaat on B35 and see if he can do the ecu bypass for you, it doesnt take long so cant cost much.
Old 31st May 2017, 11:04 AM   #5 (permalink)
Registered User
Where at the front? What will be the effects, will it throw a code and put a light on the dash? Will it go into limp mode and will the code/light reset if I reconnect?
Old 31st May 2017, 11:05 AM   #6 (permalink)
Registered User
Is there a wire trick or something I can do on the crash ECU?
Ah, just read the second bit. Yes, wire bypass. Doubt I'll have time to visit anyone, is it difficult to do.
Old 31st May 2017, 11:05 AM   #7 (permalink)
no limp mode, will get a light on the dash but the ECU can be reset with an Ecutek cable once all is put back together.
terry lloyd likes this.
Old 31st May 2017, 12:11 PM   #8 (permalink)
terry lloyd is ........
terry lloyd's Avatar
The only thing with disconnecting them is are the sensors one time only ??? - ie: if you triggered the system with it unplugged the bonnet wont pop, but when you plug it back in it may go off ???
Old 31st May 2017, 12:19 PM   #9 (permalink)
LOL that could be a surprise for someone
Old 31st May 2017, 12:43 PM   #10 (permalink)
Registered User
Can you disconnect the actual ECU or will that put it into limp mode?
Old 31st May 2017, 01:48 PM   #11 (permalink)
R0B. is unaware they can edit their status
R0B.'s Avatar
Bonnet Cancellers
I'm off to the Nurburgring in a few weeks, I too was concerned about the bonnet 'popping' so weighing up fitting bonnet cancellers, here's Iain's response from Litchfield's, thought i'd ask them as they're probably one of the busiest GTR specialists dealing lots of tracked cars:
"In all the time we have been working on the GT-R I have only seen these bonnet rams go off on a couple of occasions and only when a car had fit a large object.
We would not supply or fit these as it could turn into a nightmare if you hit a pedestrian and they didn't go off."
R0B. is offline   Reply With Quote
Old 31st May 2017, 01:55 PM   #12 (permalink)
Registered User
Originally Posted by R0B. View Post
I'm off to the Nurburgring in a few weeks, I too was concerned about the bonnet 'popping', here's Iain's response from Litchfield's, thought i'd ask them as they're probably one of the busiest GTR specialists dealing lots of tracked cars:
A sensible though very corporate response. Though I would not expect to find pedestrians on the ring, bit there are large kerbs, grassed areas and road cones.
So there are bonnet cancellers, is there a bumper sensor canceller?
Fitted for ring duties only of course.
Old 31st May 2017, 01:57 PM   #13 (permalink)
R0B.'s Avatar
Yes, R35Audio sell them for circa £100 incl VAT and postge, as do JM imports.....
R35 GTR Bonnet Cancellers
I'm tempted to fit a set just for peace of mind.
Old 31st May 2017, 02:11 PM   #14 (permalink)
I am pretty sure its the main ECU that controls it - that is why it resets with Ecutek /Cobb
Old 31st May 2017, 02:40 PM   #15 (permalink)
Registered User
That's just the bonnet, is there one for the bumper sensor?
Old 31st May 2017, 02:47 PM   #16 (permalink)
Site Admin.
Mookistar's Avatar
as a newbie you shouldn't be going anywhere near Kerbs at the ring.
Autoguide.com
Old 31st May 2017, 02:55 PM   #17 (permalink)
R0B.'s Avatar
Same thing, the cancellers purpose is that should the bumper sensors send the signal to the ECU to fire the bonnet actuators, the bonnet actuators don't fire.
Old 31st May 2017, 03:02 PM   #18 (permalink)
Registered User
I didn't intend to hit the Armco at blyton either...
Besides, I've read reports of them going off when driving through a fast dip, or rough anything. Just don't want that to be me.
Old 31st May 2017, 03:04 PM   #19 (permalink)
Registered User
If the ecu goes off it will still throw a dash light right? And the pedestrian ECU requires replacement after?
Old 31st May 2017, 03:39 PM   #20 (permalink)
Chris**** is hiding
Chris****'s Avatar
Ive been round quite a few times, and its been fine, but get the cancellers if you want added piece of mind
From all the responses, you can reset the ecu if they do go off.
Chris**** is offline   Reply With Quote
