-   -   Strange Noise (https://www.gtr.co.uk/forum/518330-strange-noise.html)
GTRMikeyB 12th June 2017 04:56 PM
Strange Noise
Hi Guys,
Recently the GTR has started making a New noise was hoping someone might have had a similar issue or it might be nothing!
I have a 2013 GTR,
I know they have loud Gearboxs/Constant Moving Drive Shafts so you get a lot of noise anyways. But this is a New one.
Basically when it Engages drive and when you let off it makes a pretty loud Clicking/knocking noise just when you engage the Throttle or let off as if the Drive shaft is knocking when it gets power.
Know I am not mechanically Minded what so ever so I am probably so wrong just thought i would ask on here incase something is about to go Bang and I can fix it first.
Any Advice or Help would be Appreciated.
Thanks
Tin 12th June 2017 05:11 PM
Does it sound like its coming from the front centre console? Could be the bellhousing, does it speed up with very gentle throttle input?
GTRMikeyB 12th June 2017 05:23 PM
Well if you have the Windows open it just sounds like its coming from under the Car.
It doesn't speed up there is only a Noise when you let off the throttle or put on the Throttle. mainly under gentle throttle you can hear it most
TREG 12th June 2017 05:26 PM
Get a short video up of it
barry P. 12th June 2017 06:04 PM
I would guess it's the clicking front wheel problem, have you done a search on here for "clicking front wheel"? It's usually fairly easy to resolve the problem.
Simonh 12th June 2017 06:30 PM
Single click or continuous clicking?
Trevgtr 12th June 2017 07:14 PM
It's not the wheels by the description, he said it's a single noise on and off throttle, nothing like the continuous clicking from hell the front wheels make on turning.
I don't think it's one of the normal noises unfortunately GTRMikeyB, sounds like something has a bit of play in it.
Trevgtr 12th June 2017 07:17 PM
Just thought, is it a single metallic 'DING' noise coming from nearer the rear end? If so it is normal, but completely random and of unknown cause.
WingedBeast1968 12th June 2017 08:56 PM
Clutch relearn ?
GTRMikeyB 13th June 2017 09:00 AM
hey guys,
It is like a single Click/Knock mainly when you let off and you can hear it most if its just gentle throttle.
It sounds like it is coming from the Front. I still have warranty with the Garage I bought it from so think I will just give it to them tell them what I can hear and see if they will fix it.
I also get like a Jingling noise sometimes which sounds like its coming from the wheels any ideas?
Trevgtr 13th June 2017 07:03 PM
Jingling noise is probably brake caliper pad pins rattling, have a look at the top pins on front calipers, the spring clip is not fitted from factory (lower pin will have the clip).
The single click could be the DING noise I described, there is no known explanation or cure for it.
Let us know what the garage says :)
