Deano83
Power steering cooler leaking!
So I noticed last weekend I had a little oil on the undertray after an inspection it's clear that the lower pipe on the power steering cooler is leaking slightly.
I thought it would be as easy as just buying some new pipe and replacing it,which I've done but it still seems to be leaking! Has anyone else had this problem that may be able to shed some light? Cheers in advance.
charles charlie
is chasing a Veyron from 30-130mph
Upgraded cooler from Forge is around £2-250.
If you've swapped the pipe and it's still leaking it's likely the core is damaged. Maybe time for a nice upgrade?
Arrived 29/5/09 Reborn 12/1/17 ______________________________________ Engine built @ RiversideRacing Litcho rods/pistons/RaceIC/BOVs/oil cooler/susp+handling kit/front diff Race Developments ported manifold/AT Power TBs RF street zorst+DPs RacingBrake BBK Xtreme18 Clutch/Dodson 1st gear+shaft/trans brace 2015 alloys/nav upgrade/Nismo cluster DSC susp controller DBA front/Varis CF bonnet/2016 Lights TTE7XX turbos = >900bhp 700lbsft 30-130mph in 8.19s To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Deano83
Thanks for your reply Charles. I'm a little miffed to be honest,please excuse my lack of knowledge on this but any ideas what can cause the core to get damaged??,just don't want to buy a new unit if there could be another underlying problem.
charles charlie
Age and corrosion most likely. Hard for that area to get direct puncture damage and the internal pipe is a big one even if some rogue projectile made it through.
Haven't heard of anyone else having issues tbh other than overflow from overheating the PAS fluid on track (myself included) You're 100% it's leaking from the cooler / pipe connection?
#5 (permalink) | |
Deano83
#6 (permalink) | |
charles charlie
![]() I'd buy the Forge kit and swap the whole lot out given it's only a couple of hundred quid. See it as a little selling point when you sell the car. ![]()
Teaboy
is Making tea and taking names
I have seen quite a few of them and they are getting more common as these cars are getting older. I have seen maybe only 2 that have been leaking from the cooler and all the others ( 10 + ) have been the lines that run to the cooler.
Deano83
Cheers for your advice guys. I've ordered a replacement from Nissan in the end. Nothing worse than no being able to get out in your toy when the weathers nice.
Bookmarks |
Thread Tools | |
