GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - AT600 Package ..what next ? :-)
Old 17th March 2017, 08:59 AM   #3 (permalink)
roscop123
roscop123 is unaware they can edit their status
Originally Posted by charles charlie View Post
At the level you are bigger injectors gives your map headroom safety so the ecu can ensure you never run lean. Swapping injectors is a simpler job than the downpipes and imho is a necessary step for engine safety and future proofing.
Downpipes help to reduce exhaust back pressure to get an earlier spoil as well as reducing engine bay temps. Disadvantage is a much louder exhaust and a smell of petrol as the primary cats help remove unburnt fuel.
At this level of tune your tuner should recommend pulling some timing in order to keep torque to a safer 600lbsft. This isn't to nanny the transmission but to protect the stock rods.
That said there isn't a magic line below which you are safe. Increase torque and power and you increase the risk of failure both in the trans and the engine. There are plenty of cars running stage 4.25 with no issues as well as a fair few that have had trans failures and engine failures. There are plenty of cars that have had a variety of trans failures even at stock levels too.
It's a simple equation of increasing power increases risk.
He did say they keep torque no greater than 610lbsft
Im not so sure i want the increased risk by upping the power slightly then ...i may just stick to what i have for a while although i do fancy the downpipes lol
roscop123 is offline   Reply With Quote
