My13 clank clank noise is driving me mad! - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree1Likes
  • 1 Post By Stealth69
Old 6th July 2017, 07:13 AM   #1 (permalink)
james_barker is unaware they can edit their status
I have a noise that sounds like furniture in the boot rattling around and its giving my OCD a real meltdown.
Its almost certainly the 2nd noise identified in this blog for the gtr symphony of sounds.
Nissan GT-R (R35) Technical DIY Blog: Conducting the Symphony of Sounds from GT-R
Just wanted to check if any of you fine people have found a solution to this?
Sent from my SM-G930F using Tapatalk
james_barker is offline   Reply With Quote
Old 6th July 2017, 07:29 AM   #2 (permalink)
Could be jack in the boot not secured properly (if your car was spec'd with a jack from factory)
Old 6th July 2017, 07:36 AM   #3 (permalink)
Nah, because like the blog post indicates it stops if I apply any brake pressure. It's just the damn lego construction employed by Nissan.
Old 6th July 2017, 07:43 AM   #4 (permalink)
dudersvr is A Legend
dudersvr's Avatar
Jack goes in the storage in passenger footwell.
Old 6th July 2017, 08:14 AM   #5 (permalink)
NELLEE is Attracted to women half his age and half is weight!
NELLEE's Avatar
Could it be worth trying some pre 2013 clips for the pads?
Ive never had this my MY09 and MY12, I would call in at your local specialist to get them to come up with a fix
NELLEE is offline   Reply With Quote
Old 6th July 2017, 08:20 AM   #6 (permalink)
hmmm that's odd, people in the US have moaned about the jack in the boot..... perhaps I misread, perhaps he had his mate Jack in the boot and he was knocking furiously to be let out
dudersvr likes this.
Old 6th July 2017, 08:37 AM   #7 (permalink)
Chronos's Avatar
Cars owned: R35 Black Edition
such a good link!! and handy.. hope you get yours sorted... BTW any squeaks and rattles, from inside the cabin which i had when i 1st bought mine, and was PROPER annoying, I took the car to pwpro who strip R35s nearly daily for wrapping, so know then inside out, they stripped the inside applied foam strips etc to the normal squeaky areas, also had the centre console done as well and now its sqeak free and has been for a few years now, bliss!
Old 6th July 2017, 10:13 AM   #8 (permalink)
terry lloyd is ........
terry lloyd's Avatar
Couple of things it could be - if it has a tracker fitted that could be left flapping about, poorly installed, (edited by admin on location, be sensible peeps!)
Some brake pads have bigger holes for the pins than the oem ones and they rattle - also the pins wear in the calipers - i removed mine cleaned them and coated with silicone sealant where they insert into the caliper
Could be seen as cost cutting to some
Old 6th July 2017, 10:16 AM   #9 (permalink)
Originally Posted by terry lloyd View Post
Couple of things it could be - if it has a tracker fitted that could be left flapping about, poorly installed, (edited by admin)
Some brake pads have bigger holes for the pins than the oem ones and they rattle - also the pins wear in the calipers - i removed mine cleaned them and coated with silicone sealant were they insert into the caliper
The brake pad thing you describe sounds like a likely source and fix. I'll give it a go. Thx
