R32 GTR - Weekend driver - Page 3 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree18Likes
Old 15th May 2019, 06:45 PM   #41 (permalink)
Mike-998 is unaware they can edit their status
Originally Posted by rhocken View Post
I used this stuff I borrowed it from someone on the Forum
https://justjap.com/tomei-throttle-coat.html
The throttle seals I think I got from here:
https://www.efihardware.com/products...y-Lip-Seal-Kit
Thanks for the links! If I have to have the manifold off I'll definitely give those a try.
Originally Posted by alexcrosse View Post
One of the last things to do idle wise it to put a bit more preload on the spring in the idle valve, but it's a bit of a job.
You need to dig out all the epoxy, it reveals a bit flat head grub screw. 1 turn on this or so to account for any yielding in the spring over the years. Then you should be able to use the other screw to adjust idle again.
Here is a pic from SAU.
I don't have the kit to go that far so thought it best to leave it. I've had it off and cleaned up and now it idles around 1100-1050, so some improvement.
I think I can live with that for now so I'll leave it as is. At least until after I've been to some shows this year - that's quite enough time in pieces!
Mike-998 is offline   Reply With Quote
Old 16th May 2019, 06:21 AM   #42 (permalink)
alexcrosse is unaware they can edit their status
1050 is almost within tolerance anyway, so thats pretty good.
Remember often the tachos are out too
I chased this same problem for a year or so lol.
alexcrosse is offline   Reply With Quote
Old 16th May 2019, 09:23 AM   #43 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Originally Posted by jnoor View Post
The turbo refurb and the turbo line refresh looks sublime!
What did you get done to the turbos as part of the refurb? Did TD use 360 thrust bearings as part of the turbos?
The N1s are steel turbines aren't they?
Anyhoo all the work looks fantastic, looking forward to seeing more stuff
Iíve still got my R34 turbos which you can have at a good price as mentioned before. Can even offer you Billet comp wheels if required.
Old 16th May 2019, 04:35 PM   #44 (permalink)
Those values are from the PFC hand controller - I didn't realise quite how far out they are though!
alexcrosse likes this.
Old 17th May 2019, 05:15 AM   #45 (permalink)
Madaxgt is unaware they can edit their status
You can actually adjust the rev counter to match true rpm. There is a little plastic phillips screw adjustment point on the back of the unit which was set at factory when new. Its not a quick job though and kind of tricky to adjust with all the wiring connected. But it is possible.
Madaxgt is offline   Reply With Quote
Old 17th May 2019, 08:24 AM   #46 (permalink)
jnoor is told I am addicted to this site
jnoor's Avatar
FFS Younes! You know my project is on hold atm
Why you do this?! I didn't know you did billet comp wheels for the R34 turbos, just thought you did them specifically for the 2860s.
jnoor is offline   Reply With Quote
Old 17th May 2019, 02:18 PM   #47 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Can do them for any turbo. Check out IG posts of recent. Buy them then when your ready I can get wheels designed and made. 13g is a lot of weight saving
