Gear selection issues - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree13Likes
Old 16th July 2017, 08:30 PM   #1 (permalink)
sparky_7999 is unaware they can edit their status
sparky_7999's Avatar
When the car is cold and I reverse out the drive way, I then put it in drive and sometimes it takes like 3 secs and what sounds like a few attempts to get its self in gear. Whilst this is happening the gear selection number flashes. Any ideas??
sparky_7999 is offline   Reply With Quote
Old 16th July 2017, 08:39 PM   #2 (permalink)
Can start by doing a gearbox Learn but it could be :
solenoid issue
damaged fork.
Old 16th July 2017, 10:06 PM   #3 (permalink)
dudersvr is A Legend
dudersvr's Avatar
If clutch learn doesnt do it then a valve body strip and clean and filter change/clean is next step.
Old 16th July 2017, 10:08 PM   #4 (permalink)
Cheers guys. It doesn't do it all the time and only does it when I start it and literally drive straight away. Weird! Does the valve body strip work cost a lot to do?
Old 16th July 2017, 10:13 PM   #5 (permalink)
dudersvr's Avatar
Its a good 3 to 4 hours work and use about £50 of brake cleaner. Its not really a DIY, just did one today and got another tuesday.
Old 17th July 2017, 08:46 AM   #6 (permalink)
GT-RDC Founder Member
barry P.'s Avatar
Most likely scenario is worn shift fork shaft, AC Speedtech have seen this several times. They supply and fit a new hardened shaft and a different type of shift fork bearing to prevent it happening in the future.
Old 17th July 2017, 08:54 AM   #7 (permalink)
Barry loves a hardened shaft so he would know if these replacements are any good
barry P., Chronos and snuffy like this.
Old 17th July 2017, 10:43 AM   #8 (permalink)
Tinyflier is Running ACSpeedtech forged engine,trans,exhaust
Cars owned: R35 (4.25) & Brabus ForFour
I had this on my CBA and ACSpeedtech carried out a rebuild as Barry has said. Since then (nearly 2 years ago) I have not had a single R-1-R selection failure.
I thought (usual health warnings about the accuracy of my thoughts), once this starts to happen it can only get worse over time and as Barry said can lead to a shift fork breakage.
David
Tinyflier is offline   Reply With Quote
Old 17th July 2017, 11:30 AM   #9 (permalink)
GTR RGT is unaware they can edit their status
GTR RGT's Avatar
Cars owned: R34, R35, Defender, Supra
For future reference - it will be slow to change when battery voltage is low also.
GTR RGT is offline   Reply With Quote
Old 17th July 2017, 12:08 PM   #10 (permalink)
dudersvr's Avatar
Heres a pic of the inside of the pickup filter in a functioning non failed built trans from yesterday, people think you can just spray them with brake cleaner and they are like new, not so, they can be split and cleaned 2 or 3 times then there will be swarf in the primary filter and the valve body that has another 7 small filters and the solenoids that get clogged.
[ATTACH] [/ATTACH]
Could be worse, could look like this
Old 17th July 2017, 05:13 PM   #11 (permalink)
barry P.'s Avatar
I'm sure you know who's box that is and where it failed.
Old 17th July 2017, 05:29 PM   #12 (permalink)
dudersvr's Avatar
Old 17th July 2017, 06:29 PM   #13 (permalink)
R35 Section manager
TREG's Avatar
Cars owned: R 35 GTR
Question
Where do you work then mate?
Old 17th July 2017, 06:49 PM   #14 (permalink)
dudersvr's Avatar
I was at Austec when it was opening,my pal still has the lease so I have use of a ramp there till he shuts it. Am in the process of looking for a new shop maybe with Dimitri from Greece who has come over to sort out Rockys and Buzz's cars, I look afeter a couple of hi hp 911's and of course mine and a couple of other GTR's but as happens I getting asked to do more and more and Dimitri wants to open a shop here as well as his GTR shop in Greece.
TREG likes this.
Old 17th July 2017, 07:23 PM   #15 (permalink)
Ooo Matron !
snuffy's Avatar
Cars owned: GT-R & Fiat 500
Originally Posted by Stealth69 View Post
Barry loves a hardened shaft ...
Stealth69 likes this.
MY2013 TCM
ACSpeedtech EcuTek RaceRom 5
Old 17th July 2017, 07:26 PM   #16 (permalink)
Ooo Matron !
snuffy's Avatar
That is exactly what mine did. It was normally when cold, and also the same thing when going into 1st. Then last years it went flash-flash-flash and went into second with "trans fault" on the display. The selector fork has sheared it's end off.
MY2013 TCM
Old 17th July 2017, 07:28 PM   #17 (permalink)
barry P.'s Avatar
Is Dimitri anything to do with Extreme Tuners from Athens?
Old 17th July 2017, 08:27 PM   #18 (permalink)
dudersvr's Avatar
No they are friends of his, he is Midas Tuning.
Old 17th July 2017, 08:28 PM   #19 (permalink)
HellsSalesman is burning
HellsSalesman's Avatar
huh, why not? I did this a couple of weeks ago and thought it was quite easy. Lot's of how to's floating around the interwebs.
HellsSalesman is offline   Reply With Quote
Old 17th July 2017, 08:38 PM   #20 (permalink)
dudersvr's Avatar
So you split the valve body and removed the mini filters and all the O rings and seals and ball bearings and took the pistons out and solenoids off? If so thats good work but not IMO DIY for the average Joe, if you lose one seal you cant get them and Ill bet hardly any DIY mechanics have all the tools needed to do the job. How did you hold the pistons in the correct position to go over shift forks? Nice going though.
