DBW Conversion RB26 - Single Throttle or Multi ITBs? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree2Likes
  • 1 Post By BNR34Zed
  • 1 Post By tarmac terror
Old 14th August 2017, 12:56 PM   #1 (permalink)
BNR34Zed is godzilled
BNR34Zed's Avatar
Cars owned: '96 R33 GTR
Hi,
I've readed many post for Single Throttle vs Multi Itb.
But, who has done a DBW conversion on both?
What parts are needed to keep the Multi ITB For a DBW conversion?
I think that is easier on a Single throttle.
GTRNICK likes this.
BNR34Zed is offline   Reply With Quote
Old 14th August 2017, 07:40 PM   #2 (permalink)
tarmac terror's Avatar
No reason why it should be unless you have a STB already. If you have ITB's then surely it would be easier to keep that setup?? The only benefit I can see is that, with the right STB from a production vehicle, you could simplify the actuation mechanism as it'll already be there in a factory STB.
Matt J did exactly this in ITB's with his R33 and it's something that's on my 'final spec' sheet too!! He used an actuator and linkage mounted underneath the plenum IIRC. Go and search for his build thread and you'll see it all there.......if Photobucket hasn't destroyed it.
TT
BNR34Zed likes this.
Old 14th August 2017, 07:48 PM   #3 (permalink)
BNR34Zed's Avatar
TT
I've a ITBs setup with a Greddy Manifold but I was thinking to convert it to a STB.
Unfortunately Photobucket has destroyed all
I can't find anything on Matt J's thread.
What's the benefit on a STB instead of a ITBs setup?
Old 14th August 2017, 07:50 PM   #4 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
from a performance point of view i doubt there is much in it.
one technical consideration is the type of motor you want to use, there are more factory stb actuators and they will be supported by more ecus.
another point is the current required to drive the throttle motor, the link ecus dont have as much puff as syvecs so that might limit your options.
Old 14th August 2017, 08:28 PM   #5 (permalink)
BNR34Zed's Avatar
I've readed a thread for a DBW conversion and Link G4+ Ecu with great success on the Support forum of Link Ecu.
With a STB I know the route. R35 Pedal and LS3 TB or others.
But for ITBs I don't know how is possible to do.
Old 14th August 2017, 10:45 PM   #6 (permalink)
PM matt J. He'll, I'm sure, explain what he did...
TT
Old 15th August 2017, 08:42 PM   #7 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Check out Galvsport R32 - their work is top notch and is running full Motec engine management with their own DBW setup and Bosch Motorsport ABS.
