Intermittent TPMS failure. - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 16th August 2017, 07:52 AM   #1 (permalink)
Killerscum01 is looking for a clear stretch to push his ponies
Killerscum01's Avatar
Cars owned: Stage 4.25 GTR, 911 Turbo, 335D, Evo8 x2, M5, Mk1 Focus RS, TVR Cerbera, many many Cosworths
Hi All, I'm sorry if this has been done to death and I have done a search but cant find my specific problem.
About a week ago I had the flat tyre warning light come up on the offside front, I checked the pressure on the screen and it said 0psi, then a few moments later the pressure came back but obviously the fault had been registered, so I purchased a used ecutek cable from here and reset it code and was fine.
Anyway... today the same happened so I guess it might be going bad. my questions are:
  • Do they have an internal battery?
  • Is it charged by Kinetic/Centrifugal energy?
  • Are my issues the start of a typical failure and just get on and replace it?
It feels like, that the car doesn't pick up that sensor fast enough and then records a failure, I wonder if the internal battery (if it has one) isn't powerful enough.
Killerscum01 is offline   Reply With Quote
Old 16th August 2017, 08:15 AM   #2 (permalink)
charles charlie's Avatar
Sounds to me like a failing sensor hence its 0psi reading. Usually the MFD shows "***" when the car's receiver doesn't get any signal from the TPMS sender in the tyre.
Not heard of many failures to be honest but this'd be my guess.
They're not overly expensive to buy.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 16th August 2017, 08:33 AM   #3 (permalink)
I have to say... what worries me the most is the tyre fitters scraping a rim, doing the job.
Old 16th August 2017, 04:49 PM   #4 (permalink)
Philloy is unaware they can edit their status
Most places should be able to change the sensor without removing the tyre just ask them to brake the bead on the outside rim then use the arm on the machine to push the tyre so they can replace the sensor, That's how I do mine
Phil
Philloy is offline   Reply With Quote
Old 18th August 2017, 08:01 AM   #5 (permalink)
Phil
Yeah I did think that too to be honest.
