GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - TPMS reset when changing tyres?
Old 22nd May 2017, 09:51 PM   #3 (permalink)
charles charlie
charles charlie's Avatar
As above nothing needs doing.
You're confusing two TPMS scenarios...
A reset - done by Cobb or Ecutek when a flat tyre warning has been triggered by a tyre pressure below 14 psi (don't confuse with a low tyre pressure warning which resets upon refilling tyre and driving)
A relearn - require after installing a new TPMS sensor in a wheel. Also requires a TPMS wake up tool to activate the sensor before using a Cobb etc to start the cars process of relearning the new sensor.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
