Gearbox Help? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree8Likes
  • 1 Post By NELLEE
  • 5 Post By NELLEE
  • 1 Post By Simonh
  • 1 Post By charles charlie
Old 1st September 2017, 08:07 PM   #1 (permalink)
NELLEE is Attracted to women half his age and half is weight!
NELLEE's Avatar
Gearbox Help?
Looks like its my turn to have Gearbox issues. I can reverse ok and 1st but that's it , when the car tries to shift to 2nd it just ends up in Neutral with the no 2 flashing.
My local indy are a bit hit and miss at the weekends and I don't have a cable to check the codes
NELLEE is offline   Reply With Quote
Old 1st September 2017, 08:08 PM   #2 (permalink)
Gutted mate...... Off to the garage it is for you my old fruit, either a form or busted solenoid?
Old 1st September 2017, 08:15 PM   #3 (permalink)
NELLEE's Avatar
Yeh i'l call AC in the morning and see what the waiting list is like,,
dudersvr likes this.
Old 1st September 2017, 11:59 PM   #4 (permalink)
Trevgtr's Avatar
Unlucky mate, is it a MY12 car, can I ask what the mileage is?
Old 2nd September 2017, 05:47 AM   #5 (permalink)
NELLEE's Avatar
Yeh is a 12 plate with 12k on it
Old 2nd September 2017, 07:17 AM   #6 (permalink)
motors is unaware they can edit their status
motors's Avatar
I had same issues some time ago it was just a seal that had gone which results in no pressure to change gear it was a cheap fix hopefully yours is the same.
motors is offline   Reply With Quote
Old 2nd September 2017, 07:25 AM   #7 (permalink)
Clutch seal, when my pals did the same. All sorted by. AC Speedtech team
Old 2nd September 2017, 11:30 AM   #8 (permalink)
Ooo Matron !
snuffy's Avatar
Cars owned: GT-R & Fiat 500
Why ? I would expect them to be closed at the weekends.
MY2013 TCM
ACSpeedtech EcuTek RaceRom 5
Old 2nd September 2017, 11:32 AM   #9 (permalink)
Ooo Matron !
snuffy's Avatar
I had the same, but I lost 1st and reverse with a broken shift fork. So it could be the opposite shift fork in your case.
Mine did it at 5 years old and 20k miles or so.
MY2013 TCM
Old 2nd September 2017, 01:12 PM   #10 (permalink)
JapFreak786 is .
JapFreak786's Avatar
AC certainly do a lot of gearbox work and reknown for it. Also a chap in Birmingham who does a lot of work for garages as they sub the work out to him.
‘95 R33 GTR
Old 2nd September 2017, 05:43 PM   #11 (permalink)
NELLEE's Avatar
Update /
Tried the car this morning and it did change up through the gears, although I got a bit of a jolt the fist time it went to 2nd. After that it seemed ok. So thought best drive to AC just on the off chance anyone was around.
There officially closed on a Saturday but Andy was there doing some paperwork, he VERY kindly popped out to take a look. After running some checks and test drive and relearn he said its all fine, just must have been a glitch. not even any fault codes
Fingers crossed!!
Old 2nd September 2017, 07:41 PM   #12 (permalink)
Simonh's Avatar
Cars owned: MY11 R35 Recaro
Perhaps a good excuse to get the fluid changed?
Old 2nd September 2017, 11:12 PM   #13 (permalink)
HellsSalesman is burning
HellsSalesman's Avatar
yes, plus did you ever had your solenoids cleaned?
HellsSalesman is offline   Reply With Quote
Old 3rd September 2017, 02:46 AM   #14 (permalink)
NELLEE's Avatar
Had the Trans fluid done a few months back, not had the Solenoids cleaned up to now. Andy said it could be slightly warped clutch plate/basket
Old 3rd September 2017, 06:02 PM   #15 (permalink)
dtox is unaware they can edit their status
Hopefully it's sorted for you
My MY12 has been nothing but issues, going to be opened up for the 4th time now
I would have said it could be a fork or sol or a basket
The baskets are very common to go depending on stage
dtox is offline   Reply With Quote
Old 3rd September 2017, 06:22 PM   #16 (permalink)
charles charlie's Avatar
It's not a basket issue. If your basket snaps you don't get drive ever again in odd or even gears (depending on whether its basket A or B) until it's replaced. The gearbox will select the gear but just rev away as drive power can't get from the clutches to the output shaft.
terry lloyd likes this.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 3rd September 2017, 07:15 PM   #17 (permalink)
NELLEE's Avatar
Sorry to hear that, 4 times sounds a lot, does it get a lot of abuse? Whos doing the work?
