-   Tuning: General (https://www.gtr.co.uk/forum/tuning-general.html)
-   -   rb26 KTS suction kit (https://www.gtr.co.uk/forum/543721-rb26-kts-suction-kit.html)
Tzuteng 23rd December 2017 04:54 AM
Sorry if this has been posted before, but I searched and didn't found anything. Question for those who have the KTS suction kit: In the rear turbo piping there is a port where you screw a vacuum nipple in, what is this nipple used for? I don't recall having any vacuum port/line on the stock rubber hose when I removed it. What bolt size can I use to cap these port off? BTW, I have an R33 GTR.
GT-R David 23rd December 2017 07:21 AM
Should be 1/8npt.
It's for the stock boost solenoid valve.
Tzuteng 23rd December 2017 11:36 AM
1 Attachment(s)
Its the circled vacuum line in the picture. I swear I never saw that line when I took the stock hose out. I dont recall the stock hose having a port for this line either.
FRRACER 23rd December 2017 11:59 AM
That is normal
Tzuteng 23rd December 2017 12:02 PM
Pic is not mine, its for reference. I cant find that line in my car.
FRRACER 23rd December 2017 12:13 PM
Sorry just double checked yes that is abnormal. On the rear there is a port for a vacuum hose from the camcover breather.
Tzuteng 23rd December 2017 12:17 PM
Exactly. My stock rubber pipe has the port for the cam cover breather hose and so does the kts pipe. But I am scratching my head with that nipple/vacuum line that the kts pipe has. I have been looking and some people have the line plugged in the pipe and some have it capped.
GT-R David 23rd December 2017 05:20 PM
This hose can be removed if you don't have the stock boost solenoid valve
Tzuteng 23rd December 2017 05:27 PM
I still have the stock boost solenoid. How many hoses or lines come out of the solenoid? BTW thanks for the input on where the vaccum line comes from.
GT-R David 23rd December 2017 07:29 PM
http://oi46.tinypic.com/mw9kbc.jpg
It's the red hose.
It is on a different position on stock piping
Tzuteng 23rd December 2017 07:36 PM
Thanks for the help. Will check for this once I get home. Where exactly is that red hose located on the stock rubber piping?
GT-R David 23rd December 2017 07:57 PM
On the connection pipe between them if I remember right.
Tzuteng 24th December 2017 07:29 AM
Checked and the red hose attached to the air connector in the diagram is part of the bov recirc. If I take that hose and put it in the nipple, what do I do with the port on the air connector?
GT-R David 24th December 2017 08:06 AM
This part of the pipe will be removed when installing the KTS kit if I remember correctly. It's realy not that hard to install.
Just low quality, but easy install.
Tzuteng 24th December 2017 08:14 AM
Makes sense now. Will follow up once I work on installing the pipes.
