David
Many R32 and R33 bits Mechanical Chassis Body and interior
I have recently bought a joblot of R32 GTR parts as it gave me a bootlid, front driveshaft and many other small bits I needed. All parts came from a crash damaged r32 GTR with 59K km on the clock (pictured).
I hope I have priced everything competitively if not make me an offer. Please also note I am extremely busy currently will only post items with a total value over £75 due to limited time to pack and post. Collection welcome evening and weekends close to Coventry Mechanical Standard R32 GTR downpipes : £25 R32 GTR standard CAT £50 R32/33 GTR Coil Pack ignitor module £75 R32/R33 Coil Packs £50 R32 HKS Induction kit £75 (needs new filters £2.50) R32 GTR Hard pipe kit (only two pieces) £100 R32 GTR Twin Turbo pipes (the two pieces that bolt to the turbos on the top of the engine with the twin turbo badge) £50 R32 GTR standard BOV's and pipe £50 R32 GTR clutch slave cylinder £25 (needs new outer rubber seal as has swelled up due to sitting in oil) R32 GTR Standard ECU £25 R32/R33 Coil Packs £50 Chassis R32 GTR front calipers, good condition but missing one piston (£18 on ebay) and one side pins (again available on ebay) come with new pads in box £100 R32 GTR Rear calipers with discs, calipers look in really good condition, complete with all pads pins ect, discs are drilled and have surface rust but very little lip and will clean up with a wire brush £225 R32/33 GTR Rear driveshafts £150 each R32 GTR rear Propshaft missing balls from centre joint £50 R32/33 GTR front propshaft £75 R33 GTR 4wd Pump £125 R32 GTR 4wd Pump £125 R32 GTR Clutch and brake pedal £25 each R32 Rear camber arms £25 each R32 Rear toe arms £20 each R32 Rear subframe, ideal for shot blasting and powder coating £100 R32 GTR bonnet catch panel and centre spar completely rust free £50 R32 GTR standard rear shock (untest sold as seen) £50 R32 GTR passenger side hub, upright and top suspension arms complete assembly other than bottom arm £125 Body Parts R32 GTR wind deflector super rare drivers side only £100 R32 GTR Passenger side Wing Mirror £30 R32 GTR Rear lights in gunmetal grey £100 each R32 GTR Front passenger side indicator, has small damage to black trim but once glues you wont see it £30 R32 GTR rear bumper crash bar small dent which looks like it will knock out or could be left £50 R32 GTR side skirts, both skits but only one end cover these are very rare now £200 R32 GTR rear bumper £100 R32 GTR rear antiroll bar £50 Interior Parts R32 GTR centre gauges left hand mounts broken might be good for someone £10 R32 GTR Gauges Dashpack (Speedo) 59K £150 R32 GTR A pillar trims £25 each R32 GTR sun visors £20 each R32 GTR centre consol £75 R32 seat belts £20 R32 ecu cover £20 Other parts but wil leave it as that for more
tom_glanza
Have you got both the hks hard pipes and are they both polished I got stung and got some one polished and one chromed!!
anthonymcgrath
is probably succumbing to gravity... lemme check..
yep.. still there funnily enough
Cars owned: R33 gtst
Hi I pm'd you about the sun visors?
Sent from my SM-A520F using Tapatalk
#12 (permalink) |
anthonymcgrath
Random one lol... but do you perchance have the little metal clip that holds the top of the rubber trim together on the rear window (32gtr) ?
![]() Sent from my SM-A520F using Tapatalk
#14 (permalink) |
freecer
is freezing
hi
i am looking for the armrest and the shift boot plastic part (who holds the boot down). https://picload.org/view/ddwriraa/img_1475_15.jpg.html also looking for the oem seatbelts with mountings. plus some pillar trims. pm me if you still have these parts ![]()
Bookmarks |
Thread Tools | |
