Restoration/Modification of my road legal Circuit racing R32 GTR - Page 5 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree47Likes
Old 16th October 2019, 01:56 PM   #81 (permalink)
David's Avatar
So thats enough tempting with fabrication and exotic chassis modification.
Back to rust repairs...........
This is what the drivers side chassis leg ended up looking like before primer.
Hopefully you will agree quite a change
The blue/balck paint is a rust converter recomended by Steve Richardson (Facebook Skyline restoration Guru)
I am not going to bore everyone with primer picture so onto more rust......
R32 GTR Restoration/Modification Track car build
Old 16th October 2019, 02:36 PM   #82 (permalink)
David's Avatar
So back to the (worst) rust on the passenger side.
Having learnt the techniques and what I needed to keep and how to quickly get it apart I made a start on the passenger side sill. Firstly off with the outer skin
As you can see it is really crusty
This is where I cut the rear quarter to be able to get access
A per the otherside, I now know this complete panel will come out for replacement. I also cut all the rear sill off and will use the other side as a reference as the remaining bits are so rusty.
Old 16th October 2019, 02:42 PM   #83 (permalink)
David's Avatar
Inside of the rear crossmember cleaned up
Hear I have missed one photo but this is with the second under seat skin removed
Complete sill removed and back to good metal
Old 16th October 2019, 02:48 PM   #84 (permalink)
David's Avatar
The rear floor was worse than the otherside, sorry no picture but this is where the donor car cam in handy.
Complete replacement floor section shot blasted.
It was then separated and from the inner sill and spliced into the original floor, as per the other side by undoing all original welds and then seem welding across the loin into the existing floor
You can see from the hole that as per the other side the three layer that form the seam at the end of the floor need reconstructing. This panel is the first
Old 16th October 2019, 02:54 PM   #85 (permalink)
David's Avatar
So this is a repeat of the other side, first repair inner sill (blue/black is rust treatment paint not rust)
The second layer of the rear floor was then added back in and spot welded in place.
Almost done
Old 16th October 2019, 02:59 PM   #86 (permalink)
David's Avatar
So the big hole then needs filling with a new rear inner sill
Used the sizes from the drivers side I made a replacement and fitted
Trial back in the remain of the what i'll call rear sill strengthening plate (as you can see there is not much left of it)
So make a new one using CAD (Cardboard aided design) and fit
Old 16th October 2019, 03:14 PM   #87 (permalink)
David's Avatar
Then as per the otherside simply make a replacement corner for the arch panel (see previous description as to how to do this).
Interestingly for some reason I screwed the bead rolling up on this so ended up making a second one (pictured)
Note the remaining rust on the top of the inner wheel arch wont be left, but I'll do that later once the sills are on the the rear quarters are cut off
Now to the most difficult part of the whole car. Here you can see what I will call the rear sill support panel. As you can see only 1/3 of it has survived although actually better than the other side.
I decided to repair it in two parts, and this is where I now needed the sill trial fitted to judge the final shape
Dont worry this crusty edge will also be replaced
But first
Old 16th October 2019, 03:22 PM   #88 (permalink)
David's Avatar
So first some more CAD
Tacked in place and rear edge replaced
The end result after flapper wheeling I think is quite good. Pity it will never be seen as will be covered by the front edge of the rear quarter panel
At this point I decided I wanted a proper spot welder before continuing as the next step is to fit both outer sills.
So while I looked for one to buy I had a look at the the front chassis leg / arch / bulkhead. It didn't look pretty.......
Simonh likes this.
Old 16th October 2019, 03:25 PM   #89 (permalink)
David's Avatar
Originally Posted by kevr32 View Post
Bumped for an update, come on Dave.
Thanks Kev, it's good to see the update to your thread gives me some enthusiasm as to what mine can look like when finished.
How much I look forward to paint........ & carbon panels really looking forward to starting making them
Old 16th October 2019, 03:32 PM   #90 (permalink)
David's Avatar
Please feel free to add comments questions to the thread
Old 16th October 2019, 03:37 PM   #91 (permalink)
David's Avatar
This side was far worse than the other side
Crusty
Holes
More holes
More general crusty horidness, many would be tempeted to leave like this, but these panels need lifting off to expose the root of the issue
Look at all that rust hiding under the seem
Simonh likes this.
Old 16th October 2019, 03:40 PM   #92 (permalink)
BenTaylor200 is aware he can edit his status
Cars owned: 527bhp 200SX
More S15 info please
BenTaylor200 is offline   Reply With Quote
Old 16th October 2019, 03:40 PM   #93 (permalink)
David's Avatar
Based on the experience of the otherside and now having this inner wing panel from the donor shell I decided to completely cut this panel out.
Exposing the full crustyness of the bulkhead
So out with the grinder and 1mm cutting discs
Old 16th October 2019, 03:45 PM   #94 (permalink)
David's Avatar
Cut out the rot
Cut matching panel from donor
Weld in
Sand flat
Hopefully you agree, as good as new
Old 16th October 2019, 03:50 PM   #95 (permalink)
David's Avatar
So what lerks beneath the inner wing panels on the chassis leg, yes more rust
one layer removed
Finally top edge of chassis leg removed.
Some advice to anyone doing anything similar my advice is make the biggest panels possible, they are much easier to work with and it ensures you get back to good metal when you weld them in.
Old 16th October 2019, 03:58 PM   #96 (permalink)
David's Avatar
Sorry no CAD pictures, but simply make a template cut from I think 2mm from memory as chassis leg is much thicker.
Then weld in:
Then grind flat, here I have not ground back as much as other panels as I want the strength and it will be covered in some form of under seal so you will never see anyway
Old 16th October 2019, 04:01 PM   #97 (permalink)
David's Avatar
Found picture of how I made the panel, as you can see it has a recessed feature
The tools are really simple, just beat it over a section of round edge bad, the result looks pretty OE
Simonh likes this.
Old 16th October 2019, 04:25 PM   #98 (permalink)
David's Avatar
No problem i'll grab some pictures, the VE conversion seems surprisingly simple although I think my turbo selection is now wrong
I still need some simple bits if you can help
- Standard size crank
- Water neck
- Thermostat housing
- Standard crank pulley
Old 17th October 2019, 10:29 AM   #99 (permalink)
800bhp is making plans
800bhp's Avatar
Cars owned: Current Fleet : Drag 200SX, Alfa Giulietta Cloverleaf, Alfasud, Alfa 33 Racecar, Renault Trafic
- Water neck
I think I have a set of Supertech valve springs and titanium retainers for the VE head (I bought them twice by mistake!!)
800bhp is offline   Reply With Quote
Old 17th October 2019, 04:18 PM   #100 (permalink)
- Water neck
10 years ago I'd have had all of these, had to downsize my parts hoard to make room for more cars!
