briancgtr33
is rusting
torque settings for manifold,elbow...Help!!
Hi all, so i've got my turbos off and most of the nuts were really loose.
one elbow was held on with 1 nut slightly tight 2 nuts less than finger tight and 2 missing the other wasn't much better. The manifold bolts where pretty loose as well. While this made stripping down a lot easier i'd like to get them torqued down correctly. I've ordered new locking nuts from driftworks. i've searched but can't find the correct torque. looking for manifolds and elbows torques?, i did find one thread that sugguested 18-24nm would that be right? thanks for any help
MS33
I had the same problem, I'd re-fitted the turbo's, then about 12 months later all of the nuts came loose.
![]() Using a 3/8 drive he did the nuts up as TIGHT as possible having had this problem before. Since then no problems, so whether the torque setting aren't high enough, I don't know, could be the case.
lightspeed
is mapping Infinity
Cars owned: Project BNR32
Yes 18-24Nm.
Not a fan of “as tight as possible”......take it from a real engineer who has designed many successful bolted joints.
Red Duke
is renovating and upgrading!
Tight as possible usually ends up as: "Just a bit m...*SNAP!* "
![]() I bought a Silverline torque wrench for doing a few bits on my GT86, it wasn't hideously expensive like some and does the job, really pleased with it. ![]()
briancgtr33
is rusting
cheers guys.. didn't want to do as tight as i could
got everything i need now to fit turbos. just one stubborn stud in the elbow to get out. and hopefully every nut will stay tight.
MS33
24Nm is 17.70 ft-lb I'm old school
#7 (permalink) | |
briancgtr33
is rusting
it's only a short wrench and 24nm is about as tight as i can get it with it ![]() just snapped to many things to risk it.
Bookmarks |
Thread Tools | |
