Which DCT fluid do you use? - Page 2 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
View Poll Results: Which DCT fluid do you use
OEM Nissan 4 19.05%
Motul DCTF 6 28.57%
Pentosin FFL-4 2 9.52%
Pentosin FFL Racing 8 38.10%
HKS DCTF II 1 4.76%
Voters: 21. You may not vote on this poll
Like Tree9Likes
Old 22nd September 2018, 12:55 PM   #21 (permalink)
terry lloyd is ........
terry lloyd's Avatar
There is another litre if you drain the clutches - there is a procedure to do this but I cannot remember how it goes something to do with putting it in gear with the brake on
I have 10ltrs of motul dct if anyone wants it £100
Old 22nd September 2018, 07:24 PM   #22 (permalink)
dudersvr is A Legend
dudersvr's Avatar
Originally Posted by nick the tubman View Post
you say 10ltrs per change... fairly sure we never managed to get 10ltrs into the box before it poured out the top sight hole...
from memory I think it was 8.5ltrs..
is it defo 10ltrs to fill it >?
and has anyone got a link where I can buy a replacement gearbox oil filter ?
thanks
The fluid coming out of the drain over the tower tube does not mean its full!
I put at least another ltr in and maybe 2 in mine as it launches hard on slicks
Old 22nd September 2018, 07:34 PM   #23 (permalink)
dudersvr's Avatar
thanks
Nissan do not supply a replacement filter (wonder how they change it ???)
AFAIK only Litchfield supply filters, the pan filter is Dodson as is the round filter deeper in the box, they supply a reusable Dodson mesh filter which is better value, but the pair are over £200, nearer £250 retail if I remember correctly. The flat pan filter is easy enough to open up and clean the mesh inside then re flatten the flange back together.
nick the tubman likes this.
Old 26th September 2018, 09:55 PM   #24 (permalink)
Jnin is unaware they can edit their status
I flushed my oil a few months ago. Used Motul. Cheap and very similar to Nissan’s stock gearbox oil from what I was told
Jnin is offline   Reply With Quote
Old 7th October 2018, 04:01 PM   #25 (permalink)
charles charlie's Avatar
Originally Posted by Jnin View Post
I flushed my oil a few months ago. Used Motul. Cheap and very similar to Nissanís stock gearbox oil from what I was told
Given how poor Nissanís original fluid is with regards heat resistance Iím not sure thatís a good thing if itís true.
Afaik all aftermarket fluids exceed Nissanís OEM fluid.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 8th October 2018, 03:16 PM   #26 (permalink)
Cardiff R33 is trying to resist mods
Cardiff R33's Avatar
TBH I Cant believe these cars done come with coolers for DCT, I used the Pentosin Racing one as already blew a clutch seal with the crappy Nissan stuff.
Anyone regularly going on track needs a cooler IMO
Cardiff R33 is offline   Reply With Quote
Old 8th October 2018, 06:22 PM   #27 (permalink)
dudersvr's Avatar
They do come with a oil to water cooler dude, it heats the trans up and tries to cool it, the heating up works extremely well the cooling not so much !!!! Its using the engine coolant BTW. Nissan do not seem to acknowledge a problem hence Nismo say the diff needs cooler for track work as the diff also gets very hot apparently.
Old 10th October 2018, 11:57 AM   #28 (permalink)
nick the tubman is feeling very pleased !
nick the tubman's Avatar
Cars owned: R35 GTR `10. R33 GTR v-spec Road & Track. R33 GTR Race Car
managed to get 9.5 ltrs in the gearbox... you put in 8.5, the run the car for a couple of minutes,, then top it up again.
the filter was spotless... very surprised. was expecting at least something to be on there..
both diffs done as well.
TBH, considering the amount of trackdays and trips across Europe etc, about 9,000mls in between changes, the oil in all 3, seemed to be in very good condition. still clear and smelt as new.
gone for the Motul Competition stuff this time
its Blue in colour - not seen that before.
I will let you know how it gets on temp wise compared to the standard stuff.
dudersvr likes this.
GTR = More smiles per mile, than any other...
nick the tubman is offline   Reply With Quote
Old 12th October 2018, 11:54 AM   #29 (permalink)
e36er is unaware they can edit their status
Originally Posted by dudersvr View Post
You left out one of the best and the cheapest
Millers DCT oil
https://www.opieoils.co.uk/p-89662-m...f-dct-dsg.aspx
That stuff?
e36er is offline   Reply With Quote
Old 15th October 2018, 09:58 AM   #30 (permalink)
have to say since the oil changes, gearbox is smoother now, especially from cold.
Tags
dct, fluid, hks, motul, pentosin
