GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - 1050cc injectors and induction kit
Old 19th March 2018, 03:44 PM   #2 (permalink)
charles charlie
charles charlie's Avatar
You're going about this all wrong.
Folks upgrade injectors because they install larger intakes that cause the oem injectors to max out, risking the car running lean under high load.
Generally you don't install injectors first.
Here's a sensible idea.
Decide who you want to map your car and what your goals are.
Then ask them for their recommended parts list to achieve said goal.
But yes you can run a stage 4/4.25 with panel filters alone, however you've been asking questions about BOVs and intakes with regards sound, so I'm not sure that you know what you want tbh.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
