Aftermarket oil cooler location poll - Page 3 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
View Poll Results: Where have you mounted your oil cooler?
Behind PASSENGER side of bumper (behind indicator on 33) 77 33.19%
In the centre by the IC and rad 94 40.52%
Behind Drivers side bumper (near the BOV's) 61 26.29%
Voters: 232. You may not vote on this poll
Old 2nd May 2010, 03:56 PM   #41 (permalink)
james1067906 is somehow in the possession of 3 gearboxes :/
james1067906's Avatar
I would love to, unfortunately the car is in Cyprus and i'm in Arizona until July, with no pictures of it on my laptop :/
james1067906 is offline   Reply With Quote
Old 4th May 2010, 02:22 PM   #42 (permalink)
chippy is unaware they can edit their status
chippy's Avatar
Cars owned: R33 GTR
when you have the cooler mounted with the fittings at the top does this not trap some oil when doing oil change ?
(as in pics above)(GTR--J)
chippy is offline   Reply With Quote
Old 4th May 2010, 10:55 PM   #43 (permalink)
Marko R1 is happy to have his old GTR back!
Marko R1's Avatar
Cars owned: no.60/100 Australian Delivered R32 GTR
That is a good point, apparently the r35gtr has a similar issue and needs a bung on the factory oil cooler. I decided to leave my oil cooler off as I have the rips sump which means my oil capacity has almost doubled to 7ltr. If I do some track work I will be fine as we have 20min sessions.
Btw - what is a safe oil level temp? i.e. At what temp does engine oil lose its lubrication qualities?
Marko R1 is offline   Reply With Quote
Old 5th May 2010, 07:06 PM   #44 (permalink)
jdmchrist is wtb other parts!!
Cars owned: r32gtr
same question as marko, anyone got the answer??
jdmchrist is offline   Reply With Quote
Old 6th May 2010, 12:13 AM   #45 (permalink)
Marko R1's Avatar
If my memory serves me right, I think 130degrees is the limit?
Old 16th May 2010, 08:27 PM   #46 (permalink)
leeroy_25 is Chuffed to nuts the RB30 lives!
leeroy_25's Avatar
I Just mounted mine today on an R33.. Between the AC and intercooler!
Quick question on oil coolers in that position it makes it very hard to pre-fill the cooler with oil. When filling the oil is it best to key the car over for a while with the ingition module unplugged so it doesn't fire to get oil through the cooler and top up the engine before starting. Likewise when doing a service should you drain the cooler and follow the same process. For me I will be running in on mineral oil to start and I gather it's not wise to mix it synthetic and mineral oil when I come to put my proper Silkolene Pro S in.
Lee
leeroy_25 is offline   Reply With Quote
Old 10th November 2010, 07:50 AM   #47 (permalink)
comzilla87 is toying with the idea of 4wd
comzilla87's Avatar
None of the above. I run a heat exchanger on the radiator.
The oil gets heated up by the water and up to temp faster, but the radiator is big enough to keep both water and oil temps around the same, max ive seen on both temps so far on the track is 180 degF, or around 80 degC.
I also have the option to run a radiator blocking plate that i put in in the winter.
It helps get the temps up when driving on the road/track if its too cold outside, and only takes 10mins to put in or take out.
comzilla87 is offline   Reply With Quote
Old 11th November 2010, 03:25 AM   #48 (permalink)
Cars owned: r32gtr
is it a custom rad??
Old 11th November 2010, 03:32 AM   #49 (permalink)
comzilla87's Avatar
Yea i got it from the states, its a C&R radiator made for a nascar.
It is the same as this pretty much, just new, not 2nd hand.
30" C&R VISTEON ALUM RADIATOR W/OIL COOLER NASCAR RACE: eBay Motors (item 140438209614 end time Dec-06-10 18:26:22 PST)
Old 11th November 2010, 03:34 AM   #50 (permalink)
Cars owned: r32gtr
i presume that its was not a direct fit?
Old 11th November 2010, 04:32 AM   #51 (permalink)
comzilla87's Avatar
It required a little bit of modification to make it fit but it wasnt too bad. nothing a little 4" grinder couldnt fix. no mods on the intake side, but required on hot side just under the headlight. Also i just bolted it to the radiator support panel at the top.
Old 13th November 2010, 10:36 AM   #52 (permalink)
nozza1 is Wanting to work on his gtr!!!!!
nozza1's Avatar
Cars owned: Honda civic LSI - Audi-Ur Quattro - Lancia Intergrale EvoII - Kawasaki Ninja zx7r - R34gtr V-Spec - P2 v70 D5
So, am l right in thinking, if l chose to fit a oil/water heat exchanger, l don't need a separate oil cooler?
AUDI QUATT TURBS 20V, LANCIA INTERGRALE EVO 2, GOLF TDI ANNIVERSARY CHIPPED 250 BHP, KAWASAKI ZX7R
nozza1 is offline   Reply With Quote
Old 13th November 2010, 07:06 PM   #53 (permalink)
comzilla87's Avatar
Yea that is correct. Helps keep everything in one place and not too many lines going to the front too. Also you could keep your a/c if you like.
Old 11th April 2011, 09:12 PM   #54 (permalink)
adamsaiyad is running the beast :)
Banned
Originally Posted by R.I.P.S NZ View Post
By far the best all round system we've used is the heat exchanger in the bottom tank of the radiator as per the R34 Stealth Bomber, oil temps come up quicker and I've never been able to get the oil temp more than 10 deg higher than water temp, they are compact, simple and have short lines, no worries with stones etc either.
The downside is you have to buy a 90mm thick radiator at the same time and although they seem expensive initially, once actually in the car, they work out well against buying a big rad and oil cooler and installing both properly.
Rob
Hi Rob would you mind spec'ing up some quotes im sure some users on here would be dead keen to have something a bit more one off like this, and with temps never more the ten degrees then water temps sounds like its a more viable alternative to a external air oil cooler ?
would love to hear back from you im sure forum members would be more then happy to at least have peice of mind on costing ?]
Thanks
adam
adamsaiyad is offline   Reply With Quote
Old 11th April 2011, 09:15 PM   #55 (permalink)
Banned
Ps all the guys aiming for low oil temps need to know this, oil past its max temp point is no good but oil below its normal running temp can also have its negatives, good oil temp meaning not too thin not too thick means more hp, yes thats right a good heated oil at optimum running temp means that it has a chance to release some few extra Horses in a engine too thick and its slows everything down.... Just a thought
Old 22nd April 2011, 03:30 PM   #56 (permalink)
R32TT is ...in surgery
R32TT's Avatar
Cars owned: GTR R32
Here is an option that PWR do.
This is a 57mm thick radiator - side flow, twin pass.
In the passenger side end tank is an oil cooler with -10 fittings.
On the drivers side is a Power Steering cooler built in with -6 fittings.
Optioned with a SPAL 16" fan.
Its not quite as tall as the stock radiator, so you need to modify the bottom mounts to lift it all up by about 30mm. Its also mighty close to my ATI balancer, but you'd have more room with a stock balancer.
....hmm.. just tried to post a photo for you all, but the board come back saying I need to have 15 posts.. doesn't seem very helpful. Odd because I have uploaded a photo before some months back. Is there another way to ge the photo up?
R32TT is offline   Reply With Quote
Old 26th April 2011, 10:37 AM   #57 (permalink)
35 row on -12 lines in front of rad, fed via a thermostatically controlled sandwich plate with stock Modine oil to water cooler removed.
Best Regards,
Chris Wilson.
Old 26th April 2011, 08:00 PM   #58 (permalink)
Banned
Do you mind taking a pic of the oil filter adapter and where it mounts to the block, and where the lines feed and return back off the where the stock modine oil cooler assembly was ? would be great for some ideas etc etc, ps is this kit available on a site and what price ?
Old 26th April 2011, 08:10 PM   #59 (permalink)
Not sure if I have any detailed pics of the adaptor with the sandwich plate on it. It's an off the shelf UK one, with a `stat, mounted on a self made male / male block adaptor sleeve. Everything except the adaptor is off the shelf stuff, found in the workshop.
Best Regards,
Chris Wilson.
Old 20th June 2011, 08:56 PM   #60 (permalink)
nozza1's Avatar
other than being a pain in the arse to pre-fill, positioning the fittings at the bottom is okay?
Originally Posted by STBSO1985 View Post
