GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - r33 gtr hks v-cam build burning oil
Old 29th March 2018, 12:15 AM   #1 (permalink)
rageyourdream
rageyourdream is unaware they can edit their status, no I am not.....
Hi all
I noticed lately I am going through quite a bit of oil, I have checked for leaks etc and can see no signs of any and logged my oil pressure which seems perfectly consistent
I think I am getting oil bleed through the turbo exhaust BB seals under WOT max boost as when I shift I get a puff of white smoke out the back, this is the only time it happens or the car displays any smoke at all
I have a full HKS engine, with v-cam, hks oil pump, 2.8 stroked, hks head and hks 2530-KAI turbos running 700bhp
oil pressure reads about 8 bar on WOT shift and my average oil pressure while driving normally is about 6 bar with idle being 3 bar, using FUCHS 10w60 oil
I was wondering if maybe I need to add a smaller restrictor in the turbo oil feed as it was allowing to much oil through from the pressure, I think the 2530-kai come with 1mm restrictor banjo bolts, perhaps I should change to 0.8mm ?
any insights would be greatly appreciated, thanks in advance all
rageyourdream is offline   Reply With Quote
