#101 (permalink) |
RB28
is @RB28V on Instagram
Cars owned: R34 GTR Vspec RB28 Vcam
Yeah quite a few features are out there. 1320 Video did one too. Some pretty cool cars on the way from Japan, including the Midnight Purple Z-Tune and a HKS Zero R
My HKS 2.8 build thread - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#103 (permalink) |
RB28
Yes, Apparently all 3 Mines Vspec N1 Demo cars have them and so does the Millenium Jade VspecII Nur Demo car, the one that Mines always used at Nismo Festival and R's Meeting.
#104 (permalink) |
RB28
I was able to get my hands on these out of production Tein RS Circuit Masters. There are rare and are hard to acquire. The spring rates are F12K R10K with helper spring setup. Fully damper and rebound adjustable. The cool reservoir oil canisters look great. The shock cylinders are fully anodized aluminum in Tein green. The surface is textured with fine vertical striae for a more 'upmarket' feel. The strut tops are a bit weathered because they are 'used' afterall.
They will be overhauled and revalved in custom Racepace spec by Fulcrum in QLD who is the official Tein distributor in Australia. Custom Eibach springs and custom top hats will also be added. The Racepace suspension setup is proven on a number of competitive Targa and circuit cars.
My HKS 2.8 build thread - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RB28; 30th October 2019 at 12:27 AM.. |
#105 (permalink) |
RB28
Ive decided to delete the Hicas system on my car when the Teins go in. Wasn't a big fan of the rear moving around when I was going around a corner at 140kph
![]() Other aftermarket suspension components on the car include: -Nismo Upper Circuit Link Set -Nismo Sway bars (Front & Rear) -Nismo Upper Link Set (Front & Rear) -Nismo Tension Rod Set -Mines Titanium Strut Brace RacePace will add -RacePace Hicas Delete Kit -Tein RS Circuit Masters (Revalved with Custom Eibach Springs) The Tein RS, aka 'Circuit Master; Super Racing Spec', has been out of production since 2006-2007. They were the top of the line in the Tein catalogue for production cars at that time. In some ways, I feel that the materials used and the way it was manufactured surpass what's commonly available today, even the premium priced shocks. Details of the RS are listed below (sourced from US based my.is forum in 2002) MATERIALS AND FACTS: DAMPING MECHANISM: 45mm diameter pistons Double shim stacks (near unlimited tunability with knowledge of shim valves) Two 'special form' adjustment needles SHOCK/RESERVOIR BODY: Monotube shock body 53mm outer diameter Aluminum alloy (A7050) seamless tube, CNC'ed, green (hard?) anodized Inner tolerances: diameter: ±5µm roughness: ±1.6µm Reservoir body interior is PTFE (Teflon) coated CNC'ed aluminum alloy eyelet, Tein rubber bushing, steel pivot SHOCK SHAFT: 14mm diameter Chromoly (SCM435) steel, Ti-N coating SHAFT SEAL/GUIDE: WRC spec PILLOWBALL MOUNT: Aluminum alloy, CNC'ed, Powdercoated (gold) SPRINGS: Main and helper Steel, ground and tapered, enameled 12K front, 10K rear SPRING PERCHES: Aluminum alloy, forged and machined SETTINGS: -34mm front, -12mm rear (easier measured as 335mm both from the center of the wheel to the fender lip, front and rear) 10 clicks rebound front 10 clicks compression front 10 clicks rebound rear 13 clicks compression rear Will post pictures of all components when the Teins have been finished ![]()
My HKS 2.8 build thread - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RB28; 1st November 2019 at 05:19 AM.. |
Bookmarks |
Tags |
bnr34, gtr, hks, mines, rb28 |
Thread Tools | |
