200MPH? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree2Likes
Old 9th April 2019, 08:21 AM   #1 (permalink)
m1ac_drew is back in a ten second car!
m1ac_drew's Avatar
Cars owned: DBA 4.25 R35 GT-R. Previously 2 x Skyline R33 GTS 2.5t
200MPH?
Hi guys and gals,
I just picked up my 4.25 R35 yesterday and I'm wondering if it is good for 200MPH? Has anyone tried to reach this milestone on track or on the Autobahn? If it's not, what level of modification would be required?
I'm curious, since I know 200 was breached some time ago by heavily modified R34s, and maybe even before?
m1ac_drew is offline   Reply With Quote
Old 9th April 2019, 10:48 AM   #2 (permalink)
Evo9lution is hoping ...
Evo9lution's Avatar
To reach 200mph, the car needs to have the rev limit raised by (I think) 250rpm or else the car will hit the limiter at 197mph.
Would a stock GTR that has had this change done (not really stock by then but we can ignore the semantics) be able to reach 200mph? Possibly, given ideal circumstances ...
In reality it is very hard to achieve in anything short of 900BHP unless you have a very clear, long and straight piece of road. Autobahns are actually very hard to achieve this (195 mph - GPS verified so actually over 200mph on the clock) is the fastest I have achieved on the road (not been to a runway long enough) and autobahns are often very hard to achieve it as they are often two-lane (far from ideal), are rarely empty and have bends on them (at 180mph, a shallow bend feels quite sharp). A dusk / dawn run is a consideration but traffic often prevents this. A night time run may be better for traffic but not being able to see where the road goes while doing a double-ton is far from wise!
So, in short, you probably need a lot of power and/or a very long, straight and clear piece of tarmac!
Not Fast but definitely Furious!!!
Evo9lution is offline   Reply With Quote
Old 9th April 2019, 10:57 AM   #3 (permalink)
m1ac_drew's Avatar
Thanks, that's very informative!
I'm also wondering about the back straight of the Nordschleife, the Döttinger Höhe, but it's probably not long enough.
Just out of interest, how does one raise the rev limiter? And does this do any harm to the car? I understand that hitting (or spending considerable time on) the limiter is not in general a good thing, since it is there to protect the engine.
Old 9th April 2019, 11:14 AM   #4 (permalink)
Evo9lution's Avatar
Nope it's not (not in a 4.25 anyway - it's also partly uphill)! Would have to be done on a track day as well as during a TF you don't drive anywhere near the full straight.
Should be possible from a simple tweak using EcuTek or Cobb (assume you'll have one or other of those on a 4.25; unlikely that you're running an a/m ECU, but if you are, same deal; tweak to the map).
Raising the rev limiter isn't a huge deal unless you plan on bouncing off the rev limiter often ... If you only used it to try to get to 200 mph in 6th gear you'd likely never even use that extra. Probably worth shifting about 6200 rpm if on normal turbos as they run out of puff so the additional 250 rpms would not be affected if you do that.
Old 9th April 2019, 11:16 AM   #5 (permalink)
m1ac_drew's Avatar
Cheers, my expectations have now been set accordingly!
Old 9th April 2019, 10:19 PM   #6 (permalink)
WingedBeast1968 is still here
WingedBeast1968's Avatar
Cars owned: CBA R35 GT-R Black Edition Nav MY10
I know of someone who had the speedo reading 206mph
Which was probably a lot less than that, but they read slightly high throughout the speed range.
To do 30mph, my clock reads around 35mph. Stock size tyres too.
R35 GT-R Black Edition with Navigation
Nismo CS ECM - Nismo TCM - Airtec IC - GFB - Russ Fellows + Carbon tips
Oo oO
Old 9th April 2019, 11:00 PM   #7 (permalink)
m1ac_drew's Avatar
My Qashqai's speedo also exaggerates by around 10%. Is there any way to recalibrate the speedo on the GT-R? On my bikes I have a device called a SpeedoHealer to do this.
Old 14th April 2019, 02:37 PM   #8 (permalink)
dudersvr is A Legend
dudersvr's Avatar
By law speedos have to over read, tyre sizes can effect either way, mine was 2mph out at 194 but got this on a road in serbia known as the MMM23
Old 14th April 2019, 05:18 PM   #9 (permalink)
Will64 is unaware they can edit their status
Will64's Avatar
Cars owned: Noble m12, Audi b7 Rs4, Mercedes C63, Range Rover Evoque, R35
So do I, maybe the same guy! Crazy speed and it was on a public road.
Will64 is offline   Reply With Quote
Old 17th April 2019, 02:45 PM   #10 (permalink)
Mr.B is Loving LM 4.25
Mr.B's Avatar
Here's a nice piece of road.
2 lanes.
From 1 to 3 is 4.3 miles long.
From 2 to 3 is 2.8 miles long.
RB28 likes this.
Mr.B is offline   Reply With Quote
Old 17th April 2019, 06:58 PM   #11 (permalink)
Attachment 250641
With negative manifold pressure too
Oo oO
Old 17th April 2019, 06:59 PM   #12 (permalink)
2 lanes.
Where is this?
Oo oO
Old 17th April 2019, 10:07 PM   #13 (permalink)
Mr.B's Avatar
Sent you a PM.
You can be at 120mph at point 2, so I’ve been told.
WingedBeast1968 likes this.
Old 2nd May 2019, 10:15 PM   #14 (permalink)
gtr mart is fast and loud
gtr mart's Avatar
200 in a 4.25 is theoretically possible in a 4.25 but tricky and takes a while.
I've bumped power a bit since and it will monster it. I'm looking forward to popping my 200mph cherry at the GTRDC runway day in a week or two.
2017 Japanese Drag Series (JDS) street Champion
2018 GTRDC TDOAR Sprint Champion
2019 Car Culture Dyno Day Shootout Winner
Build thread:
Items for sale:
Old 3rd May 2019, 11:15 AM   #15 (permalink)
OhhEnnEmm is unaware they can edit their status
Keep us updated on whether or not you manage it! Best wishes pal
OhhEnnEmm is offline   Reply With Quote
Old 3rd May 2019, 02:00 PM   #16 (permalink)
Takamo is Living the Dream... Alhumdulillah (thanks to God)
GTR Register Trader
Takamo's Avatar
Cars owned: R32 GTR, R33 GTR, R34 GTR, R35 GTR and many many more!!!
If it's a stage 4.25 then 200mph is possible maybe even 205mph
Rabs Car Alarms 0121 771 1511 or 07973733441
Facebook:
Official Dealers of:
Autowatch Ghost Immobiliser
Smartrack Trackers, Toad, Scorpion & Blackvue
Takamo is offline   Reply With Quote
Old 3rd May 2019, 02:31 PM   #17 (permalink)
Evo9lution's Avatar
Only if the rev limiter is increased ...
Old 8th May 2019, 07:35 PM   #18 (permalink)
Guy
Guy is here.
Cars owned: Have owned R32/33/34/35, Porsche 964/993RS/996GT2 Ruf/997GT2, plus some Lambo/Ferrari/Alpina/BMW etc
Not sure how relevant this is, but;
Many years ago I took my R34 GTR to 199mph on GPS on the autobahn, with five big blokes in the car, whilst on a road-trip to watch the 24 Hrs at the 'ring with the Falken R34s. That car dynoed 680bhp at the crank.
I took my stock R35 GTR easily to about 185mph several times, but never found the road conditions to go faster. it certainly had more in it.
If you have the gearing and power, the main issue is about having enough distance. When you are already travelling at near 200mph you are covering a lot of ground as the speedo creeps up the final 10-15mph. My old Ruf/Porsche would reach 200mph in about 1.5 miles from a standstill, but needed another 1.5 miles to add the next 15-20mph.
Guy is offline   Reply With Quote
Old 8th May 2019, 07:54 PM   #19 (permalink)
dudersvr's Avatar
And theres the AMS car hitting 255mph in 1/2 mile
Old 8th May 2019, 08:13 PM   #20 (permalink)
DocT is Litchfield LM1 storm trooper
This thread caught my curiosity, just calculated with the overdrive 6th in my Dodson gearset I have a 282 mph potential....wonder if 1200bhp and 8100rpm will get me anywhere near.
DocT is offline   Reply With Quote
Similar Threads
Cosworth finaly PROVEN over 200mph SteveN Non-Skyline / GT-R chat 11 17th September 2004 08:14 AM
"620bhp" "200mph" R32GTR "V-Spec" for sale... SteveN General Nissan Skyline Chat 4 11th June 2004 09:00 AM
200mph Speeding Guy General Nissan Skyline Chat 33 28th January 2003 07:03 PM
200MPH racing on M25? Blow Dog General Nissan Skyline Chat 56 27th January 2003 08:17 PM
Ronnie over 200mph Robinsongtir General Nissan Skyline Chat 70 13th October 2002 03:07 PM
