Help: GTR slow to start - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree5Likes
  • 1 Post By snuffy
  • 1 Post By Simonh
  • 1 Post By Takamo
  • 1 Post By snuffy
  • 1 Post By terry lloyd
Old 20th April 2019, 10:54 AM   #1 (permalink)
Daniil is Hey
Hi,
Hoping I can get some help from the community, Iíve noticed my R35 is becoming more slow to start, it will crack over for sometimes 5-7 seconds before starting.
I prime it when I first start it for 5 seconds to build oil pressure and it fires up fine, but the rest of the time it takes ages! Even if I prime it.
This can get quite embarrassing in public car parks when everyone is looking!
Anyone have any ideas what could be the cause? Or is this normal?
I have a 13 plate, litchfeild stage 2 with a complete straight through 90mm, previous owner even fitted a CKC Remote start up too.
Thanks.
Daniil is offline   Reply With Quote
Old 20th April 2019, 11:16 AM   #2 (permalink)
dudersvr is A Legend
dudersvr's Avatar
Get a log and ask Ian to look at it for you, maybe try plugs if its not had a set, is battery spinning it over fast.
Old 20th April 2019, 03:18 PM   #3 (permalink)
Ooo Matron !
snuffy's Avatar
Cars owned: GT-R & Fiat 500
Does it crank slowly ? It's most likely the battery is on its way out.
If it's the original one that it's 6 years old so I'd say time for a new one.
Simonh likes this.
MY2013 TCM
ACSpeedtech EcuTek RaceRom 5
Old 20th April 2019, 04:46 PM   #4 (permalink)
Simonh's Avatar
Cars owned: MY11 R35 Recaro
Battery on its way out is most likely
Simonh is online now   Reply With Quote
Old 20th April 2019, 05:47 PM   #5 (permalink)
Takamo is Living the Dream... Alhumdulillah (thanks to God)
GTR Register Trader
Takamo's Avatar
Cars owned: R32 GTR, R33 GTR, R34 GTR, R35 GTR and many many more!!!
Timing advanced or retarted, what's the mileage and is it modified
Rabs Car Alarms 0121 771 1511 or 07973733441
Facebook:
Official Dealers of:
Autowatch Ghost Immobiliser
Smartrack Trackers, Toad, Scorpion & Blackvue
Takamo is online now   Reply With Quote
Old 20th April 2019, 08:09 PM   #6 (permalink)
Daniil is Hey
Thanks for the reply, Had plugs changed on last service.
Strange itís fine sometimes, and others itís a pain to start
Old 20th April 2019, 08:12 PM   #7 (permalink)
Daniil is Hey
Thanks for the reply, honestly not sure if it turns over slowly.
It sometimes starts fine, other times a pain... does this still sound like a battery issue?
Old 20th April 2019, 08:13 PM   #8 (permalink)
Daniil is Hey
Not sure what the first but means... mileage is 47k, itís got a litchfield stage 2 and a straight pipe.
Old 20th April 2019, 09:02 PM   #9 (permalink)
GTR Register Trader
Takamo's Avatar
What fuel was your car mapped on because shell is differently mapped against like tesco or BP, Litchfields alter the degrees of timing to give best results so sometimes if you use different brands of fuel it may confuse the timing and that can cause delays in starting, worth asking Litchfields.
Facebook:
Old 20th April 2019, 10:41 PM   #10 (permalink)
Simonh's Avatar
£60 for a new battery, the most likely solution to your issue. It is where I would start.
snuffy likes this.
Old 21st April 2019, 08:37 AM   #11 (permalink)
GTR Register Trader
Takamo's Avatar
A low battery would not cause a delayed starting, it would sound like a lazy start like as if its low on power, if it's cranking at normal speed and sounds strong then its something else.
terry lloyd likes this.
Facebook:
Old 21st April 2019, 09:28 AM   #12 (permalink)
Ooo Matron !
snuffy's Avatar
Does it get worse the longer you leave the car ? So if you start it up, drive it a few miles and then stop, if you then restart it straightaway, is it okay then ?
If it's cranking slowly it will sound like it's labouring. If my battery is getting a bit low from it being parked for 3 or 4 weeks then it's slow to crank.
Simonh likes this.
MY2013 TCM
Old 21st April 2019, 09:29 AM   #13 (permalink)
Ooo Matron !
snuffy's Avatar
That's what I would do as well.
Or, charge the battery up and then try it. If it starts okay then it's almost certain that the battery is about to give up the ghost.
MY2013 TCM
Old 21st April 2019, 12:24 PM   #14 (permalink)
terry lloyd is ........
terry lloyd's Avatar
If its cranking ok its not the battery - could be a fueling issue weak mixture causes starting problems - I would would start with cleaning the MAF sensors, Stage 2 has K&Ns which come covered in oil this can coat the sensors - electrical spray works well just don't touch the wire in the sensor
Takamo likes this.
Similar Threads
URGENT HELP knocking from rear on slow corners in GTR richymotor General Nissan Skyline Chat 13 14th August 2012 09:21 PM
Slow idle - cold start issue? TPS? leeroy_25 Maintenance 1 14th December 2011 07:22 PM
Slow internet! HELP!!!!! V4 SKUNK Non-Skyline / GT-R chat 0 24th April 2007 06:42 PM
Help, slow motion drag footage ? cokey Non-Skyline / GT-R chat 2 14th July 2006 10:51 PM
SLOW SPOOL UP - ANYONE HELP??? TonyT1965 Turbos 25 2nd July 2005 10:30 AM
