Surface transforms ceramics - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree1Likes
  • 1 Post By jimbo1234567
Old 29th April 2019, 10:45 AM   #1 (permalink)
jimbo1234567 is unaware they can edit their status
fitted mine a few weeks ago and the front pads rattle in the calipers at slow speed over a rough road which is pretty annoying. im going to pull one of the pads out and compare the dimensions to oem and go from there. its not a problem I expected for that kind of price and I didn't want to change the car to make it in any way worse but this has. anyone else had this experience with them or can offer any solution ??? . apart from that 5 weeks in and im loving the car apart from the fuel bill.
andyevo likes this.
jimbo1234567 is offline   Reply With Quote
Old 29th April 2019, 10:47 AM   #2 (permalink)
andyevo is unaware they can edit their status
Fuel bill, canít be any worse than high power b5 can it?
andyevo is offline   Reply With Quote
Old 30th April 2019, 06:15 AM   #3 (permalink)
pwpro is exacting perfection at every opportunity
GTR Register Trader
pwpro's Avatar
Cars owned: Datsun 510 evo !!
just copper slip the back of the pads so they stick to the pistons rather than rattling about
a trusted source in the midlands for your cars appearance and care
pwpro is offline   Reply With Quote
Old 30th April 2019, 09:12 AM   #4 (permalink)
done that with some ceramic brake grease on install. its pretty sticky stuff
Old 30th April 2019, 02:23 PM   #5 (permalink)
terry lloyd is ........
terry lloyd's Avatar
Move the pin clip from the bottom to the top
Old 1st May 2019, 08:54 AM   #6 (permalink)
mine has them bottom and top already being a 2015
Old 14th May 2019, 12:15 PM   #7 (permalink)
so the problem is the pad dimensions and they are basically undersize causing them to move up and down when on a rough surface , I measured a gap of .635 mm between the pad and caliper on the surface transforms pads and .330 mm on the stock pads . you can actually grab the pad in the caliper and move it up and down. I need a solution to make the pad .4 mm longer by either welding a bead onto the pad then grinding it back or some kind of shim system to take the slack out. any ideas anywhere ??
Old 14th May 2019, 02:20 PM   #8 (permalink)
What make and model pad are you using?
Old 14th May 2019, 02:24 PM   #9 (permalink)
they will be the rsc1 pads that came with the kit, they are a much deeper pad that sticks a fair way out of the bottom/inside of the caliper as the front disc has a bigger swept area .
Old 14th May 2019, 02:25 PM   #10 (permalink)
https://surfacetransforms.com/nissan-gtr-brake-kits
Old 14th May 2019, 03:41 PM   #11 (permalink)
I know somewhere on the net there was some titanium shims for sale, could you not use something like that with the ends squared off at 90degrees rarther than just a flat shim?
Old 14th May 2019, 03:44 PM   #12 (permalink)
Other option would be to reline a set of std pads or have a custom set made if possible.
Old 14th May 2019, 04:07 PM   #13 (permalink)
the shims are great idea, any idea where you saw them ? I couldn't reline a std pad as its a different size and wouldn't sweep the part of the disc nearest the bell, for the price of the setup I think the quality control is terrible, ive emailed st yesterday but because im not the original purchaser I doubt ill get anywhere with them.
Old 14th May 2019, 04:38 PM   #14 (permalink)
I’ll try and have a dig around but I am sure other members will know where there from.
Initially I think they were made to reduce the effects of squelling
Old 16th May 2019, 02:07 PM   #15 (permalink)
L6DJX is reducing weight and getting stiffer ;)
L6DJX's Avatar
Cars owned: 2015 GTR Litchfield tuned
titanium works on facebook
Forged Engine and Dodson Gearbox @880bhp/745ftlb
Fully Stripped out w/ GT3 Rollcage &Tillet Carbon seats
Alcon SuperKit, with Project Mu H16-03 Pads
JRZ RS PRO- With full SPL bushings and Camber arms
Quaife front Diff
Nankang AR-1
L6DJX is offline   Reply With Quote
Old 16th May 2019, 09:48 PM   #16 (permalink)
cheers, im pretty dissoppointed that surface transforms didn't reply to me so ive engineered my own solution.id be well pissed if I had bought these new and paid someone to fit them. I knew id have no come back with them not being the original purchaser. fortunately I have my own fully equipped workshop so I have a great idea once the ramp is free.
Old 17th May 2019, 07:30 AM   #17 (permalink)
L6DJX's Avatar
the discs are great - as are the pads.
Surface transforms are a HUGE company and do not answer their emails.
If you ring their liverpool number and ask for sales or support you can get through to them to talk
Quaife front Diff
Nankang AR-1
Similar Threads
CARBON CERAMIC BRAKES - Surface transforms front + rear L6DJX Private: For Sale - R35 GT-R PARTS ONLY 18 9th March 2019 05:59 PM
SVM Surface Transforms Ceramic Discs JoGoGTR Exhausts, Brakes, Wheels, Tyres and Suspension (GT-R) 11 27th November 2016 08:46 AM
Anyone Using Surface Transforms Ceramic Discs? Mr.B General Nissan R35 GT-R Chat 20 4th June 2016 11:07 AM
CCC - Cage, Carbon and Ceramics Guy General Nissan Skyline Chat 36 11th July 2003 12:11 AM
Going from stock ceramics to steel (GTR33) senna Turbos 2 24th September 2002 03:16 PM
