Flat spot around 5000rpm in 5th - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 20th May 2019, 07:41 AM   #1 (permalink)
gavm is wondering how I ever lived without a GTR
gavm's Avatar
Hi All,
Just did a airfield day and had a bit of a weird issue. Going through the gears the car pulls hard until it hits around 155mph in 5th when it just stops accelerating (occasionally the revs also drop off like I've taken the foot off the pedal). If I back off the throttle briefly (1 sec) it then pulls hard again all way until I run out of road. Happened every time. The car wasn't overheating and the temps were all normal. It's a Stage 4.25 btw and cobb tuned although I'm probably moving away from this. I'm going to book it into Litchfields to see what they think.
I'm thinking overfueling maybe and a remapping needed? Any other ideas?
gavm is offline   Reply With Quote
Old 20th May 2019, 08:24 AM   #2 (permalink)
charles charlie's Avatar
If you'd logged your runs you'd most likely have seen teh ECU retarding timing due to knock.
At those high engine loads the most likely reason is high IATs.
I had the very same experience at last year's event and with Litcho's Race intercooler. I logged each run and Iain checked over the logs and they showed retarded ign timing in 5th and 6th due to knock.
Mine is a built engine so nothing to worry about nbut on a standard engine I'd be wary.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 20th May 2019, 08:39 AM   #3 (permalink)
gavm's Avatar
Cheers for that. I'll get it over the Litchfields before I look at doing any more high speed runs!
Old 20th May 2019, 08:43 AM   #4 (permalink)
To be honest there isn't much they can do other than suggest a bigger more efficient intercooler to keep your IATs lower and a dyno log to check your tune.
Your standard ICs were never meant to handle a stage 4.25 at full WOT on a runway high speed run!
Also without any logs to check over they can only place an educated guess on what caused the flat spot. That said I'm 99.9% sure it was high IATs.
Be reassured though that as long as your car is running a safe, well mapped tune, teh ECU is doing exactly what is was meant do to keep your engine safe.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 20th May 2019, 11:09 AM   #5 (permalink)
terry lloyd is ........
terry lloyd's Avatar
It sounds like you ran into one of the cobb safety trips - it will cut the throttle until you lift off to under 25% throttle for a set time @ 1-2 seconds, then it will reset - if you had the accessport connected it would have told you why it tripped - stft / knock / temps etc been awhile so there maybe a few more safety trips added
Old 20th May 2019, 04:56 PM   #6 (permalink)
Papa Smurf is nurburgringgtr
GT-RDC Founder Member
Papa Smurf's Avatar
Cars owned: Nissan MY18 Track Edition Litchfield GT-R, Golf R, Dancing Donkey 458
Strange question, but what sized tyres are you running front and back?
Papa Smurf is offline   Reply With Quote
Old 20th May 2019, 08:33 PM   #7 (permalink)
gavm's Avatar
Front: 265/35/20
Rear: 305/30/20
Similar Threads
super flat spot snow Maintenance 4 17th January 2007 10:46 PM
front mount intercooler flat spot Damian666 Tuning: General 4 3rd January 2007 03:24 PM
Please Help.......5000rpm and flat spots on my gts R33Troy Tuning: General 7 19th November 2005 09:39 AM
Flat Spot at about 6000RPM zeroreality Tuning: General 0 5th February 2003 01:16 PM
Flat Spot psa198 Tuning: General 3 11th December 2002 02:33 PM
