1200 BHP project build - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan GT-R > R35 GT-R Projects
Like Tree17Likes
  • 5 Post By Hugh Keir – PTSYS
  • 1 Post By GTRNICK
  • 1 Post By Hugh Keir – PTSYS
  • 1 Post By Tin
  • 1 Post By motors
  • 1 Post By dtox
  • 1 Post By Gtr76
  • 2 Post By Hugh Keir – PTSYS
  • 3 Post By Hugh Keir – PTSYS
LinkBack Thread Tools Display Modes
Old 25th May 2019, 05:50 PM   #1 (permalink)
Hugh Keir – PTSYS is getting old
Single Product Trader
Hugh Keir – PTSYS's Avatar
Cars owned: R32 GTR Race Car
Bought my MY10 R35 GTR in 2014.
In 2016, JM Imports built the car from a stage 2 into 1000 BHP daily driver.
The basic ingredients were as follows:-
Litchfield Borg Warner 7163 Turbo Kit
Short engine
Willall sump
CNC Stage 2 Heads with Ferrea big valves.
Gas flowed Greddy inlet plenum
AT Power throttle bodies
Custom intercooler piping and cold air inlets
Assembled engine
The engine Dyno’d at 842 Wheel BHP at 6,700 RPM with 1.8 bar boost on pump fuel, so something around 1000 engine BHP.
I mostly use the car as a daily driver, but occasionally use it in anger at the likes of TOTB where it has run 9.72 seconds Ό mile at 146 MPH using E50 fuel.
I have been feeling a tinkering itch and wanted to see if it was possible to extract a bit more power from the existing set-up.
Back down to JM Imports and the engine is currently out.
Here is one of the existing Litchfield 71mm compressor covers fitted to the Borg Warner turbos.
Here is the new larger compressor cover I am planning to fit to test whether there is more power available from the 7163 turbos.
First compressor cover mock up on the engine.
Compressor cover under construction at JM imports.
Excited to see what the outcome is.
Watch this space as the build continues.
paulmc, GTRNICK, Tin and 2 others like this.
DSC Sport equipped R35 launching at TOTB
name="wmode" value="transparent"> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Hugh Keir – PTSYS is offline   Reply With Quote
Old 25th May 2019, 07:36 PM   #2 (permalink)
GTRNICK is Chillin
GTRNICK's Avatar
Cars owned: Porsche 997 Turbo, U.K. R34 GTR V-spec Black, New Smart
Lovely car and awesome project. I think if I had an r35 I’d go to JM.
Hugh Keir – PTSYS likes this.
“Don’t mistake my kindness for weakness. I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me!”
GTRNICK is offline   Reply With Quote
Old 26th May 2019, 01:01 PM   #3 (permalink)
JM Imports have lots of big power cars under their belt Nick, so once you downsize your portfolio, would be definitely something to consider.
GTRNICK likes this.
Old 26th May 2019, 02:39 PM   #4 (permalink)
GTRNICK is Chillin
GTRNICK's Avatar
Exactly my thoughts.
Look forward to seeing yours running
Old 26th May 2019, 05:54 PM   #5 (permalink)
Tin
Tin is modded out.
Tin's Avatar
Lovely setup, didn't realise you were running 7163s, interested to see what else can be pushed from them
Are you running Syvecs or Ecutek?
Old 29th May 2019, 07:56 PM   #6 (permalink)
I am on Syvecs Tin.
It's quite hard to judge what is possible from different Turbo setups.
On my R34 GTR, I had several different turbo setups. Finally, I went for small turbine housings which were an option on the HKS 3037S setup I was running.
There was a suggestion that I had gone too far, yet the car was easy to drive and would pull 156MPH on the 1/4 at TOTB.
The above is a bit of a trial the other way going for a bigger more open compressor housing.
I am pretty confident it will lift the power, but less certain how it will affect the spool.
Old 31st May 2019, 07:59 PM   #7 (permalink)
motors is unaware they can edit their status
motors's Avatar
Looking good Hugh, JM always do a great job cant wait to see results with turbos. May give me ideas for the future
motors is offline   Reply With Quote
Old 31st May 2019, 09:40 PM   #8 (permalink)
dtox is unaware they can edit their status
This setup looks unreal I can't wait to see this at TOTB on 27th July
have to let me know what them turbos are like. Bet they spool fast
dtox is offline   Reply With Quote
Old 31st May 2019, 11:53 PM   #9 (permalink)
GTRNICK is Chillin
GTRNICK's Avatar
These turbos will spool great. My 1 single 9180 spins up quick lol
Old 3rd June 2019, 06:06 PM   #10 (permalink)
Time will tell if the turbos work well with these compressor covers dtox.
I will end up with something similar to the Garrett GT3076R Turbocharger wheel sizes, which I believe is the turbo that AMS use in the Alpha 10 kit they sell.
Hopefully they will retain the good spool that the EFR turbos are known for.
Not experienced any other EFR turbos Nick, fingers crossed since there is a ton of work to modify the compressor covers and then plumb the intercooler in.
Am changing to a slightly smaller inlet plenum at the same time, so plenty to do for the JM Import team.
GTRNICK likes this.
Old 8th June 2019, 05:39 PM   #11 (permalink)
Wanted to update you with a little more progress on the modifications to the Borg Warner EFR turbos.
Some more mocking up on the Drivers side Turbo.
Great care being taken to keep the compressor outlet bends flowing smoothly and minimise direction change while allowing the gasses to expand.
First mock-up on the passenger side
Final mock-up prior to splitting the outlet pipe to aid installation.
The previous Turbo inlet pipe was limited to 2.5" at the Turbo.
The new 4” Turbo inlet piping is planned to run forward to the front of the car to improve air flow to the Turbo, which will hopefully lift power further.
Old 8th June 2019, 07:53 PM   #12 (permalink)
Gtr76 is unaware they can edit their status
Nice setup! Will be very interested to see how much more you can push out! Keep us updated?
Gtr76 is offline   Reply With Quote
Old 7th July 2019, 09:01 AM   #13 (permalink)
archan is unaware they can edit their status
Any update?
archan is offline   Reply With Quote
Old 4th August 2019, 06:45 PM   #14 (permalink)
Apologies,
Been mega busy recently.
Good news is the build is well on the way to completion.
I went with the HKS 12 injector option for the plenum.
There are still some bits and pieces to be done over the next couple of weeks.
Thought you might like a sneaky peek at progress on the Dyno
The car is very easy to drive, with 900 Wheel ft lbs of torque by 4200 RPM.
Maximum power so far is 1025 Wheel BHP at 6640 RPM.
Depending on who's correction factor you look at, this is between 1205 and 1240 engine BHP.
Look forward to getting the final results in the near future.
matt j and GTRNICK like this.
Old 4th August 2019, 07:01 PM   #15 (permalink)
MR2Brett is unaware they can edit their status
MR2Brett's Avatar
Cars owned: Currently owned 2010 Gt-r r35, Porsche 944, seat Leon fr, Kawasaki zx10r, autotrail apache 700se
Wow neck breaking results, well done!
MR2Brett is offline   Reply With Quote
Old 4th August 2019, 08:14 PM   #16 (permalink)
GTRNICK is Chillin
GTRNICK's Avatar
Lovely jubbily. Bloody animal
Old 8th August 2019, 08:38 PM   #17 (permalink)
Final bits getting modified prior to mapping.
New upper intercooler to throttle body pipes.
New Airbox inlet
Fitted in place
Bellmouths on
Behind bars
Bit more mapping at the beginning of the week
Mookistar, Kieranrob and Chronos like this.
Display Modes
Similar Threads
Buzzy Build (Forged build) buzzysingh R35 GT-R Projects 49 31st December 2018 10:48 AM
B is for Build - YouTube build w/ R35 GTR DuncDriver General Nissan R35 GT-R Chat 2 11th December 2018 10:43 AM
My R33 GTR Project. Project "500" BHP big_jim Skyline / Stagea Projects 38 19th January 2012 12:10 PM
1200 bhp SPEC'd GTR ENGINE casanova Private: For Sale - R32, R33, R34 Skyline and Stagea PARTS ONLY 10 22nd August 2010 04:30 PM
Sumo Drag GTR ' FUUJIN ' gets 1200 bhp and 7.5 second spec (20/12/2008 @ 22:47:06) GTR-Dreamer General Nissan Skyline Chat 20 9th April 2009 04:30 PM
