R33 GTR ABS+4WD lights on - need help - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan Skyline > Maintenance
Like Tree1Likes
  • 1 Post By Jigen Daisuke
Old 6th June 2019, 10:01 AM   #1 (permalink)
Jigen Daisuke is unaware they can edit their status
Good Morning everyone,
I own a 1995 R33 GTR (non VSpec) and yesterday I noticed two warning lights popped up on my cluster: "4WD" and "ABS".
I'm from Italy, a country where you can't find any Skyline-experienced tuner, so I need some help to make a diagnosis
After searching on the net and on this forum I opened the trunk and watch for error codes on Attesa ECU:
-six slow flashes
-a short pause
-three fast flashes
-a long pause
After that the flashes looped the same pattern
Is it the "63" error code? (FR and RR G-Sensor 1 or 2 and circuit)
If so, I still don't know what does it mean and which parts I have to check to find out the problem...
May you help me, please?
Thank you
Jigen Daisuke is offline   Reply With Quote
Old 6th June 2019, 10:39 AM   #2 (permalink)
Site Admin.
Mookistar's Avatar
could simply be a bad earth, worth checking your earth straps
Autoguide.com
Old 7th June 2019, 08:21 AM   #3 (permalink)
Thank you for the suggestion!
Where are the earth straps you said?
Old 7th June 2019, 08:28 AM   #4 (permalink)
Site Admin.
Mookistar's Avatar
on the battery, in the boot and in the engine bay. Pretty easy to find, any black cable the connects to the body. Have you had work done recently?
Autoguide.com
Old 7th June 2019, 08:40 AM   #5 (permalink)
MS33 is unaware they can edit their status
MS33's Avatar
Have you checked the reservoir in the boot? Had the same thing a little while ago...low fluid.
MS33 is offline   Reply With Quote
Old 7th June 2019, 08:41 AM   #6 (permalink)
About 3 weeks ago the car had the coilovers changed...
I don't know if the problem may be related to this work
Old 7th June 2019, 08:48 AM   #7 (permalink)
lightspeed is Building a house
lightspeed's Avatar
Cars owned: Project BNR32
Check the wiring continuity from the G-sensor connector back to the Attessa ecu. At the same time check the g-sensor for the red stripe of death
Old 7th June 2019, 08:55 AM   #8 (permalink)
I checked the level and it's about 2 centimeters above the max (cluster on, engine off)
Maybe I have to check it with engine running...
EDIT: The fluid in the reservoir seemed to be of two different colours... Is it a problem?
Where is the G-sensor? How can I identify it?
Red stripe of Death?
Old 7th June 2019, 12:25 PM   #9 (permalink)
MS33's Avatar
Two different colours are normal also a 5mm gap, check the reservoir when the ignition is on, I seem to remember that's when to check the level. Personally I use the level when the engine is running and I haven't had the warning lights on again.
Old 7th June 2019, 01:42 PM   #10 (permalink)
Giò is unaware they can edit their status
between the front seats behind the handbrake.
On the sensor there is a strip, if it is red it is damaged
Giò is offline   Reply With Quote
Old 10th June 2019, 09:08 AM   #11 (permalink)
During the weekend I performed several checks:
-G-sensor ok (no red stripe of death )
-Some sort of oxidation on the ATTESA ECU bracket (not on the ECU itself) but apparently there is no leaking from rear wiper
-ATF level on reservoir is slightly above max when the engine is on
As a last try I disconnected and reconnected ECU plugs: the warning lights disappeared
It was a problem of electric contact on the plug, probably because of the age of the car... I will also clean the plugs with a dry cleaner for electronic boards
Thank you all guys for support
MS33 likes this.
