Tegiwa 3mm Inlet Manifold Plenum Spacer - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 4th July 2019, 07:58 AM   #1 (permalink)
PhilEvans64 is unaware they can edit their status
PhilEvans64's Avatar
I have a Tegiwa 3mm Inlet Plenum Spacer to fit and have been told the screws should be 3mm longer. Does anyone know the OEM thread spec please? Also, I assume the OEM gasket is removed, so exactly 3mm of additional screw thread length will be required? Thanks
PhilEvans64 is offline   Reply With Quote
Old 4th July 2019, 08:26 AM   #2 (permalink)
dudersvr is A Legend
dudersvr's Avatar
Why are you fitting this? Plenum to lower plenum are M6.
Old 4th July 2019, 08:37 AM   #3 (permalink)
Thanks for the info. I forgot to ask the original length of the screws and the type of head (hex, Philips, slot?) ? I am giving this a try for a small increase in inlet plenum volume to go with my Stage 4.25 plus water methanol injection. The spacer was about £65 and can easily be removed if no gain (or negative) on performance. They are a common mod in the US and Japan but I have seen no firm evidence of any performance gain?
Old 4th July 2019, 08:51 AM   #4 (permalink)
It is also supposed to have a (marginal) effect reducing heat transfer.
Old 4th July 2019, 08:56 AM   #5 (permalink)
jimbo1234567 is unaware they can edit their status
I tried these on my rs4 and they are a waste of money
jimbo1234567 is offline   Reply With Quote
Old 4th July 2019, 09:01 AM   #6 (permalink)
I'm sure you are right but I think it's worth a try. Same with TB spacers.
Old 4th July 2019, 01:49 PM   #7 (permalink)
charles charlie's Avatar
There is no way a spacer can give power gains. The plenum is just a pressurised reservoir that feeds valved cylinders. The volume of air that is mixed with injected fuel is governed by the bore size and piston stroke.
Another gimmick with some pseudoscientific mumbo jumbo. Anyone remember fuel line magnets?!
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 4th July 2019, 06:04 PM   #8 (permalink)
they are also known as a phelonic spacer which is there to insulate the manifold from the cylinder head. during normal driving there is huge amounts of air flowing through the inlet manifold and the temperature of the manifold will be dictated by the temp of the air coming out of the intercooler. its only when the car is parked up or you are in slow stop start traffic that the air flow through the intake mani will be very low and heat will be conducted up from the heads . that's when these will do anything for you.
Old 5th July 2019, 05:58 AM   #9 (permalink)
There are no proper tests of these spacers from any manufacturer which immediately makes me think Bullshit.
The process of engineering anything is take a theory, test it quantitatively, then rinse and repeat as the item/device progresses through improving versions.
Any device that therefore has no data to support it through development immediately shows that this proper R&D hasn’t been undertaken.
That shows they’re created out of someone’s thought that it might work not that it does work proven by rigorous testing.
There have been a small number of creative individuals that have tested these spacers and guess what?
Found no statistical difference.
Phenolic Spacer Test on the S4 Intake Manifold | MyAudiS4
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 5th July 2019, 06:57 AM   #10 (permalink)
L6DJX is reducing weight and getting stiffer ;)
L6DJX's Avatar
Cars owned: 2015 GTR Litchfield tuned
Oh i have missed your vocabulary... Love it Andy
Forged Engine and Dodson Gearbox @880bhp/745ftlb
Fully Stripped out w/ GT3 Rollcage &Tillet Carbon seats
Alcon SuperKit, with Project Mu H16-03 Pads
JRZ RS PRO- With full SPL bushings and Camber arms
Quaife front Diff
Nankang AR-1
L6DJX is offline   Reply With Quote
Old 5th July 2019, 07:07 AM   #11 (permalink)
adz87kc is living the dream
Wait, are you stating that there's nothing magnetic about fuel?!
adz87kc is offline   Reply With Quote
Old 5th July 2019, 08:25 AM   #12 (permalink)
Simonh's Avatar
Cars owned: MY11 R35 Recaro
Fuel line magnets have a scientifically proven impact of performance.
The extra weight slows you down.
Old 5th July 2019, 11:32 AM   #13 (permalink)
dudersvr's Avatar
A stock plenum and TB's will be good to 1500hp, I made 1101 whp on stock plenum and ASNU injectors. Save your money
Old 5th July 2019, 08:38 PM   #14 (permalink)
Already have it and it is cheap to buy and fit ***x1f642; But does anyone know the length and head type of the oem bolts; I believe the thread is M6?
Old 6th July 2019, 07:12 AM   #15 (permalink)
I’d ask why you want new ones? I’ve had 3 different intake manifolds on my car and the OEM bolts were reused every time.
If you’re really wanting new ones maybe remove one and measure it?
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 6th July 2019, 08:32 AM   #16 (permalink)
The spacer adds 3mm so I imagine the bolts need to be longer?
Old 6th July 2019, 08:50 AM   #17 (permalink)
Maybe measure OEM and add 2-3mm?!
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 6th July 2019, 08:53 AM   #18 (permalink)
Yes, I would be don't have the tools handy at the moment sadly.
Old 8th July 2019, 02:39 PM   #19 (permalink)
Managed to remove one bolt: M6 hex head with 25mm thread; next size is 30mm and fits with a washer. The 350/370Z's apparently show gains with a plenum spacer. Even if no torque or HP on a GT-R35, it may help reduce heat transfer a bit. Anyway, was only £65.
Old 8th July 2019, 08:44 PM   #20 (permalink)
you can buy a lot of beer for £65.
