Fault codes - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 28th July 2019, 02:57 PM   #1 (permalink)
Gymrat is unaware they can edit their status
Gymrat's Avatar
Fault codes
Had the car just over a week. Posted previously about the car kangarooing which seems to be when going from vacuum to boost, I've ordered dongle etc from Litchfield to do some logging. Yesterday however I got engine management light on. Codes coming up are p0223, p0228, p2133 with the same codes pending.
They seem to relate to throttle position sensor. Has anyone had this before, should I get the dealership onto this although I'm in Belfast, he's outside Wolverhampton.
Could these relate to my kangarooing?
Any help would be appreciated
Chris
Gymrat is offline   Reply With Quote
Old 28th July 2019, 06:36 PM   #2 (permalink)
dudersvr is A Legend
dudersvr's Avatar
It appears it could be the throttle position sensor in the pedal is reding wrong and fooling the throttle bodies (imo) it would be strange for both TB's to go down but if TPS is shot it makes sense.
Old 28th July 2019, 06:43 PM   #3 (permalink)
Gymrat's Avatar
I think I've caused it now.
After checking where the throttle bodies are I now realize I unplugged them to check they wee on tight yesterday before the fault popped up. I was checking and tightening everything. Not sure whether to clear them or leave it until I get the dongle to data log for Litchfields.
Old 28th July 2019, 06:46 PM   #4 (permalink)
dudersvr's Avatar
Did you have ign on, just unplugging will not cause a fault code
I would clear the codes and see if it runs ok if so problem solved
Old 28th July 2019, 06:52 PM   #5 (permalink)
Gymrat's Avatar
Nope car was off, seems to drive fine albeit jumpy at low revs
Old 28th July 2019, 06:56 PM   #6 (permalink)
dudersvr's Avatar
Reset the ecu
Go to ECM section, reset ecu
Old 28th July 2019, 06:59 PM   #7 (permalink)
Gymrat's Avatar
Reset the ecu
Disconnect the battery or is there a fuse to pull?
This didn't effect the remap on my focus,, I take it its the same with the gtr?
Old 28th July 2019, 07:02 PM   #8 (permalink)
dudersvr's Avatar
No you should be able to reset the ecu with the BT dongle you can with the laptop version
