Not making power - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree2Likes
  • 1 Post By David
  • 1 Post By Jimbostir
Old 10th October 2019, 03:42 AM   #1 (permalink)
webster444 is waiting for clean roads
I have recently finished putting the car together & had it mapped on a rolling road with rather disappointing results. The mapper was unable to add any more ignition advance in order to make power as it had started to knock & pulled he the timing back again.
Engine Spec:
Standard RB26 bottom end
-5 turbos
Tomei turbo elbows
Tomei 1.2mm head gasket
Tomei Poncam type As
Tomei adjustable cam wheels (have not been adjusted yet)
Sard 800cc injectors with ballast resistors
Nismo adjustable fuel regulator
Splitfire coilpacks
Link G4 ECU
Top secret catch can
HKS Silent exhaust, de-catted
Koso aluminium rad
Greddy hard boost piping
Uprated fuel pump (cant remember what one)
It was only able to achieve 425bhp 316ftlbs at 1.4bar, much less than I was expecting for that spec!
IATs reached 45degrees on the dyno but have not been higher than 19degrees on WOT pulls
Compression test did not show anything wrong with good equal compression over all 6 cylinders hot & cold.
Fuel Tesco Momentum 99
Any ideas or suggestions on what may be causing it to struggle to take any more ignition advance & therefore make better power, I am hoping that it may have been a bad batch of fuel so will run through a couple of tanks of fresh fuel before going back.
If anyone has similar spec to mine and could share their ignition table so I could compare with mine that would also be a big help
webster444 is offline   Reply With Quote
Old 10th October 2019, 12:59 PM   #2 (permalink)
K66 SKY is NO longer a subscribed reader of Evo magazine -The thrill of errrm....Advertising Watches???
K66 SKY's Avatar
Cars owned: 1992 Carlton GSi 3000 24v - 1996 R33 Skyline GT-R Standard Spec II.
This little bit sticks out for me! Why would you fit these parts with uprated Cams too if you are not going to adjust them to fully use the timing performance advantage these items are intended to give with your other engine modifications?!
JM2PW!
Passionate about old RWD Vauxhall-Opel's from the 1980's and 1990's but my Do-Luck BCNR33 Skyline GT-R is totally in another league and blows them all away!!!!
K66 SKY is offline   Reply With Quote
Old 10th October 2019, 05:57 PM   #3 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
You should make well over that even with the cam pulleys set at 0. I would say that assuming your fuel pressure reg is set to standard pressure or more then it’s the fuel. I have had a bad tank of momentum and I won’t use it any more. Shell is the way forward. I can share my ignition map, I’ve just got to get my laptop with the software on it. My spec before was similar with stock cams and I made 503 bhp when it was peak summer at 1.4 bar (30 degrees ish ambient.)
My engine build:
Old 10th October 2019, 06:10 PM   #4 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
My engine build:
Old 10th October 2019, 06:16 PM   #5 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
This map I made 557 hp on 1.5 bar, same setup in winter.
Itís not too different.
YouTube vid of it here mate. https://youtu.be/iAbdj1PbZVY
My engine build:
Old 10th October 2019, 10:08 PM   #6 (permalink)
Thanks for sharing your ignition map, once the laptop charges I'll compare it to mine.
I don't think fuel pressure is contributing as the injectors are only at 78% duty and when the mapper added fuel at the point of knock & it made no difference, hoping it is the bad batch of fuel. Problem with Shell V power for me is I'd likely use half a tank between my house and nearest Shell garage to fuel up!
The cam pulleys haven't been adjusted yet as I am planning on doing this once running correctly and then make adjustments, carry out a dyno pull and see what effect it has on response etc.
Old 12th October 2019, 09:00 PM   #7 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
I’d use any super unleaded from a proper petrol station. BP ultimate is really good and esso I have never had an issue with even on a trackday.
Please take a pic of the ignition map and put it on here.
My engine build:
Old 13th October 2019, 12:21 AM   #8 (permalink)
R33 GTR is aware he can edit his status
R33 GTR's Avatar
Cars owned: R33 GTR & Shitroen Saxo
Weird you say that, I use Tesco all the time as the only time I've had bad batches of fuel it has been from Shell
To the OP, my car makes another 100bhp with smaller turbo's ( GTSS ) and standard cams
R33 GTR is offline   Reply With Quote
Old 13th October 2019, 12:32 AM   #9 (permalink)
kenecchi is driving a fake GTR
What kind of spark plugs are you running and do they all look normal? Between your fuel and ignition system, are any of the parts old enough to consider they might be failing?
kenecchi is offline   Reply With Quote
Old 13th October 2019, 07:39 PM   #10 (permalink)
Plugs are NGK BKR7EIX, they look normal, slightly rich but not too bad.
Majority of the ignition system is new, coils, plugs & harness are all new. Again majority of the fuel system is new injectors & fpr, fuel pump is a couple of years old.
Ignition table below:
Old 14th October 2019, 11:51 AM   #11 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
BKR are ISO plugs and 2.5mm shorter. Correct ones are BCPR which are JIS. You can easily pull the spring on the coil to make sure you get better contact with the plug tips.
Old 14th October 2019, 05:31 PM   #12 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
I’ve used BkR8EIX for years. No problems. I’d change from 7s to 8s.
My engine build:
Old 15th October 2019, 12:22 AM   #13 (permalink)
Lith is lurking
Cars owned: R33 GTS25t
How does the car feel? No chance it's just a low reading dyno, it seems a lot of UK tuners do made up engine HP numbers which usually look really inflated - so comparing with those could cause disappointment.
Also, no sign of a triggering upgrade - something now that these things which are getting on is getting very worth addressing. Could be ignition scatter, how "smooth" does your power curve look?
'97 Skyline GTS25t
12.6 @ 112mph
Old 17th October 2019, 09:44 PM   #14 (permalink)
Car pulls very well, definitely much better than before, the car was in a mild state of tune prior to this however, comparing it to other cars I have owned of similar power/weight I would say it feels about right for that power.
Power curve is pretty smooth
Old 18th October 2019, 03:17 PM   #15 (permalink)
David's Avatar
Some ideas:
Could the cam timing be a tooth out?
Could you have really high exhaust back pressure from a CAT or restrictive exhaust (are HKS silents rubbish, and you dont mention down pipe)?
Whats the condition of the intercooler?
My car made more power than yours with stock turbos at slightly more than 1 bar on abbeys rolling road
Jimbostir likes this.
R32 GTR Restoration/Modification Track car build
Old 18th October 2019, 04:17 PM   #16 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
Some really good suggestions from David.
Also, are you talking BHP @flywheel or hubs?
David likes this.
My engine build:
Old 18th October 2019, 05:00 PM   #17 (permalink)
David's Avatar
Jimbo makes a really good point
Another thought is
- exhaust gas leak before turbo
- Boost leak
- Were valve clearances checked after fitting the pon a cams. Is there possibility the valve clearances are tight and effecting compression when the engine is hot
Both would work the turbos much higher than normal and lead to reduced tolerance to ignition.
Old 20th October 2019, 09:59 PM   #18 (permalink)
Some good ideas there.
The cam timing could well of shifted so will check that.
Exhaust wise I'm sure I have read of people making much higher power using the same exhaust? Theres no cat or restrictive down pipe, down pipe is aftermarket but unsure of brand. No signs of any exhaust gas leaks either.
Valve clearances were all checked and adjusted to within spec when the cams were fitted, there were only 4 valves that required adjustment.
Externally the intercooler looks in good condition but haven't looked inside, the IAT appears to be healthy during WOT pulls however.
Power figure is at the flywheel
Old 20th October 2019, 10:50 PM   #19 (permalink)
David's Avatar
It it were my car I would buy or borrow a boost leak checker next
