GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - So much for underseal/restoration project
Old 20th February 2019, 10:56 PM   #802 (permalink)
K66 SKY
K66 SKY is NO longer a subscribed reader of Evo magazine -The thrill of errrm....Advertising Watches???
K66 SKY's Avatar
Cars owned: 1992 Carlton GSi 3000 24v - 1996 R33 Skyline GT-R Standard Spec II.
Originally Posted by tonigmr2 View Post
Ok so a refresh is required. The por15 has not done a good job. Whether product or application is open to debate, but it looks like the underside needs more treatment. Only 4 years and 2000 miles later, garaged and not used in winter!
If the underside has not been initially wire brushed down to remove rust particles from all corroded areas Toni until you get to solid metal, The Rust Treatment applied will just flake off with the loose underneath debris during normal road use....rendering said rust protection absolutely useless thanks to not removing all the detritus.
In the four years since, this rust inhibitor should have been repeated and reapplied at least once more every six months of the cars use to remain 100% effective. Its not a one time done forget about it deal because it requires regular repeated maintenance!
Time to get an abrasive wheel for your grinder, Acid etch primers/paints & sealants, a good compressor and an applicator gun like this below....
And after a few weekends of hard work your vehicles underneath will be as good as new once more.
HTH!
Passionate about old RWD Vauxhall-Opel's from the 1980's and 1990's but my Do-Luck BCNR33 Skyline GT-R is totally in another league and blows them all away!!!!
K66 SKY is offline   Reply With Quote
